Question about Porter Cable Porter-Cable Speed-Bloc Quarter-Sheet Finishing Sander 330
Excessive vibration Model 330 - Porter Cable Porter-Cable Speed-Bloc Quarter-Sheet Finishing Sander 330
  • 10,865 Answers
Hello. When you have excessive vibration you have to replace the four small rubber posts that insulate the upper housing from the vibration of the pad. These are available at portercable.com
Posted on Oct 04, 2010
What causes excessive vibration in 11.5 HP Swisher Trailcutter after hitting a stump?
The most likely cause is a bent blade. If the blades are not reasonably straight and balanced it will cause excessive vibration. I suggest addressing this asap. The excess vibration can cause more serious problems if not fixed.
May 24, 2014 | Swisher 44-Inch 12.5 HP Trailcutter...
Extreme Vibration in my Porter Cable (Rockwell) 330 Sander
I also have had this problem and I found that if I hold the unit tightly and squeeze the plastic housing the RPM's will stabilize as the unit warms up. Best fix is to replace the rubber isolators that prevent vibrations from the motor from reaching the plastic housing. The isolators have become hard through age or very cold temperatures.
I read somewhere that keeping the sander stored in a warm room can also help because when the rubber is very cold it becomes hard.
Oct 07, 2009 | Porter Cable Porter-Cable Speed-Bloc...
Excessive vibration
check for bearings fault,ie open door and lift inner chrome drum up and down if you feel a knocking feeling or you ear this then its the bearings
Jul 06, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Excessive vibration since moving--not before
is the place you moved the washing machine level are the legs level if so you have a blocked sump
Jun 24, 2009 | Washing Machines
I HAVE A PORTER CABLE 330 SANDER, IT VIBRATES SO MUCH IT IS UNCOMFOORTABLE TO HOLD. IF I REPLACE THE RUBBER POSTS WILL THIS SOLVE THE PROBLEM? IS IT SOMETHING ELSE?
Not sure if this will work for you, but I had the same problem with my 330, it vibrated so much it felt like I was being electrocuted. I took the four screws holding the pad off and blew compressed air inside the sander to remove all the sawdust. Screwed the pad back on and now it works fine. Mine was only 5 years old with very little use.
Apr 20, 2009 | Air Tools & Compressors
Excessive vibration on spin cycle
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you hav removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 05, 2009 | Washing Machines
Excess vibration
Remove the 4 sander plate screws being carefull not to strip them. Look at the plastic ******** extentions attached/flooting to the houseing and look for broken or bent arms on them ,replace with new ones, this should solve your problem.
Mar 19, 2009 | Porter Cable Cable 0330 Speed - Bloc...
Excessive vibration on spin cycle.
Front loaders are prone to vibration problems. Don't want to go into the technical details of why, but it's important that they're placed on very solid surface (preferably concrete or tile), and checked that their feet have been adjusted so that the machine is level. Unfortunately, most people don't have a concrete pad for their washer. One simple option to consider is to provide dampening of the vibrations. This can be done very simply as this one fellow demonstrates. The main thing to keep in mind with this solution is that it is merely trying to dampen the vibrations. Don't be too forceful in your own solution (think lightly touching the top of a vibrating tuning fork with your finger to stop the tone).
Mar 12, 2009 | Bosch Washing Machines
80 Series top loader excessive vibration and noise on spin
check the screw feet, on the front corners, one may be not screwed down far enough to be 'tight' to the floor allowing a small movement that makes a lot of noise, halting under pressure suggests this is the case
May 26, 2008 | Kenmore 24032\24036 Top Load Washer
Porter Cable Porter-Cable Speed-Bloc Quarter-Sheet Finishing Sander 330 Logo
198 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
