The printer is connected with the laptop thru wireless connection. Its getting detected also. But whenever I try to print a page it goes to the printing Q and does nothing
  • 7,733 Answers
Can you post the printer brand? HP?
Cancel all pending jobs from your print queue. Remove the printer and add it back in from your printer lists.
Of course you can try uninstalling and reinstalling the unit.Of course you can try uninstalling and reinstalling the unit.
Posted on Oct 04, 2010
My printer is not printing showing offline
First thing you need to do is power cycle the printer. If that doesn't fix the problem then restart your PC. If it still shows offline and you used a USB cord to connect to the PC, I would try changing out the USB cord. If it is a wireless printer, then you need to log into your wireless router and see if it shows an IP assigned to the printer. If not then go thru the wireless setup routine for the printer again.
Feb 27, 2018 | PRINTER Office Equipment & Supplies
Printer connected to wifi but won't print
check that the driver for the printer is installed and updated as sometimes the driver can disappear from the system
Feb 27, 2014 | HP DeskJet 3520 InkJet Printer
Wireless toshiba laptop not connecting
You didn't mention your model number for your printer. On your printer, go to settings and print your wireless specifications page. Your printer IP will be there.
You can also have your computer search for your printer!
Oct 15, 2013 | Epson Office Equipment & Supplies
Lexmark X1240 starts to print then stops and job gets stuck in print queue.
If you are printing wireless thru a D-Link adapter, you are going thru too many connections. Let me explain: I have worked on electronics most of my life and the old saying goes, "the more breaks you have in a connection, the more chances you have that something, somewhere in between the breaks, will cause you to have more problems".
Go thru your Uverse directly with a RJ45 or CAT5 cable, if possible. If not, then hard wire it using a USB switch. This allows multiple devices to use the same printer.
Hope this helps.
Apr 25, 2017 | Lexmark X1240 All-In-One InkJet Printer
Wondering what I need to print wirelessly from laptop with this printer
If you printer hasn't a built-in wireless connection and if you haven't a wireless router then -
You need a wireless router plus print server. Connect this print server to the wireless router with a LAN cable. Then the printer is then connected to the print server's printer port.
The laptop's wireless card is then configured with the router's wireless settings.
The laptop is then installed with the printer driver and the printer port needs to be changed/configured with the print server's IP address.
ALTERNATELY
If the printer is connected to a desktop computer on your home LAN and it is also connected to your wireless router. Then you can set this printer as A Shared Printer on your desktop computer, but this desktop computer and the printer has to be powered up for the laptop to print to the printer.
For instruction on setting up a shares network printer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
Nov 16, 2010 | Canon PIXMA MP510 All-In-One InkJet...
Printer works scanner does not
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Scanner:
  • Unplug the Scanner cable from the computer.
  • Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications
  • after installing drivers and software it will ask you to connect the Scanner.
  • then you can connect the Scanner and and try to Scan.
Hope this help. Please Rate My Response! Thanks!
Aug 20, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Wireless printing does not work
For an effective wireless connection, the printer should be connected to one of the LAN ports of a configured wireless router. This way, every pc(mostly laptops with wireless capability) can print to the printer. You will need a wireless adapter for desktop pcs to access any resource made available wirelessly ok. Good luck
Jun 02, 2009 | Canon PIXMA MX850 Multifunction Printer
No wireless detect connection
Hi
Note all changes to be made from wired computer only . Any computer that is phisically connected to the router.
Open the router setup page by typing in your default gateway address( router address) on the web browser
You can get it by
Start -> run -> cmd -> ipconfig
You will see the router setup page opening up
Check what it says . IF on the top it says Internet Status :: Connected then
1. Under wireless you'll see channell and ssid
2. Change channell to 6 or 11 .That gives you the best wireless signal strength . This is the most probable cause .
If you want you can also change the
3. Check your security key
4. And apply changes
5. Now on your wireless laptop go to Control panel ->Network connections -> wireless network connections -> right click -> deleate preffered networks -> refresh netweork list
6. You will find your network there select and connect.
Works great
If Ip status : says not connected
1. restore factory default
2. reconfigure router
3. reconnect
This shoud help and please let me know .
Mar 26, 2009 | Linksys Wireless-G WRT54G Router
Problem in wireless connection.
ok First Didnt say what operating systems you were running 2Have you updated from windows SP2 let me Know ttech
Aug 01, 2007 | HP Photosmart C6100 All-In-One Printer
26 people viewed this question
k24674
jasbo
jasbo
