Computer not showing on via monitor
Hello have a gateway desktop computer fsp200 60atv and I tried to add memmory. As soon as I added the memmory the computer went off and ever since when I turn on the computer the monitor isnt coming on - blank monitor but I hear the system on .. the lights showing the HD is on.. inside on the mothermoard I see a blinking red light near the ethernet card...
Please help
    Sergeant:
  • 336 Answers
Memory is Hard and you can destroy your computer if it isn't done properly because of many reasons. I would suggest that you remove the Memory and see if it works again but I must warn you that if you enter your computer without being a technician you may do further harm to your computer. If it works great but if not I will go through the steps of troubleshooting with you.
Hope This Helps
All The Best,
RCF
Posted on May 28, 2008
Hook up a older monitor to my desktop its says no input
By adding a monitor, are you trying to set up a multiple monitor display? If so, you'll have to enable your second monitor after you've connected it using the display settings in your control panel (or by pressing the Windows key + P in windows 7).
Jan 09, 2012 | Gateway Computers & Internet
I have a Gateway Desktop computer, and I have had it for a couple years, and it just wouldn't turn on. So I need to know if that means that computer is dead?
Check for any lights. Usually a computer would have a flea light on the motherboard as soon as you plug it in. If it doesn't have a flea light, start with the power supply. Swap the power cord of the monitor with the power supply of your desktop. If it still would not show power, try replacing the power supply. Worse case, you may need to replace the motherboard of your computer which would cost a lot.
Jun 27, 2011 | Gateway Computers & Internet
Greetings, I have a Gateway 832Gm Media Center PC, I want to add a Radeon HD 5550 graphics card to get the ability to get dual monitor support. My question is do I disable the chipset via the bios or can...
Most likely what you will want to do is just turn your resolution down to it's lowest settings. and turn off unplug the computer and install the card. Plug the monitor into the card and then boot up the computer. Sometimes depending on the computer you may have to disable the onboard video in the bios but a lot of times you don't. If you do run into an issue you can unplug the card hook the monitor back up the onboard video, then if need be disable the onboard driver, by going to control panel, then system properties, then device manager and then under video adapter disable the drivers for the onboard video but it shouldn't be necessary.
Thank you,
Lee
Dec 07, 2010 | Gateway 832GM PC Desktop
Slow flashing blue power lite. Monitor shows no
First when you power up the computer press F8 key then enter in enable vga mode.
If you are able to enter then go to start menu->control panel->display property ->settings.
Change screen resolution to 1024*768 then apply and ok.
But if you are not able to see safe mode and other menu.
Then open cpu cabinet .
Refix RAM memory.
Pull cmos cell from motherboard for 10 minutes.
Reattach all connection harddrive.
Open processor fan and processor remove dust from all parts.
Make sure motherboard is not ground with cabinet.
Remove PCI cards if any.
After all above still same then change RAM then try.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 19, 2009 | Gateway DX4640-UBC01A PC Desktop
Computer does not boot up
Computer has three short beeps as it starts? computer RAM (memory) related issue.
If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
Hope this helps.
Oct 22, 2009 | Gateway GT5404 PC Desktop
My gateway one desktop has no display it is getting power and you can hear it booting up but there is no display at all on the screen
Try another monitor that you know is good. It sounds like your video (on-board or add-on card) has died.
Or take your monitor to someone else's working computer and try it there.
If the monitor works elsewhere, then your video is kaput.
Jun 13, 2009 | Gateway ONE GZ7108 All-in-One Desktop PC
Screen goes off showing VGA with cable on the screen
This looks like a bad cable connection. Try using a new cable for the connection between the computer and monitor. If that does not work test you computer on another monitor to make sure you are getting signal output from the video card.Also check the monitor on another computer.This is to check and make sure the monitor is working properly.You can also try using a add on video card in the computer to see if you can use the monitor this way.If you still are having problems. You can use this web address to get customer from Gateway. http://support.gateway.com/s/PC/R/1013953/1013953nv.shtml. I hope this helps you with your problem.
May 16, 2009 | Gateway GM5259E PC Desktop
Computer not showing anything
Did you check the type of the memory card the motherboard of your computer would support? It may be a DDR1 or DDR2 and also check how much memory your motherboard can hold. You disconnect the memory card and check to see if the computer would turn on.
May 27, 2008 | Gateway 505GR PC Desktop
Computers & Internet Logo
60 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
