Question about Frigidaire FRS-26DR7D Side by Side Refrigerator
My evaporator fan motor went out for the 4th time and now the wire short out is there a fuse that I need to change?
    Sergeant:
    Champion:
  • 351 Answers
Mo fuse in refig
Posted on Oct 04, 2010
2003 chevy impala heat/ac not blowing out
First thing to do, is check your fuse box. Look in manual where it is. It normally could be a fuse that has blown. Next step would be wire short going to the fan motor and last step is fan motor went out and needs replacing. Check fuse first.
Apr 07, 2013 | 2006 Chevrolet Impala
WHERE IS THE WIRING HARNESS THAT WOULD CAUSE THE EVAPORATOR FAN TO STOP
I would look for a fuse somewhere. If you've found the board, simply smell the board. One of the few good things about an electrical short (creating the smell), is that the smell sticks with the problem.
Assumptions:
When checking the power to the motor, consider that there is typically a temp sensor that tells it when to kick on and off. If the entire system isn't running, it likely won't ever get to that point, thus no power reading.
Follow the smell.
Also, the good thing about motors is that you can hook up just about any power to it (within reason), and "bump test" it. You'll just bump the power to it, to see if the fan bumps on. Not something you'll want to do for an extended period of time, but it'll serve its purpose.
Sep 02, 2012 | KitchenAid Superba Architect KSCS25INSS...
Kenmore central air conditioning unit tripping breaker each time we turn it on.
The breaker tripping when you turn the unit on indicates a 'direct short' and 99 out of a 100 times the short will be either the outside fan motor or the compressor itself. Either way - you will need a qualified serviceperson to diagnose this problem correctly and make the needed repairs.
Best solution is to call AC person.
However, here's a good way you can get it down to either the fan motor or the compressor.
(1) With all power OFF - disconnect the wires to the fan motor
(2) turn on AC unit (a) if breaker trips it means the compressor is probably the shorted component. (b) if breaker DOES NOT trip and the compressor runs - it means the fan motor is shorted.
(3) If breaker tripped with the fan motor disconnected meaning the compressor is probably shorted you can then (with ALL POWER OFF) 'disconnect the wires going to the compressor' and re-connect the fan motor wires. Turn on power - and if fan motor runs (with compressor wires off) you know it's the compressor that is shorted.
After all this you will now know which of the two (compressor or fan motor) is shorted.
If it's the fan motor you can with 'limited mechanical experience' change the motor yourself, but if it's the compressor you will need to call a serviceperson because of the expertise needed to replace the compressor.
Jun 05, 2011 | Kenmore Heating & Cooling
Cooling fan fuse
most likely the cooling fan has a short in it. disconnect the connector on the fan. If it doesn't blow now its the fan motor. If it still blows you have a short from the fuse to the motor. What this means is the hot wire is touching bare metal somewhere
Jul 17, 2009 | 2002 Pontiac Sunfire
Cooling Fan Fuse
Sounds like a short in the wiring, or a bad fan motor drawing too much current. Check the wiring for shorts, if none are found, replace the fan motor.
Jun 10, 2009 | 2003 Chevrolet Impala
1996 Lumina. Airconditioning fan does not
if it changes tone as the setting is changed it should be getting power , if the fan is not blowing it is the evaporator motor/wiring.
Phil
Jun 09, 2009 | Heating & Cooling
Runs -6far. for about 2 weeks, then alarm sounds, unit is warm.
its the problem of the motor which runs the fan.that motor needs replacement.a very chance it can be possible that the motor is perfect but the wirings from the motor which connects to the fan are faulty and got cut in between.but it can be possible.so first check out the wirings if they r perfect then its faulty fan  motor.get it replaced. thanks.
Feb 10, 2009 | Kenmore Freezers
Fan in the freezer stop working ater a while
You may have a serious issue with the wiring harness inside the refrigerator.  You will need to have the technician come back out and check the continuity of the wires leading from the control board to the fan checked out.  If there is no continuity, it is not repairable.
Mar 13, 2008 | LG LRSC21935 Side by Side Refrigerator
Frigidaire FRS-26DR7D Side by Side Refrigerator Logo
83 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
