Question about Hoover U5750-900 WindTunnel Bagless Upright Vacuum
I have a Hoover U5750-900 Windtunnel Bagless and For some reason, the belt has been replaced correctly, but there is a very LOUD vibration/rattling coming from the agitator, like it's hitting the assembly/bottom plate? Is there a reason that there would not be enough distance from the plate?
  • 126 Answers
SOURCE: hoover s3755 bagless windtunnel canister
Very likely it's the cord at the nozzle neck. These cords flex when you vacuum and they often break internally where the cord goes into the neck. Turn the vacuum on and wiggle the cord at the powerhead and see if the powerhead comes on and off. If this happens, then you will have to replace the cord.
On some of the early models, the receptacle in the hose, where it plugs into the top of the wands, will break away from the plastic pins it sits in, and the receptacle will slide back into the handle, which means that it will not plug into the powerhead connection when you connect the hose. You can check this by looking at the end of the hose and observing if the receptacle is sitting flush with the opening it sits in. If it is pushed back, it will not make a complete connection with the powerhead cord that is sitting at the top of the wands.
Posted on Jan 20, 2008
  • 126 Answers
SOURCE: Hoover self-propelled windtunnel belt pops off
The correct belt is a 38528035. If the belt does not have this number printed on it, it is a generic belt and probably the wrong one. The pulley on the transmission is "convex" because this pulley design keeps the belt running in the middle. (a belt will always try to "climb up a hill") If the motor shaft and the pulley are not aligned properly, the belt will constantly throw off. This can be a result of a bad motor mount (located inside the motor compartment.) The motor shaft end has a rubber cover that absorbs vibration and keeps the motor positioned squarely. The handle could also be loose on the pivot. It is held down by two metal clamps that screw securely to the bottom, holding the handle on to the base and allowing for the handle to pivot backwards. This problem can be difficult to diagnose and I have had many in my shop for repair. It takes a seasoned and experienced repairman to find a solution to this problem, in most cases. The disadvantage I have here is that I cannot see your machines to inspect all the various things that effect the belt alignment. I hope that some of this information will help.
reddevil6
  • 1673 Answers
SOURCE: How to install front wheel assembly on Hoover Bagless windtunnel vaccuum
There is a spot that sticks up on the holder for the wheels, the hole in the spring goes there, then it fits between the holder and the base asm.04f5295.jpg
Posted on Feb 29, 2008
reddevil6
  • 1673 Answers
SOURCE: Hoover US8174-900 Savvy Bagless
It uses a cogged belt, turn it over, remove the bottom plate, remove the other screws from the bottom, turn vac back over and remove the Hoover emblem, there is a screw there to remove and the top comes off, then you can get to and replace the belt.
Posted on Jun 01, 2008
  • 294 Answers
SOURCE: height adjustment on Hoover Windtunnel u5755-900 no longer works
On this model it is only a single slide adjustment lever. have you trie to tilt the vac backwards (lifting the wieght off the front wheels) and then slide the adjustment lever?
If there is a mechanical issue with it. take the bottom plate and roller out, and then the 2 small screws which hold the cover on underneath. you should be able to see the problem from there
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Posted on Jan 18, 2009
How to stop the main belt from comming off the motor shaft on a hoover modle u6634-900/windtunnel
Hello there! If you have replaced the belt and it is still slipping off, you may be not have the right belt for your vacuum. This unit takes a flat belt and a v-belt. Make sure you are replacing the belts with Genuine Hoover Parts. I have included the links below where you may go to order the belts specific to your cleaner.
WindTunnel PowerDrive Belt 2 Pack
WindTunnel Self Propelled Belt
Hope this helps!
Jun 21, 2014 | Hoover Self-Propelled WindTunnel Bagless...
My Hoover Bagless Windtunnel vacuum has no suction on the bottom, although the hose works. Everything else seems to be working properly.
Check the belt, look like we have the same problem, I just unscrew the bottom part where he brush roller is located and found a broken belt
Easy to replace just follow this instrctions
Jan 31, 2011 | Hoover U5753-900 WindTunnel Bagless...
Hoover beater bar is loud & vibrating.
brush roller /agitator needs replacement. part price : $25.00 to $ 30.00
May 06, 2010 | Hoover U6630-900 WindTunnel Bagless...
Hoover U5780-900 Windtunnel Cyclonic Bagless
You probably need to change the belts. Here are the belts you need and the manual:
Hoover 5780-900 Belts
Manual
Dec 22, 2009 | Hoover U5780-900 Windtunnel Cyclonic...
My HooverDeluxe Elite Rewind became extra loud
If the belt is really worn it can cause that. I wold try changing the belt if you haven't recently. Here are the belts you need:
Hoover Elite Rewind Belts
Nov 14, 2009 | Hoover U6630-900 WindTunnel Bagless...
Describe how to replace belt on hoover windtunnel bagless
If you turn the vacuum so the bottom is facing up you will see the base plate that covers the roller brush. There will be four screws (usually phillips head), remove the screws and the base plate will lift off. You now have access to the roller brush and belt. Lift the roller brush up and remove the old belt. Place one end of the new belt over the motor shaft and the other end over the roller brush and put the roller brush back in place. Now simply replace the base plate and you're done! This models requires Hoover belt # 38528033 (single) or Hoover belt #40201160 (2 pack). You can get this belt at www.vacbelts.com.
Here's the pages:
http://www.vacbelts.com/hoover-40201160-belt.htm
http://www.vacbelts.com/hoover-38528033-belt.htm
Oct 15, 2009 | Hoover U5750-900 WindTunnel Bagless...
Replacement belt # for hoover wind tunnel model u5750-900. original belt # 38528-035, please
your belt number is correct ending in 035. I have had luck with belt number ending in 033 also.
Jan 28, 2009 | Hoover U5750-900 WindTunnel Bagless...
Had a problem with the brushroll now its burning up the flat belt
When you put the flat belt on, is the print on the outside of the belt? Is the brush correctly positioned?
Dec 21, 2008 | Hoover U6630-900 WindTunnel Bagless...
Hoover Windtunnel Bagless bolt fell off
With this self propell series, the entire bottom needs to come apart to re-install the nut. if it is one month old I would highly recommend taking it in for warranty service. What plastic is melted?
Nov 02, 2008 | Hoover U6630-900 WindTunnel Bagless...
Hoover Windtunnel selfpropelled bagless vacuum
Hoover emailed me back right away with a solution and a thorough explanation for a very easy fix. I guess I should have thought of that myself. Oh well, but that did not cost me anything. Now that makes me happy.
Jun 18, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Hoover U5750-900 WindTunnel Bagless Upright Vacuum Logo
54 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
