Setup belkin wireless network - Computers & Internet
  • 1,183 Answers
1.Connect a Cat5 cable into the Ethernet port on the back of your cable or DSL modem. Plug the other end of the cable into the "Connect to Modem Internet/WAN" port on the back of the Belkin Router.
2.Connect a Cat5 cable into the "Ethernet" port on the back of any desktop or stationary computers and then plug the other end of the cable into one of the LAN ports on the back of the Belkin Router. Start with port one and work your way up with subsequent computer connections.
3.Turn the Belkin Router on by plugging the router into a power outlet. Allow 30 seconds for the router to fully boot up. All computers tethered to the modem via a Cat5 cable have access to the Internet.
4.Open the Wi-Fi Wizard on your laptop and turn on the Wi-Fi antenna. Once turned on, the Wizard finds all network connections in your area. Connect to your network to establish an Internet connection. Complete this step for each computer not tethered to the Belkin Router with a Cat5 cable.
Thanks for using Fixya
Proton
Posted on Oct 04, 2010
Belkin n50 setup as wireless access point
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings to protect your wireless network and Internet from unauthorized access. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Feb 03, 2013 | Belkin Computers & Internet
Can i setup the belkin f7d4302 as a wireless bridge
belkin does not support this. The only way you can do it is by running a cable to the router to extend your wireless signal around the house. I did a similar setup with a powerline network adapter if running a cat5 cable is not a option. just make sure you change the main ip address for the 2nd router to like 192.168.2.2 and disable dhcp since the main router will handle dhcp. also make sure the wireless settings are the same and channel is different if 1st router is channel 1 then use channel 6 or 11 for the 2nd router.
Feb 26, 2012 | Belkin Wireless Play Router (F7D4302)
How do I set up a security password
Here's a video on how I did it on my F9K1003V1.
Aug 09, 2011 | Belkin Basic Wireless Router
We have a belkin.49ed router and hooked it up. It
The wireless security of the Belkin must have been enabled. Use a computer wired to the router to access the setup page and get the network key.
In the address bar of your browser, type 192.168.2.1.
By default, leave the password blank.
Once on the setup page of the router, go to Wireless -> Security. You will see the network key here.
On your laptop, view the available wireless networks and you should see your wireless network name or SSID, then when you click connect you have to enter the network key.
I hope this helps!
Jul 18, 2010 | Belkin Wireless Share Router (F7D3302)
Wireless connection to belkin g router model no. f5d7230-4
You need to access the setup page of the router using connected computer.
In your browser's address bar, type 192.168.2.1.
On the Belkin setup page, go to Wireless.
Take note of the SSID. This is the name of your wireless connection.
Then go to Security under Wireless. Copy the network key.
On your friend's laptop, view the available wireless networks, you should see the SSID, then just enter the network key.
I hope this helps!
May 18, 2010 | Belkin (F5D7230-4) Router (587009)
We formerly used a linskys router, How can we
if you have not changed any settings from belkin router, access the wireless configuration on your windows machine and search for the belkin ssid then hit on connect
Sep 23, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Cannot connect to belkin N1 wireless router
It seems like your router is configured once without any issues. Ignore that error message if you are connected with the internet. The setup couldnt find the Network adapter or the router because it is know more a factory default settings. It is been configured already
Apr 03, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin N Wireless Router doesn't connect to Modem
If router is brand new you should have a set up disk. the set up disk will walk you through it or you might log onto Belkin site to see a walk through set up. If you can access internet from modem to router to internet. That means router is functioning properly. To go completely wireless you will need to secure your network and setup your access codes. Definitely use the setup disk to do this. A unsecured wireless network is a nightmare waiting to happen. Good luck
Sep 01, 2008 | Belkin Modem connector (R6G064-R-50)
Wireless Acquire network address problem
belkin has a wizard to help you with the wireless setup.
maybe you have a security option turned on. check the router for security options.
make sure its on disable security to check the wireless part also check to see if the wireless option is turned on.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Jun 25, 2008 | Computers & Internet
Computers & Internet Logo
129 people viewed this question
David Payne
David Payne
