Question about Apple iTunes
My Iphone won't sync properly with Itunes. Everytime I plug it in it wants to "set up new Iphone". Or it gives me the option to restore my last iphone back up, only when I go to do this it says the restore failed. It's only since I downloaded the latest version of Itunes 10.0.1
    President:
  • 2,291 Answers
ITunes.exe has been set to run in compatibility mode for an older version of Windows. For best result, turn off compatibility mode of iTunes before you open it.
> 1. Make sure iTunes isn't running. 2. Click Start, type regedit, then press Enter. 3. Navigate to this Registry location:HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers 4; Its better you clean/repair Windows registry with Reg In Out. 4. Look in the main pane for a key that refers to iTunes. If you find one, delete it, then exit the Registry. 5. Start iTunes. The offending message should be gone!
Posted on Oct 08, 2010
I can't unlock my Ipad, it won't accept my password, how can i change my password
If you have synced your iPad with iTunes before you forget your password, you can reset your iPad by using iTunes without losing data. Through iTunes, you can restore your iPad from the last backup and remove the passcode from your locked tablet while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPad Passcode with Recovery Mode section below.
Step 1. Connect your iPad to the computer with via a USB cable that your iPad has trusted.
Step 2. Launch iTunes. If you've synced your iPad with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPad and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it and follow prompts to choose the latest iTunes backup to restore your iPhone.
After the restoration process is complete, your passcode will be erased and all your data will be restored from your backup. You will now be able to access your iPad without any passcode. And you can set your new password on iPad.
http://www.leawo.org/tutorial/how-to-reset-password-on-iphone.html
Nov 23, 2016 | Apple iPad Tablets & eReaders
Forgot password on my old iphone 4s 16gb
It's the most frustrating thing for us to forget our iPhone password. In order to unlock and access your iPhone normally, you need to reset your iPhone password. Resetting iPhone password is not complicated.
If you have synced your iPhone with iTunes before you forget your iPhone password, you can reset your iPhone by using iTunes without losing data. Through iTunes, you can restore your iPhone from the last backup and remove the passcode from your locked iPhone while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPhone Passcode with Recovery Mode section below. The following steps will show you how to reset iPhone password with iTunes.
  1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
  2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
  3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by in the Summary window.
forgot-password-old-iphone-4s-16gb-oxaxc0rwhkhzilrwacqreyis-1-0.jpg After the restoration process is complete, your passcode will be erased and all your data will be restored from your backup. You will now be able to access your iPhone without any passcode. And you can set your new password on iPhone.
How to Reset Password on iPhone
Oct 12, 2016 | Cell Phones
How do i download everything on my iphone 3g onto my iphone 4 by using itunes
Plug in your iPhone 3g, go into iTunes and sync it with iTunes. Then right click where it says for examples Alex's iPhone and back up your iPhone 3G. Once you're done, plug in your iPhone 4 and set it should give you a choice of either setting it up as a new phone or syncing with last back up. If that does not come up, just plug in your iPhone 4 and sync everything accordingly. Hope that helps.
Aug 28, 2011 | Apple iPhone 3G
My iphone want go pass the silver apple screen
Using the Restore function for your device is part of standard troubleshooting procedure. Restoring your device will delete all the data from your device, including songs, videos, contacts, photos, calendar information, and any other data. All settings are restored to their factory condition.
Whenever you restore your device, Apple highly recommends that you perform a sync prior to restoring to back up any changes since your last sync. If you have movie rentals on the device, see iTunes Store movie rental usage rights in the United States before restoring.
Use the following steps to restore your device:
  1. Make sure you have the latest version of iTunes installed and running before attempting to update.
  2. Connect your device to your computer.
  3. Select your iPhone, iPad, or iPod touch when it appears in iTunes under Devices.
  4. Select the Summary tab.
  5. Select the Restore option.
  6. When prompted to back up your settings before restoring, select the Back Up option (as seen in the image below). If you have just backed up the device, it is not necessary to create another.
