Question about Seagate Medalist 3491A (ST3491A) .43 GB Hard Drive
On the Seagate ST3491A where is the power connection?
  • Seagate Master
  • 7,733 Answers
If is a external one usually is on the back. But use this manual if you need it.
Posted on Oct 05, 2010
Cannot connecy power supply to unit
You need a USB cable to connect the seagate drive to the PC and you need to plug the seagate's power supply into the seagate drive and the wall.
Jun 17, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How to connect
You need a USB cable to connect the seagate drive to the PC and you need to plug the seagate's power supply into the seagate drive and the wall....
Externalseagate 250go not open how to solve
If you cannot open or see the harddrive when you connect it to your computer after it is powered on then that is the external harddrive itself. First, check if the power connection is connected and the usb cord connect correctly. Then see if any lights come on on the external hard drive. If lights does come on and still nothing showing or coming on to the computer, then your harddrive is history. Seagate makes one of the worstest hardrive. You can google this up about seagate promblem and there are thousand out there who have this same promblem. I know this because I have the same promblem you have.
Jan 17, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
St3160827as seagate hdd is not detecting in bios , other new seagate hdd is working fine with the same connection(sata cable and power card) I have imp data in that hdd ,pls help me how to get data...
Turn your computer off.
Disconnect the power cord.
Disconnect all other disk-drives and CD/DVD drives, leaving only the "suspect" drive connected.
Restart your computer, and enter BIOS SETUP, and see if the drive is detected, and how it is connected (primary/secondary, master/slave).
Read the model-number and serial-number and manufacture-date on the disk's label,
and access Seagate's web-site, to check the warranty-status of the drive.
If the warranty is valid, Seagate will replace the drive, at minimal cost to you.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Nov 03, 2010 | Seagate (ST3160827AS) 160 GB Hard Drive
How can I power up my seagate 7200.11 500gb external h/drive to my pc
If your OS supports this device ... plug in the power supply to proper voltage ... and connect the end to the device. Use a appropriate USB cable from the back of the Seagate and plug into an available USB connection on your computer.
Oct 03, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate freeagent 500gb not getting powered
is the power frequency different out in india, it's not just the voltages you have to watch!
If you can remove the hard drives and use a usb interface to connect them then software like filescavanger will recover files providing the hard spins up ok.
Jan 11, 2010 | Seagate Free Agent Go Small 12 GB USB...
Will the ms9327e + (usb) support a SATA drive?
well it depends on what board you have.
your best bet is to look on the motherboard.
the SATA connection looks almost identical to the connection on the harddrive, so you can use that for reference.
on the harddrive you will see 2 plugs. the smaller one plugs into the motherboard and the larger one is power.
for power, power adaptors are made to convert the standard 4 pin connector to a SATA one.
Feb 24, 2009 | Matsonic MS9327E (MS9327E+(USB))...
New Seagate FreeAgentPro USB eSATA 500GB power on light not glows
Thank you for your reply.
I have solved the problem with local help.
Printed installation manual of Seagate 500 GB eSATA external hard drive has not properly mentioned how to use power on/off switch once connected to mains. I could get local help, who has already used the device. On/Off switch to be pressed for few seconds after mains connected, sometimes it comes automatically once power is on and USB cable pluged to the USB port of PC if power supply is ok. There is no indicator for the power supply (before device glows) after connected to the mains. I was in confusion whether power supply is ok or not.
Finally, It was found that the problem was with mains power supply and I have changed the power socket and adapter.
SP Jena
Nov 18, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
When i connect my seagate via usb nothing comes up on my pc, the light comes on on the external h/d but nothing pops up on the pc? help please i need precious photos on it. thanks
have you try connect your pen drive to the same usb port, is it working?
If Pendrive is working but not the Seagate hardisk. Most propably is your USB power is not enough to support the External Seagate hard disk, you need to supply more power to the Seagate hard disk by using USB Y cable(1 end connect to Seagate hardisk where the other end got 2 USB connector to connect to your PC).
Jul 30, 2008 | Computers & Internet
Seagate Medalist 3491A (ST3491A) .43 GB Hard Drive Logo
66 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
