Question about Kodak EasyShare V1003 Digital Camera
V1003 Both of my v1003 will not turn on. i have charged the battery. the newest one is only 3 months old. what should i do?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey eah226,
I would first make sure the battery is inserted correctly, and if this isn't the problem I would remove the batteries and try plugging the camera in with the ac adapter and see if the camera turns on with it plugged into the wall. If the camera does turn on this way I would try cleaning the battery contacts with an eraser. If none of this works I would have the cameras looked at by an authorized service technician such as bringing them in to a Geek Squad® precinct at a Best Buy™ store and they can send it out for service. The 3 month old camera is still covered by the manufacturers' warranty and any repair would most likely be free. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on May 28, 2008
Kodak Easyshare V1003 will not charge I have had it plugged in all day
The rechargeable battery will more than likely need to be replaced, if it won't charge it is time to replace the battery.
Mar 17, 2011 | Kodak EasyShare V1003 Digital Camera
My camera wont charge
have you check the charger? or is there a power on the outlet? try to charge it from different power source
May 25, 2010 | Kodak EasyShare V1003 Digital Camera
My Sony VSC 1 camera is not turning on!!!! The charge went out and the camera turned off. After that it's not turning on. What do I do?
1. Please make sure that you're using the fully charged battery.
2. Try resetting the Camera. To reset the Camera, remove the battery from the Camera, press and hold the Power button for 30 seconds and then, reinsert the battery.
3. Please make sure that you're using the compatible battery with the Camera.
4. You may also try using a different battery to check whether the issue is with the battery.
Feb 17, 2010 | Kodak EasyShare V1003 Digital Camera
Will not turn on
Here are the steps for your V1003 no power problems: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Feb 04, 2010 | Kodak EasyShare V1003 Digital Camera
Every time I turn the camera on, it takes 2 to 3 minutes to come on and always makes me verify date and time. Why?
This usually indicates that your rechargeable Li-Ion battery is starting to lose its ability to retain adequate charge due to age and usage (about 500 charges or 18 months of 'normal' use). Try putting a new rechargeable Li-Ion battery.
Hope it helps!
Jan 16, 2010 | Kodak EasyShare V1003 Digital Camera
Easy Share V1003 Turns on, then shuts down.
Make sure that you are installing a fresh/ full charge battery
Remove the memory card and the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Aug 23, 2009 | Kodak EasyShare V1003 Digital Camera
Can I charge my v1003 camera in Germany?
Yes that is correct you can use a plug adapter to charge it,,,
Aug 07, 2009 | Kodak EasyShare V1003 Digital Camera
I turn camera on. Lens comes out. beep 3 times. turns off.
Everytime I try to turn it on, the lens comes out for about a second, the camera beeps 3 times, the lens retracts and the camera shuts off. The battery is completely charged and the camera is only 4 months old. HELPP :(
Jun 17, 2009 | Samsung Digimax S500 Digital Camera
V1003 cannot hold a charge!
your camera might require a new main board to solve this issue. repairs can run from 80.00 and up. goto digitalcamrepair.com for more help.
Nov 17, 2008 | Kodak EasyShare V1003 Digital Camera
Kodak EasyShare V1003 Digital Camera Logo
55 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