  7. Select the Restore option when iTunes prompts you (as long as you've backed up your device, you should not have to worry about restoring your phone).
  8. Once the restore process has completed, the device restarts and displays the Apple logo while starting up:
    iPhone only: For the iPhone only, after a restore, the iPhone displays the "Connect to iTunes" screen. Keep your device connected until the "Connect to iTunes" screen goes away or you see "iPhone is activated." If iTunes does not have an Internet connection, you cannot complete this step.
  9. The final step is to restore your device from a previous backup. Once your device is restored and-in the case of the iPhone-in the process of activating, you should be able to see the following in iTunes:
    Select the backup you want for your device and select the Continue button to complete your device's restoration.
If you do not want to restore from backup, select "Set up as new..." If you want to preserve previous backups that iTunes has made, be sure to back up the appropriate directory before choosing to set up as new.
Aug 12, 2011 | Apple iPhone Smartphone
Switched my iphone 3 on today and all i got was the logo apple cant do anything els with it what the problem
Aug 12, 2011 | Apple iPhone 3G
My iphone keeps on showing the opening mode with logo ...what can i do...
Aug 11, 2011 | Apple iPhone Smartphone
How can you reset a forgotten password on the iphone a1203 phone
reset-oxaxc0rwhkhzilrwacqreyis-1-0.jpg How to Reset Password on iPhone
Jul 23, 2011 | Apple iPhone Smartphone
How can i put music on my iphone using itunes
1. Open iTunes. Open the Edit menu on Windows or the iTunes menu on a Mac. Click the "Preferences" option. Make sure the "Disable automatic syncing for all iPhones" check box is selected.
2. Plug your iPhone into the computer and wait for iTunes to recognize it. Click on your iPhone's icon on the right side of the iTunes window. Click the "Music" tab.
3. Select the music you want to sync to your iPhone using playlists. You can also select the option to sync all your music to the iPhone.
4.Click "Sync" when you're done customizing your settings.
Get more details: Transfer music files from Mac to iPhone
Nov 05, 2009 | Apple iPhone Smartphone
I locked my i phone
Probably will have to put it in DFU mode and restore as new device in Itunes which will delete all your info on phone. (Hope you have it previously synced in itunes). Then sync info back to iphone from your itunes. If you want to try do this, plug it in to a computer with iTunes, and after it tells you that you can’t access the information because it’s locked, hold the power button (on the top left) and the round button on the front. It’ll take a few seconds, but keep holding until it gives you the option to restore it to factory settings. This will erase everything on it, good luck
Jul 08, 2009 | Apple iPhone Smartphone
Ipod touch i forgot my password and got a new computer
Sadly the ONLY way to get beyond the password with out having the code is to restore using itunes. Below I have posted a step by step on restoring an iPod touch.
Last Modified: February 16, 2009 Article: HT1414 Old Article: 305744 Using the Restore function for your iPhone or iPod touch is part of standard troubleshooting procedure. Restoring your device will erase all data from your iPhone or iPod touch, including songs, videos, contacts, photos, calendar information, and any other data. All iPhone or iPod touch settings are restored to their factory condition.
Whenever you restore your iPhone or iPod touch, Apple highly recommends that you perform a sync prior to restoring in order to back up any changes since your last sync. If you have movie rentals on the device, see this document before restoring.
Use the following steps to restore your iPhone or iPod touch:
Make sure you have the latest version of iTunes installed and running before attempting to update. Connect your iPhone or iPod touch to your computer. Select your iPhone or iPod touch when it appears in iTunes under Devices. Select the Summary tab. Select the Restore option. When prompted to back up your iPhone or iPod touch's settings before restoring, select the Back Up option. If have just backed up the device, it is not necessary to create another.
Select the Restore option when iTunes prompts you (As long as you've backed up your device, you should not have to worry about restoring your phone).
Once the restore process has completed the iPhone or iPod touch restarts and displays the Apple logo while starting up
May 07, 2009 | Apple iPod touch
Apple iTunes Logo
601 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
