Question about Canon PIXMA MP750 All-In-One InkJet Printer
I am getting (scanner error) is any way to reset the printer to factory preset?
  • Canon Master
  • 7,733 Answers
The best way to rid out those issues is to Uninstall / install back.
Posted on Oct 04, 2010
  • 2,973 Answers
Please disconnect, uninstall and then reboot and reinstall the device as per the link below.
http://www.fixya.com/support/r3559995-installing_devices_on_pcs_and_laptops
Scenner error 17 solutation plz help
I have checked for scanner error code 17 and have found nothing.
I would suggest a good cleaning and blowout of the system.
afterwards, I would reset to factory defaults
Hope this works for you
Apr 26, 2014 | HP LaserJet M1005 Printer
My printer has an error with error code E42 how can i fix that? pls help..
E42 I believe is a scanner error. Try first to switch it off for 30 minutes and try. Else re-attach the ribbon cables of the scanner and try again.
If error still persist then do a factory reset as per below
1) Switch off the printer
2) Press and hold the Stop/Reset button while switching on the printer.
3) With the Power LED lit, press the Stop/Reset button two times while pressing and holding the Power button.
4) Release the Power button and the Stop/Reset button that will put the printer in service mode. Just wait for the menu selection.
5) When the LED lights in green, press Stop/Reset button to specified number of time(s)
according to the Legend below.
Legend:
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset procedures below.
5 times Orange Destination setting See Destination setting procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Jul 13, 2011 | Canon PIXMA MP160 All-In-One Printer
Hi have a hitachi c29-f100, how do I reset it
Hello
I'm not sure about what preset option you are asking for. If it is to reset the parentia passcode reset; key in '7777' will reset the set to its factory preset code '0000'. You can reset the passcode afterwards. If you wish to picture, sound etc; to return them to factory preset, select each window, hilight the reset option and pres enter. This will reset the that window settiing to its factory preset. OK.
Jun 27, 2011 | Hitachi 32UDX10S 32" TV
My philips 191EL LED monitor was not functioning the menu buttons but have a display and in use while plug on, however, at below portion of the screen appears the word SmartImage on and SmartImage off. Is...
simply long press input and power touch buttons to reset the ic program and it will be ok be sure to wait 5-10 seconds note: be sure the led has display input and powered on with the problem your encounting thanks ok
Jun 10, 2011 | Philips Computers & Internet
Gives error 51-2Y I already did a cold reset and reset to factory settings it did not help can it be a fuser error? if not does anyone know what it is. I appreciate any response thank you Frank
Did the printer have a rough ride? HP's service manual suggests this to be a laser error on the yellow laser scanner, though these printers usually withstand shipping without any problems. Just for grins, if you can get the printer to get to READY again, run the printer through a complete calibration (from the control panel: Configure Device/Print Quality/Calibrate Now). The DC controller circuit board is also a possibility, but given the error code popped up almost as soon as you plugged the machine in suggests the yellow scanner has suffered some sort of mechanical damage from the trip. If the calibrate routine doesn't remedy the problem and you want to be sure, you could do the major disassembly required and swap the yellow scanner with the scanner for another color in the printer and if the error code changes to 51.2M (magenta), 51.2C (cyan) or 51.2K (black) (the code will reflect which scanner you exchanged with the one in the yellow position) you'll have confirmed the scanner is the problem, or if no change, then the DC controller is next in the chain.
Any further questions feel free to ask.
Dec 05, 2010 | HP LaserJet 4600dn Color Printer
I have three Radio Shack 97s. I have picked up off craigs list. One has the factory preset frecs. I have added additional frecs. This one is my master. The two other 97s. Have had thier presets wiped...
To INITIALIZE your scanner and restore it to the original factory settings:
- Power the scanner OFF.
- Power the scanner ON. "Multi-system Trunking Scanner" will display on the screen
- With the message still showing, press 0 (zero).
- Press 1 (one).
- Press ENT. "Initializing please stand by" will display for about 5 seconds.
- M000 will display on the top line, Bank 0 Ch 000 will display on the third line. Do not power the scanner OFF until this display appears.
NOTE: The INITIALIZE process will erase/delete all information that you have programmed into the scanner and restore its original factory settings.
Need the manual for your PRO-97? You can download and print it, at no cost, here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/PRO-97_OwnersManual_ome20-527.pdf
Bill B.
Listening in since the 60's
Nov 18, 2010 | Radio Shack Pro-97 Handheld Scanner
HP M1522nf printer, shows "scanner error 5"
I have the same problem, could you pl let me know where can I get the stepper motor?
Dec 08, 2008 | Office Equipment & Supplies
Machine error AE on brother MFC 6800
The error is from the scanner. It is possible the scanner lock on the underside of the scanner has shifted and not allowing the scanner to correctly return to the home position. Try Checking the scanner lock and make sure it is not in the locked position. Then turn off and on your machine while holding the menu/set button. the machine will come up either with an error or in maintenance mode. either way enter 99 and see what you get. Maintenance mode is a dangerous place to play around in. 99 exits maintenance mode. 91 resets all parameters to factory setting except stored locations like phone numbers and location information. 01 resets every thing to factory. DO NOT CHANGE ANYTHING IN MAINTENANCE MODE. CCDHP is scanner home position sensor. It will probably reset just by turning the machine off and on.
good luck.
Nov 01, 2008 | Brother MFC 6800 All-In-One Laser Printer
Reset MFC6800 to factory defaults
Hold down MENU/SET while plugging in machine.
You shoule then see MAINTENANCE and some strange 'Y'
press 01 you should see Param Init
then press 99
that should reset every thing
Jan 17, 2008 | Brother MFC 6800 All-In-One Laser Printer
"Scanner Failure" displayed on led panel EVERY time
The solution is at the HP website. see here
Solution five: Reset the product
Step one: Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
Step two: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next solution.
Oct 28, 2007 | HP OfficeJet D135 All-In-One InkJet...
Canon PIXMA MP750 All-In-One InkJet Printer Logo
93 people viewed this question
old marine
old marine
