Question about Pioneer DJm 400 Professional DJ Mixer
Hi i want to know where the fuse is - Pioneer DJm 400 Professional DJ Mixer
  • 5,603 Answers
Fuse is inside VERY near the input power connector. You are likely wasting time replacing it unless you find the cause why it blew.
Posted on Oct 06, 2010
Why would my iron heart Lainey 212 combo amp combo be blowing fuses?
Because some component in the amp is failing/failed and drawing too much current. The amp needs a repair shop. Poking around without knowing what you're doing can expose you to leather voltage. Don't do it.
Oct 13, 2016 | Laney IRT60H Ironheart Guitar Amplifier...
Something blew during a loud performance and now it produces continual high-freq feedback that can't be controlled.
The speaker may be blown, but if you're getting continual Hi-freq feedback that is not resolved by lowering the volume know, you need to take this to the repair shop.
Apr 28, 2015 | Behringer Ultratone K3000fx 300w Keyboard...
Amp has power ,is getting signal , meter moves when I hit the strings of the bass. but no sound coming out of either cab. ran a line out and it works that way ,
Looks like the power module went out, could be either LM3886T Power IC or Mosfet Module But certainly is in the output stage where your problem is, hope this helps to troubleshoot the issue at least...
Nov 03, 2013 | Behringer Bx4500h Ultrabass 450w Bass...
Hi, I have a mackie srm1801 and in the middle of a gig the OL LED came on and wouldn't go off. Input was unplugged and still the light wouldn't go off. After a while the fuse went and now there is no
It is likely that the O/P transistors have blown, especially if the fuse keeps blowing and the O/L led comes on. It's a repair shop jobbie
Nov 30, 2011 | Mackie SRM 1801
Peavey Pr-15 fuse blown, speaker not working. What is the fuse rating
Actually its pretty funny thing with those speakers is the "fuse" is Actually called a Lamp in this case. These are what they call a " Red Dot Fuse ". in all the years i've been doing this i've never thought to look up the value haha. Just have to know there are Red Dot lamps and Blue dots and No Dot. If you examine the LAMP you should see somewhere close to the ends ON THE GLASS a color dot of some kind. almost like someone painted it on there. Red Dot Lamp. any parts distributer for people like Harbinger, Peavey, and B52 will KNOW what your talking about
Aug 21, 2011 | Peavey PR15 400w PA Speakers
Hi i got the korg pa50sd when i swith it on it shows me korg pa50sd boot loading files then this goes off, still the light on display is on but blank display with nothing on it ,. i was trying to find any...
NOT a fuse... thaat person knows nothing. There is something wrong for sure. Check if one of the buttons or keys MIGHT be stuck down (depressed). Sometimes the units check that all the control buttons are up and they don't really tell you why they fail to start. Beyond this a repair shop is in order.
Jul 11, 2011 | Korg PA50SD Pro 61 Key Keyboard Bundle
Hi, my M-audio Project mix stop to send 48V phantom power, Do you know if had a fuse protector inside? Tks Wallace
A common problem is a person will plug in an unbalanced plug into an input. this often grounds out the 48 volts. Use ONLY balanced lines like XLR and TRS connections. There is NOT likely a fuse inside as the 48 volts have fairly high impedance driving the mic leads... around 6K ohms. Verify that the 48 volt control setting has not been turned off.
Apr 23, 2011 | M-Audio 99104074200 ProjectMix I/O...
Hi, My Peavey Classic 50/50 has power (leds are lit) but the tubes show no sign of life - no output at all and no active lit tubes with the power tubes or the input 12ax's - I have checked the fuses and...
I had checked the fuse for the heater circuit and found that while it was testing on a low ohm check meter - it was not sufficiently handling the
full demand of the circuit - I put a bypass on the fuse and found the problem. The fuse appears to have been previously replaced with
a type not original - the original was a ceramic case fuse 10A.
I appear to be operational
MB
Dec 27, 2009 | Peavey Music
Pioneer DJm 400 Professional DJ Mixer Logo
Top Pioneer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Pioneer Music Expert? Answer questions, earn points and help others
