Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
WHERE IS THE FILTER SYSTEM ON THE kITCHEN AID KSCS251?
  • 115 Answers
SOURCE: change filter?
filter is in kickplate under freezer door and it should turn counter clockwise then pull straight out then replace please rate me
Posted on Jan 05, 2009
SOURCE: Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
Posted on Feb 18, 2008
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Posted on Sep 16, 2008
aasc
  • 1606 Answers
SOURCE: kitchen aid kscs251 gets hot on front strip
Remove the bottom kick panel , and check that the coils are clean of dust , lint , pet hair , etc . Next , pull the refrig out from the wall , and remove the back panel . Check to see if the fan , cooling the compressor is working . If not , it should be replaced .
Posted on Sep 19, 2009
Testimonial: "fan appears to be out. now I need to find the right replacement part: the one i found looks like it is not going to work."
rickead1
  • 1998 Answers
SOURCE: My kitchen aid kscs251 side
have you checked the water inlet valve in the rear of the machine? This is the piece that is directly responsible for bringing water up to the icemaker if you have water going to the door you can disconnect the icemaker line and see if there is any debris caught inside the small screen for that inlet valve side if after you do this you do still not have water or do not find any debris in the line. You would then test for the presence of power going to the top of the solenoid on the top of the valve if you did have power and there were no debris found inside the small screen you would then after performing this final test on this video would look at replaceing the inlet valve in your unit This is fairly common to happen in units once every 3-5 years click this link for the video http://www.youtube.com/watch?v=AlYCJr9dc3E if you have any further questions message me back the icemaker also does not make ice until the icemaker itself reaches 32 degrees at which time it calls for water from the water inlet valve. I await your reply Thanks Rick
Posted on Jun 01, 2011
Is the filter behind the kick plate on the Kitchen Aid Superba made in 1998?
Hi, the filter should be on the bottom kick plate and should have a cap of the same color as the kick plate.
Hope this helps
May 23, 2014 | KitchenAid Superba Architect KSCS25INSS...
I hooked up my refrigerator and the ice maker is not working.it's a kitchen aid superba kscs251
First make sure your water valve is working . If so , look for fill tube that fills ice maker to be frozen. If it is frozen , unthaw tube. If its not then replace the ice maker.
May 31, 2013 | Refrigerators
What happens to filter if fridge is off for a month? It is a kitchen aid french door with freezer bottom. will the filter go bad and need to be replaced?
As water sits at room temps its can cause your filter to go bad or even clog. I would replace the filter and flush the system after filter installed to clean out the supply line to the dispenser door.
Safety first, good luck
Jul 27, 2011 | Refrigerators
Kitchen Aid Refrigeratior, model # Kscs251 The center frame is very hot.
this heat that you feel is normal. The heat is there to keep the doors from sweating. hope this helps.
Jul 05, 2011 | Refrigerators
Water not flowing from Kitchen Aid Refrigerator. I've switched the filter and it has not resolved the problem. the unit is one year old, was working properly. 2 days ago, water leaked from spout and that...
water maybe frozen somewhere in the system. may need to disconnect water connections at various points and retry to narrow down where freeze up is at.
Jan 06, 2010 | KitchenAid Refrigerators
Kitchen aid kscs251 gets hot on front strip between the doors
Sep 19, 2009 | KitchenAid KSCS25FKSS Side by Side...
Kitchen aid 110v 450watt, I want to convert to 220v
Hi guys,
The only available Kitchen Aid stand mixers on the European markets are the Kitchen Aid Classic and the Kitchen Aid Artisan.
The best way is to contact a Kitchen Aid service center / repair facility in your area.
Here is the European website of Kitchen Aid: http://www.kitchenaid.eu/eu_EU/ka/ka_europe.htm
If you bought a different Kitchen Aid Stand Mixer (like the Professional series) you probably won't find the required parts to convert it to a European model. The only way would be to use a voltage converter.
I hope this helps.
Sep 24, 2008 | Food Mixers
Nov 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
Aug 02, 2007 | KitchenAid KSCS25FKSS Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
389 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
