Question about Tatung CLT-L50 15" Flat Panel LCD Monitor
Good evening, i have a problem with my monitor "Tatung L50" since last week the monitor turns on and off intermitently, i have tested changing the video cable and with another pc, but the monitor fails again, what can i do in that case. it's like the monitor tries to hibernate every second.
  • Tatung Master
  • 7,733 Answers
Open your PC and reset the Video Card.
Posted on Oct 05, 2010
White horizental lines across the LCD Monitor.
This is a high voltage horizontal output problem. Could just be a loose connection or an intermitant component failure. If you can get into it, check for any loose connections. Sometimes this can also be caused by a large accumulation of dust. Make sure you unplug it before opening it up.
Apr 04, 2012 | HP LP2465 24" LCD Monitor
My Tatung LD23HL Flat screen will not turn on. Is there a reset? When plugged in the power light blinks Orange.
check the monitor to computer cord, sounds like it might be loose or disconnected. swap another monitor in and go to display properties to see if the tatung is a 2nd monitor. using the replacement monitor redownload the drivers and reinstall. turn off and hook the tatung back and it should recognize it
Oct 09, 2010 | Tatung LD23HL Monitor
Tatung l17amtn lcd monitor
check the desktop and display settings from the control panel,, then from there go to screensaver and power,, make all to never and make your screensaver also to none.. and see
Sep 29, 2009 | Tatung L17AMTN 17" Flat Panel LCD Monitor
Tatung monitor Power light shows yellow light.
It sounds like your resolution or refresh rate is out of reach for your screen.
Restart your computer (even if it will be manually unplugging the power cable)
If you have no display while your computer starts up; you might have a hardware failure. Swapping your screen out, or plugging it into another computer (that works) will confirm if this is the issue.
If you can see the computer starting up you can press F8 (on your keyboard) continuously just before Windows can start.
Select "Safe mode" so that you will have the basics of screen settings.
Now you can go to control panel, display and click on the Settings Tab at the top. Change your settings to a rather default "1024x768" resolution and change your referesh rate to nothing more than 75hz under the advanced icon.
Hope this helps!?
Jul 07, 2009 | Tatung L17AMTN 17" Flat Panel LCD Monitor
Invert imgage shown on 19" CRT tatung monitor
If everything else works, then it could be that the pin arrangement of the 4 terminals of the yoke were reversed. There would be two for the vertical and another two for the horizontal. Inverting on each pair wouold give the results that you have described.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 05, 2008 | Tatung Computers & Internet
TATUNG P42HSMT
Also have a TATUNG P42SMT. Problem is the screen starts to turn green shortly after turning it on, then the screen goes black.
Sep 01, 2008 | Tatung P42HSMT 42 in. HDTV-Ready Plasma...
Brightness problem
try changing all electrolytic caps in the horizontal circuits
Aug 28, 2008 | Boundless Technology Tatung VM 9AF 9" CRT...
TATUNG 30" LCD HDTV MONITOR WILL NOT TURN ON
I found a replacement Scheda power module at you guessed it, not at Toys R Us but rather at www.tvmodulesrus.com for $79. The same module is used in several LCDs, including our PowerSpec 30" LCD sold at Micro Center. It is listed under several numbers at TV Modules R US:
P/N: 6693006610
Model: HOAU242001(A)
Scheda Inverter PWB-0656-03
Nov 28, 2007 | Tatung V30DMTT 29.6 in. LCD Television
How to open up the casing on this monitor.
It is not initially obvious how to access this insides of the monitor Unusually, access is only available through the front of the screen. The stand cannot be removed on this model. You need to pry a screw driver (or two) through the four holes located at the rear base of the monitor and remove the front panel surround. The LCD panel and all electronics can be lifted out after removing four screws.
Oct 03, 2006 | Tatung CLT-L50 15" Flat Panel LCD Monitor
I have a Tatung L50 LCD monitor and need a power cord.
go to computerlogin.com and look for 4-Pin HP Viewsonic LCD AC Adapter 12V 5A 60W or Y_LCD12V5A_4Pin its 12.99 plus s/h 12.99 25 and some change hope this helps.
Aug 16, 2006 | Tatung CLT-L50 15" Flat Panel LCD Monitor
Tatung CLT-L50 15" Flat Panel LCD Monitor Logo
74 people viewed this question
Top Tatung Computers & Internet Experts
David Payne
David Payne
Are you a Tatung Computer and Internet Expert? Answer questions, earn points and help others
