Question about Samsung Televison & Video
Hi my samsung-ltp468w will not turn on? how do i fix it? currently i have the back taken off the tv
I have a 58 inch Sanyo flat screen TV, I turn it on everything works fine, shuts down in about 10 minutes! Sound stays on though. If I shut it off and turn it back on it does the same thing!
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the... the Sanyo DP47460 that I'm having an issue with. after ~ 40minutes of watching, if I attempt to change the channel or adjust the volume, the picture/screen freezes. ... After ~ 20 seconds, theTV will automatically shut off, then turn back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Hi, I've got a Samsung LED TV that switches off after20 seconds and remains off. .... after about couple of minutes, is this the same problem with the tv in the video? .... 10:32. How to repair a Samsung LCD TV with a flashing standby ...
TV Turns On, Backlight Inverter Immediately Turns Off TV ..
Dec 17, 2015 | Televison & Video
How do i fix a plasma Samsung tv
Tony, need some info for help like model number, age of set, can u unplug for 10 min. then turn back on, and since u have taken back off what have u tested or looked at?
May 04, 2015 | Samsung Televison & Video
My Samsung HL-T5075S TV shuts off after being on for awhile and will not turn back on,also if you turn it off you have to wait awhile before turning it back on, I have tried unplugging it for up to one...
It's the problem of overheating in the power supply board of the TV.on the power supply board of the tv there are few capacitors and IC.any of this IC is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
This will help.
Sep 15, 2011 | Samsung Televison & Video
Hi I have a samsung le32c45oe1w tv which has had the arial connector snapped off the back, The question is can this be fixed easily by replacing the parts behind the back panel, I asume that all the...
TV Parts Universal TV Stands DLP Chips ShopJimmy Order the main board from here. On the back of the TV all the screws with arrows pointing to them have to come out. The back will come off then. get the number off the main board, then go online to order the part. It's easier than replacing a motherboard in a PC.
Jun 26, 2017 | Televison & Video
I got a second samsung blu-ray player, having liked the first one so much. This new one has been just terrible. Presently neither the sound nor the picture will come on my Proview LCD tv, for some reason...
One thing you might want to try is hooking the player up with the Composite (yellow/white/red) output into the TV. If this gives you a picture, then try a different HDMI cable.
Jan 14, 2011 | Samsung BD-P1500 Blu-Ray Player
Hi, I just got my new Samsung 46" LCD 3-D tv
No pictures on all modes? Since it is new I would get it fixed under warranty ASAP, I hope you do not have a lemmon set. Do not open it up or it will void the warranty.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Jan 04, 2011 | Samsung Televison & Video
Hi - My Samsung LNT5271FX 52" LCD TV won't turn on. It just clicks over and over and over, but never turns on. What's up? A relay?
This is a capacitor problem. Several Samsung models have bad capacitors installed on the power supply boards. Samsung currently offers a recall fix for this and other models. Call Samsung direct to see if your TV qualifies for this one time fix. It is a free fix, so if the person on the other end doesn't have a clue, ask to speak to a supervisor or hang up and try again.
Nov 02, 2010 | Televison & Video
My samsung WS32Z306V WONT TURN ON AND JUST HAS A TICKING COMING FROM THE BACK PLEASE HELP
Hi, Sorry this is not a fix but i wanted to say that i have the same problem on my tv which is the same model as yours.
At start tv would show faint parallel diagonal lines until some day it stopped working. Everytime i try to turn it on it doesnt! and makes a ticking sound from the back of the tv. Did you fix yours btw?
Feb 22, 2010 | Samsung WS32Z308P 32" TV
Tv turning on and off by itself - never fully turning on
Most likely failed capacitors in the power supply. I am currently having the same problem with my 26 month old LN46A750. Samsung has agreed to fix this as an out of warranty "courtesy repair".
http://www.thebuzzmedia.com/samsung-tv-capacitor-clicking-issue-and-free-repair/
http://www.avsforum.com/avs-vb/showthread.php?t=1198409
Sep 28, 2009 | Samsung LN46A750 45.9 in. HD-Ready LCD TV
Samsung Rear Projection
Hi.
Im certain I can help you there are basically 2 fixes that spring to mind for this fault.
First fix : RESOLDER IC801S ON POWER PCB.
SEVERAL PINS ARE DRY JOINT NORMALLY.
Try the first fix before attempting the more difficult second fix.
You will need soldering iron with a tip of approx 1.6mm & 0.7mm fluxed solder.
Take notes & pictures of pcb layout plugs & sockets before unpluging anything in side the tv set.
The first fix is easy you just need to find IC801S & resolder all it legs (pins) to the pcb. To find the IC follow the mains input from the switch to the PSU board The IC will be very close.
********** IMPORTANT ENSURE TV IS UNPLUGGED FROM MAINS POWER ********
TV SETS STILL HOLD ELECTRICAL CHARGES EVEN WHEN SWITCHED OFF.
IF YOU ARE NOT CONFIDENT TO UNDERTAKE A REPAIR ON YOUR TV PLEASE GET A QUALIFIED TV TECHICIAN TO DO THE WORK FOR YOU.
Second fix : CHECK R437(1.8 OHM) RESISTOR ON DEFLECTION PCB,
IF O/C CHECK IC501, IC531, IC561 ON CRT BASES FOR SHORT CIRCUIT.
http://dysonmanuals.llc.nu/
Chris..
Dec 30, 2007 | Televison & Video
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
