Question about Sony Handycam CCD-TRV21 Camcorder
The tape cartridge feels as if the entry slot is becoming narrower as the cartridge descends. This effect is most pronounced at the front (lens end) of the device. The cartridge will not reach the bottom of the entry slot.
    Genius:
  • 1,812 Answers
Tape mechanism problems are quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Oct 05, 2010
Front end makes popping sound when turn a corner
If you are feeling this through steering wheel more pronounced at lower speeds it is known problem with intermediate steering shaft. If your feeling it in floor boards maybe issue with engine cradle mounts.
Aug 06, 2012 | 2001 Pontiac Sunfire
Lexmarx X4975 disable complete-a-print
The Lexmark X4975 Professional is a multifunction thermal inkjet printer that not only prints documents and photos, but also makes two-sided printouts, scans and copies materials and accepts line-connected or wireless device print requests. Three color ink cartridges--cyan, magenta and yellow--and a single black cartridge rest inside an ink cartridge carrier. Printer cartridge replacement is not difficult. Each cartridge is secured in place with a cartridge carrier lid that opens with the simple press of a lever.
  • Turn on the Lexmark X4975 printer. Lift up the entire scanner unit to rest in an open, angled position that reveals the interior of the printer.
  • 2
    Press down on the lever in front of the printer cartridge that you need to replace to open the cartridge carrier lid.
    • 3 Pull the old cartridge from its slot in the carrier.
    • 4
      Grasp the tab attached to the tape covering the electrical contacts and ink nozzles on the back and bottom of the replacement printer cartridge. Pull the tape away from the cartridge carefully without touching the contacts or nozzles.
    • 5
      Insert the cartridge into the empty slot--the electrical contacts facing the back of the slot inserted before the front of the cartridge.
    • 6
      Flip the cartridge carrier lid over the top of the cartridge and then push down on the top of the lid until you feel the lever lock the lid in place.
    • 7
      Repeat the replacement process with the other printer cartridge if necessary. Lower the scanner back into position when finished.
      Increase Engine Horsepower.
Jun 02, 2012 | Lexmark X4975 3-in-1 Wireless Inkjet...
How to replace ink cartridges
Instructions Things You'll Need
  • New ink cartridges
    • 1
      Turn on your Canon PIXMA MP150 printer. Lift the scanning unit and hold it open with one hand. Slide the support arm on the right side into the groove at the right front corner of the unit so that the scanning unit rests in an open position.
    • 2
      Apply pressure on the top front of the first Canon FINE ink cartridge with your finger until you feel the cartridge unlock within its slot. Pull it from the slot and set it aside for disposal.
    • 3
      Grasp the tape end hanging from the new replacement cartridge and remove it carefully from the cartridge without touching the ink nozzles or the gold electrical contacts.
    • 4
      Hold the cartridge by its sides in front of the slot with the electrical contacts facing away from you and the front of the cartridge angled down slightly.
    • 5
      Slide the cartridge carefully into the slot and then push up on the bottom front of the cartridge until you feel the cartridge lock into the slot with a click.
    • 6
      Repeat the replacement process with the second cartridge if you need to change it.
    • 7
      Lift the scanning until the support arm pulls out of the groove. Push the arm back into its original position
Aug 10, 2011 | Canon PIXMA MP150 All-In-One InkJet...
I don't know how to load the ink into the printer of the iP 1600 Canon pixma
How to install ink cartridges
1. After confirming that the printer is powered on, open the front cover. The ink cartridge holder moves to the replacement position.
2. Take out an new cartridge from its casing and gently remove the orange protective tape in the direction of an arrow.
Caution: Do not attempt to reattach the protective tape once you have removed it. Do not touch the gold electrical contacts or the print head after removing the protective tape.
3. Insert the color cartridge into the right slot and then the black cartridge into the left slot.
Note: Push up on the nearest side of the cartridge until it clicks into place.
4. Confirm that the ink cartridges are installed properly.
(A) The ink cartridge is not installed properly.
(B) The ink cartridge is installed properly.
5. Close the front cover. Wait until the preparatory operation is complete; it takes about one to two minutes.
How to remove ink cartridges
2. Remove the ink cartridges.
Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
Apr 25, 2011 | Office Equipment & Supplies
How to change the ink cartridge
Checking the ink levels
  1. Open the HP Director .
  2. Click Settings , point to Print Settings , and then click Printer Toolbox .
  3. After the Printer Toolbox opens, click the Estimated Ink Level tab.
  4. For information on obtaining replacement cartridges, click Print Cartridge Ordering Information .
Replacing the print cartridges
  1. Make sure the HP all-in-one is on. WARNING: If the HP all-in-one is off when the print-carriage access door is lifted to access the print cartridges, the HP all-in-one will not release the cartridges for changing. Damage may occur to the HP all-in-one if the print cartridges are not docked safely on the right side when you try to remove them.
  2. Open the print-carriage access door by lifting from the front center of the device, until the door locks into place. The print carriage is on the far right side of the HP all-in-one. c00228292.jpg 1 - Print carriage access door 2 - Print carriage
  3. When the print carriage is idle and silent, press down on the end of each cartridge to snap it out of the carriage. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. If replacing the black or photo cartridge, remove the print cartridge from the slot on the right. c00228293.jpg 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print
  4. Gently pull the print cartridge toward you, out of its slot.
  5. If removing the black print cartridge to install the photo or gray photo print cartridge, store the black print cartridge in the print cartridge protector.
