Question about Samsung SyncMaster 753S 17" CRT Monitor
I didnt get the good dispaly - Samsung SyncMaster 753S 17" CRT Monitor
  • Doctor PC
    Doctor PC Oct 04, 2010
    What are the problem? What you mean good display?
Va703m
This is a common indication that the power supply board has bad filter capacitors. When the capacitors go out the power board can not start up correctly so you get either a white screen, a flashing power light and no display, a flickering display or no power at all. The repair is easy, it just requires replacing the bad capacitors on the power supply board. About 10 minutes and a little soldering and your monitor should be as good as new. Here is a link to a repair kit with the correct parts to do the repair.
http://www.ccl-la.com/catalog/product_info.php?products_id=145
Apr 26, 2013 | ViewSonic VA703mb Monitor
HP E800 PAVILLION WILL NOT POWER ON
If there is not LED glowing in from of the servers, check the power cable is seated in properly. If that is also fine, the problem is with the power module itself. Get it replaced.
If there is LED dispaly and no BIOS screen coming up, Switch off the server and make sure the memory modules are seated properly in DIMM slots.and also the processor and HDD.
If still it didnt come up, better contact the vendor.
Please come back and vote for me if this turns to be helpful for you or also if you need more clarifications. Thnx
Mar 27, 2010 | HP NetServer E800
Phone seems to work, but has a blank screen
i think its display problem.. check the display once... or take a new dispaly
Nov 20, 2009 | Nokia 6300 Cellular Phone
No dispaly
check the lcd connector if ists solid then you may have breaks in the the signal cable see if you can find a replacment cable if not then its a replacement screen and that can be tough to track down
Aug 06, 2009 | HP Pavilion dv6000z Notebook
White display error for some time of perod in omni900 book
change dispaly in control anel dispaly screen resolution to 1024*768
type in run "control"
Jan 01, 2009 | HP Pavilion dv2742se Notebook
My pc laptop screen is shaking
it is dispaly driver problem. uninstall dispaly vga driver thern reinstall it.
when u power up press F8 key then go to enable VGA mode.then check problem same or not.change also your dispaly properties setting resolution to 1024*768
Dec 27, 2008 | Microsoft Windows XP Professional for PC
About Dispaly
have the LCD on the phone replaced.
Jul 19, 2008 | Motorola Mobility RAZR V3
Monitor dispaly problem
I think this problem appear video o/p section.Dry solder Pl. solder video output section
Jun 01, 2008 | LG Computers & Internet
Samsung SyncMaster 753S 17" CRT Monitor Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
