Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
We have a Kenmore Elite Bottom Freezer Refrigerator. The freezer gasket on one side doesn't seal sometimes. That results in lots of frost on the inside of the freezer. What can we do to keep this from happening?
    Sergeant:
    Champion:
  • 351 Answers
Try a heat gun heat up gasket try to re seat it. or you can use a hair dryer good lock hopethis works for you
Posted on Oct 04, 2010
Kenmore elite refrigerator
You have a sealing issue I'm guessing you have an ice dispenser on the door that is letting in warm air. If not your gaskets need to be replaced
Aug 10, 2013 | Refrigerators
Freezer door does not close all the way
Remove the tray, pull door all the way out and check to see if it is spare. Sometimes the gears jump causeing one side to seal and the other dosent. If that is the issue, use pressure to square door
Aug 19, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Frost buildup at back of bottom freezer department. Refrigerator should be frost free. Freezing impaired.
could be anumber of things happing, is the freezer fan spinning? if not ice will accumulate( also hamper cooling in the refrig section). perhaps a defrost issue, a bad heater or defrost thermostat could also cause, this/ may even just be the door being left open for extendedperiods of time( ie.. overnight, or hte gasket not sealing correctly) leading to a frost build up on rear panel
Jan 27, 2010 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
The freezer freezes up and no air circulates to the refrigerator. The Fan motor is working.
is there frost on the inside back wall in the feezer you have a defrost problem. a bad door gasket will cause the duct from the freezer to fridge to fill with frost so the air cant get to the frige
Dec 25, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Frost forms on top of food in my freezer (top of refrigerator)...even inside sealed bags of items like microwave Stouffer's, etc. Sometimes up to 1/4" thick! No frost on inside of freezer though. ?????
This excess frosting can be caused by leaky door gaskets, frequent door opening, dispenser door not closing good, anywhere air can get in. Gaskets should hold a dollar bill sung all the way around both doors.
Sep 24, 2009 | Amana ABB1927DE Bottom Freezer...
Kitchenaid bottom drawer freezer is making frost or ice flakes inside. Why?
If frost is front towards door then the seal is not sealing well . Use a hair dryer on portion which is not touching cabinet . Also check for split somewhere on gasket & if found , replace gasket . If frost on the rear wall of freezer , then a defrost problem could be starting in which the fridge section would be warming up . However , bottom freezers are known for their gaskets not to seat properly .
Jul 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer compartment ice build-up
too defrost just open the doors for a day with the unit unplugged. as far as why it is frosting up check door seals make sure they are all good and seal it up well and that should take care of it.
Jun 26, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite 596755 - Freezer warm, Ice Melted, then...
did you move it or tip it on its side when these devices are moved sometimes it will create anair pocket in the cooling system after moveing let stand for a few hours before plugging back in.
Jan 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer works but fridge does not cool..please help
Ther are several things that can cause this, one a bad evaparator fan or an defrost problem. Look on the back of the freezer wall and see if there is a lot of frost. If there is then it's a defrost problem and the part most likely is a bad termination thermostat also known as a bi-metal. If there is not a lot of frost, check to see that you have air going to the refrigerator section. If not then it could be the fan.
Aug 30, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
56 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