  6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. c00228294.jpg 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape c00228295.jpg
  7. Slide the new print cartridge forward into the empty slot. Push the print cartridge forward until it clicks into place. If the print cartridge you are installing has a white triangle on its label, slide the print cartridge into the slot on the left. The label for the slot is green with a solid white triangle on it. If the print cartridge you are installing has a white square or a white pentagon on its label, slide the print cartridge into the slot on the right. The label for the slot is black with a solid white square and a solid white pentagon on it. c00228296.jpg
Jan 21, 2011 | HP OfficeJet 6210 All-In-One InkJet...
How to load the ink cartridge
Jan 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
How do I remove and replace the ink catridge ?
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01429130&cc=us&lc=en&dlc=en&product=3645100&tmp_track_link=ot_search
Please follow this link and well you would have your ink cartridges replaced without a problem.
Otherwise this is what you do
Step one: Remove the old cartridge
  1. Press the Power button ( c01983533.gif ) to turn on the HP product.
  2. Open the front access door. The carriage moves to the far right side of the HP product. CAUTION: If the HP product is off when the front access door is opened, the HP product will not release the cartridges. Figure 1: Open the front access doorc01429211.gif
  3. Wait until the carriage is idle and silent, and then lightly press down on a cartridge to release it.
    • To replace the tri-color cartridge, remove the cartridge from the slot on the left.
    • To replace the black cartridge, remove the cartridge from the slot on the right. Figure 2: Remove the black cartridgec01429212.gif
  4. Pull the cartridge toward you and out of its slot.
Step two: Prepare the new cartridge Use the following steps to prepare the new cartridge for use in the HP product. Which cartridges you use depends on your country or region. To check the cartridge compatibility for your product, right-click this link, HP SureSupply , and then click Open in New Window . If your language or country does not display next to the globe icon (c01906983.gif ) select your language and location.
  1. Remove the new cartridge from its packaging. Be careful to touch only the black plastic.
  2. Use the pink pull tab to remove the plastic tape gently. Figure 3: Remove the tapec01367670.jpg 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or the ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. Figure 4: Do not touch the contacts or ink nozzlesc00442147.gif
Step three: Replace the old cartridge Use the following steps to replace the old cartridge.
  1. Hold the new cartridge with the HP logo on top, and then slide the cartridge at a slight upward angle into the empty cartridge slot. Push the cartridge in firmly until it snaps into place.
    • To install a tri-color cartridge, insert it into the left slot.
    • To install a black cartridge, insert it into the right slot. Figure 5: Insert the black cartridgec01429213.gif
  2. Close the front access door.
  3. An alignment page prints. You do not need to do anything with this page yet. Continue to the next step.
Step four: Place the unused cartridge in a cartridge protector If you are temporarily removing a working cartridge (for instance, removing a black cartridge in order to install a photo cartridge), put the cartridge that you are not using in a cartridge protector. NOTE: Cartridge protectors come only with photo cartridges. If a cartridge protector is unavailable, store the unused cartridge in a rigid, airtight container (not a plastic bag). If unprotected, the cartridge can dry out and become unsuitable for use. Step five: Align the new cartridge The HP product prints a cartridge alignment sheet when you install new cartridges.
  1. When prompted, load unused, plain white, U.S. letter or A4 sized paper into the input tray, and then press OK on the HP product control panel.
  2. Lift the scanner lid.
  3. Place the alignment sheet on the scanner glass so that the top of the sheet is on the right side with the text facing down. Make sure that the sheet is aligned with the right front corner of the scanner glass. Figure 6: Place the alignment sheet on the scanner glass
  4. Close the scanner lid, and then press OK on the HP product control panel. The HP product aligns the cartridges.
Oct 22, 2010 | HP OfficeJet J4580 All-In-One Laser...
Can I print in only black if one of my color ink cartridges is empty?
Yes, you can! You just need to paint your empty cartridge with a black sharpie, one of the side of the cartridge that points out of the printer where you can see ink level.
Or, get a black tape and stick a piece inside of the empty space in the cartridge slot without the cartridge. Again it's a narrow vertical side closest to the edge.4c8b63e.jpg
It will be seen by the sensor as the cartridge is not empty.
Sep 11, 2010 | Brother MFC 420CN All-In-One InkJet...
Where do I access the ink cartridge compartment to change the cartridges?
With the power on, open the front cover. The cartridges will move to the replacement position:
1) Push down lightly on the front of the cartridge and pull back and down, out of the slot
2) To replace, make sure you have removed the tape and other packaging materials from the new cartridge, then push in and then up, until the cartridge clicks into place in the slot
3) Close the front cover
4) Your printer may fiddle around for awhile preparing the new cartridge for use
I hope this helps!
Mar 10, 2010 | HP Photosmart C4280 Aio Printer
Changing cartridges
1) With the power on, open the front cover. The print head should move to the center.
2) Prepare the new cartridge for installation by removing the tape(s). Do not touch the area of the ink cartridge that was protected by the tapes.
3) Insert color cartridge into the right slot, then the black into the left slot. Push up and in until the cartridge clicks into place.
4) Close the front cover. Wait until the printer finishes preparing the new cartridge(s).
Dec 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Video Cameras Logo
42 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
