Question about Kenmore Elite HE4 Electric Dryer
Installing electronic control board in Kenmore (Whirlpool)
I am installing a new electronic control board in my dryer and when I went to hook up the wires to the heater sockets, I cannot remember which one houses the red and black wires. How can I tell which one go where? I have a 50/50 chance of getting it right, but if I guess wrong....
Please help! Thank you so much.
  • adalesp Jun 28, 2008
    i have the same problem , whish is the com cable the red ore black
5 Suggested Answers
  • 159 Answers
SOURCE: Kenmore Elite Oasis Dryer top removal
there should be 2 clips you kind of press and then it should pull off. if not look to see if there is a leg that also go's into the bord if so you need to move it in to reles it from the bord and then it should pull off.
Posted on Aug 10, 2007
codfish124
  • 36 Answers
SOURCE: no heat from he4 kenmore dryer
did you check the outlet got 240 volts? if you did and your not getting that at the heater it could be the board or the motor if the switch in the motor is bad it wont send power have you found the tech sheet? that will give you how to test it but if you think swapping parts is OK then you need to go buy a multimeter so you can find the faulty part
Posted on Dec 09, 2008
SOURCE: need to install a 4-wire/ prong dryer cord strain relief assbly
The green wire attaches to the dryer cabinet. There should be a green screw in the cabinet for attaching the wire. If not, you can always drill a hole for a ground screw.
The loose green wire you see is the reason the code was changed to a 4-wire cord.
Posted on May 06, 2009
  • 744 Answers
SOURCE: Kenmore 70 series gas dryer (Whirlpool model) will not ignite!!!!
>> Do you know where the flame sensor is located? I figure the ignitor is where the "glowing" occurs and the gas line feeds to. Thanks for your help!<<
The flame sensor is right next to the ignitor. Also see this link for what it looks like:
http://www.apwagner.com/index.php?main_page=index&cPath=7_96
Posted on Mar 18, 2010
Kenmore dryer model 11087531701 powers on but will not start. Sends code f-01. What does this code mean? How can we fix this?
The 110.87531701 dryer was manufactured by Whirlpool for the Kenmore label. For Whirlpool dryers, the F-01 code indicates an internal of the main electronic control board (the brain of the dryer). Try unplugging the dryer (or turning it off at the circuit breaker). Wait a while, then plug in the power cord. If the dryer now works, you may have had an electrical surge that needed to be dissipated.
Otherwise, the recommended repair is replacing the control board. Make sure to unplug the dryer before opening the back panel to access the control board. Move one wire at a time from the old board to the same place on the new board. If you have a gentle touch and soldering skills, some have repaired the board by finding the faulty solder joint and fixing it. However, you need to make sure that you remove and replace the wires with care.
See https://www.repairclinic.com/Shop-For-Parts/a8b6d876505/Model-11087531701-Kenmore-Dryer-Parts or http://www.searspartsdirect.com/model-number/11087531701/0582/0151200.html?searchType=modelSearch&q=110.87531701&searchTerm=110.87531701 for a parts list. The control board is part 46 on the cabinet parts diagram at Sears Parts Direct.
I hope this helps.
Jun 29, 2017 | Kenmore Dryers
What is the cost of the machine control electronic system for a kenmore elite model 110.8772?
From Sears Parts Direct, the dryer electronic control board for the 110.87721700, W10339957, is $230.35. The user control, WPW10110646R, is $144.99. I didn't see the control board as in stock at other appliance parts vendors.
Since there are 4 extra digits in the model numbers for Kenmore dryers, please add a comment the full model number of your dryer. I will be glad to check if this is the correct part for your dryer.
I hope this helps.
Oct 29, 2016 | Kenmore Washing Machines
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Elite he3. What does code f01 indicate?
    Be sure to unplug the washer before accessing internal components. When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time. Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer. Reassemble and test the washer.
    Error code on dryer F01 Kenmore Elite HE3 Dryer
    Nov 19, 2015 | Kenmore Dryers
    Whirlpool duet dryer
    -Check your power source. make sure is not over load.
    -Or disconnect main power and open back panel to visual check
    all wire and connector. Possibly shock some where.
    Good luck
    Mai
    Dec 20, 2013 | Dryers
    I get an E1 code on a whirlpool duet dryer. What could the problem be.
    The problem is the control thermistor being detected open by the electronic control. It's either the wire harness connecting the thermistor and electronic control is broken or the connection is loose or the thermistor is indeed open. Measure the resistance of the thermistor then refer to the temperature and resistance table for the normal thermistor resistance values. Click on the link below for the detailed troubleshooting procedure.
    Troubleshooting Error Code E1 on Kenmore Elite and Whirlpool Duet Dryers
    Feb 04, 2011 | Whirlpool GEW9250 Electric Dryer
    Code E1 on Kenmore dryer
    The electronic control detected the thermistor is open. It's either the wire harness connecting the thermistor and electronic control is broken or the connection is loose or the thermistor is indeed open. Measure the resistance of the thermistor then if it reads open or the harness of broken. Refer to the detailed troubleshooting of this error code in the link provided below.
    Troubleshooting of Error Code E1 on Kenmore Elite and Whirlpool Duet Dryers
    Oct 08, 2010 | Kenmore Elite HE4 Electric Dryer
    My dryer shows F 70 on the panel
    For a Whirlpool dryer F70 is an electronic control issue. It can be as simple as the wire came loose off the control in the top console or as complex as both control board and console electronics have failed. Here is what the manufacture says:
    F:70
    F:71
    No
    Communication
    Between
    Electronic
    Assemblies
    F:70 / F:71 flashes when there is no communication between
    the machine control and the console electronics.
    ■ Check console electronics harness connections to the
    machine control.
    ■ Replace the machine control electronics.
    Apr 23, 2010 | Whirlpool Dryers
    My kenmore electronic stove is having a beep with code F1 on the
    Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
    KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
    F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
    KENMORE - 911 Series (General Electric/Roper)
    F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
    KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
    F1-E0 EPROM Error - Electronic Range Control (ERC).
    F1-E1 EPROM Error - Electronic Range Control (ERC).
    F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
    F1-E3 Fuel Type Fail
    Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
    “9” for gas-If code changes again-replace Electronic Range Control (ERC).
    KENMORE - 790 Series Electronic Oven Control (Frigidaire)
    F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
    Runaway Temp = Replace Electronic Oven Control (EOC).
    Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
    Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
    Kenmore Elite HE4 Electric Dryer Logo
    273 people viewed this question
    Top Kenmore Dryers Experts
    Dan Webster
    Dan Webster
    Sal DeAngelo
    Tim Whalen
    Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
