Question about Eureka Uno 2998AZ Bagless Upright Vacuum
Hi i am trying to find a manual for my eureka power paw model 8852..but have hand no luck finding out where you can get one..any where you know of i am in great falls, mt
  • 694 Answers
You can download the owners manual from below site. About midway down the page, click on "Owner's Guide" tab. Right click on "Owner's Guide" and left click "Save Target As". Save to a file dedicated to your Vacuum.
http://www.eureka.com/CapturePlus-Pet-Lover-8852DVZ-upright-vacuum
Posted on Oct 05, 2010
I took apart my Eureka 71B hand held vacuum and a small spring fell out. I don't know where it goes and can't find a manual anywhere. Help?
Lonny,
I have a 71-B2 model myself and if you can take a picture of the spring, I can try to take mine apart and see if I can figure out where your spring goes and get back with you.
Aug 09, 2015 | Eureka 71B Easy Clean Hand Vacuum Yellow
Eureka Model 8852 bvz belt for beater bar belt is broke
You need to replace it. Here is a link to the belt you need and the manual which has instructions:
Eureka 8852 Belt
Owner's Guide (1.36 MB download)
Dec 17, 2009 | Eureka Uno 2998AZ Bagless Upright Vacuum
I have the Eureka bagless with the claw. I need a
A manual for this machine can be sent to you from Eureka. Here is a phone number. 1-800-800-8975. That should get you help for a manual and they can send you the accessaries that you are missing. Also the manual will give directions on cleaning your filters.
Dec 03, 2009 | Eureka Vacuums
The power paw on my vacuum machine is not working.Eureka ez kleen
The filter is not the reason it's not working. Take out screws and open Power Paw, remove fur from the roller brush on the right side, there is a small gap where fur winds around tightly, cut off with scissors or pull out with a small toothpick.
Oct 18, 2009 | Eureka Vacuums
I have a eureka power paw that keeps breaking belts. there doesnt seem to be a part that keeps the belt in place
Make sure the roller and turbine bushings are clear of obstructions (hair, etc) and spin without excess resistance. As for a lack of barrier or belt guide, make sure that the bushing blocks on either end of the roller (and turbine, but most importantly the roller) are installed identical to each other (otherwise the roller may be in on an angle causing the belt to mis-track). Possibly a part may be missing or improperly installed, but not likely. What's important to remember is Eureka (Electrolux Homecare Products) designed the Power Paw as a cheap, quick source of income to add onto their uprights to cash into the ever-lucrative market of pet owners dealing with pet hair. Like their upright vacuums, Eureka/lux know extremely well the importance of designing their product with a very FINITE life-expectancy, and hence expecting this product to be anything of a long-term or durable solution is evidence only of you having been mislead by marketing. Of all the turbine-driven tools in use today, this one is the most inexpensive, disposable I've had the pleasure of working with. I got one free when they hit the scene. I took it back to work still in the package after seeing its track record evolve.
Long-term solution if you love these turbine-type tools? (and you should, they're great and solve major issues. I own several different ones and am very attached to them as attachments!). Go to a vacuum store and find a robust, long-life version of what these little things are trying to be. They're in a higher dollar-range, but so's a Power Paw if you start replacing it every few months. Ask for one made by Wessel-Werk. German engineering, been around for decades. The made-in-china knock-offs are better than the power paw, but if you're up for it, the actual tool made by Wessel is the benchmark by miles. The only thing possibly comparable in long-term quality and durability is called a RugRat by guys in our industry, and sold by Vacuflo and Kirby and such for decades and decades now. Most vacuum vendors should be able to hook you up. :)
Jul 12, 2009 | Eureka Vacuums
Spring connecting height adjustment
There should be a place easily for the wheel assy to fit back in and then if you look you should see 2 small holes in the bottom of the vacuum that it will slip into. If your looking at the vacuum straight they should be on the left side on the bottom.
Nov 14, 2008 | Vacuums
Eureka 2971 vacuum
The duster on this unit is just that a duster the holder for it is to vacuum it off when your not using it it doesn't have anything to do with the vacuum cleaner really. As for the power pawl it is a air driven upholstery nozzle the suction air passes through a turbine which in turn spins the brush agitating whatever it is your cleaning ie. sofa,steps. Simply attach it to the end of the hose and your off just be sure to try and clean any hair or debris for the unit it will not work if the air flow is cut off. For any questions or parts for this unit or any other visit www.stevessewandvac.com
Jul 30, 2008 | Eureka 2971AV EZ Kleen Bagless Upright...
Eureka Altima Vacuum Cleaner w/Power Paw
The way I resolved the problem was to remove the cover at the end of the power paw. Then remove the so side black covers for the shaft. Remove any debris and hair and then put back together. This solved my problem.
Jan 06, 2008 | Eureka Vacuums
Eureka Uno 2998AZ Bagless Upright Vacuum Logo
227 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
