Question about HP Office Equipment & Supplies
My girlfriend has a HP printer and a cartridge error occured. the cartridge doesnt expire until oct 2011. There is still ink in it so its not empty. She took the black ink out and now it will work with just the colored ink. is there something else she has to do besides just replacing the black cartridge?
  • HP Master
  • 13,433 Answers
Hi
to norrow down the problem, if possible test another black cartridge on the printer and see if the black ink prints, if it does not, check the cartridge carrier, is there wet black ink below the black cartridge area? the nozzles are most likely blocked, and the ink is unable to reach the paper.
If it works fine with another cartridge, then make sure that the problem cartridges contacts are clean, you might want to try to loosen up the ink by soaking the bottom portion of the cartridge for a minute or two in warm water. This can only be done on printer cartridges that have a copper portion on the bottom.
let me know the results.
Posted on Oct 04, 2010
  • Ekse Oct 04, 2010
    if you got a special error message from the printer post me the brand and model of the printer and the full error message.
Printer error message
Is this an OEM ink jet cartridge -meaning was it made by HP and not a refill. There is a microchip on the ink cartridge that the printer logs how many times it has used that cartridge and how many times the print head is cleaned. If this chip gets dirty or if the mating side has ink or paper dust on that side you can clean it with isopropyl alcohol. If it was a refill or a generic cartridge the chip might not be programmed or it is dead. There is no sensor that detects how much ink is in a cartridge.
Mar 29, 2014 | HP Office Equipment & Supplies
Ink system failure....error code 0xc19a0013....what is this error code and how do i clear it....
What is HP Printer Error 0xc19a0013 & How to Solve the Error ? 0xc19a0013 ink system failure error shows in the control panel of printer.
Reason of occurring this error message is listed below:
  • HP printer setup may not be installed properly.
  • Printer cartridges low message.
  • Printer cartridge is damage or not inserted properly.
How to Solve "0xc19a0013" Error Code for HP Printer
  • Change low or empty cartridges: in case ink alert message is display before this message. Changing the cartridges may solve the issue.
  • Make sure the printer cartridge is installed or inserted correctly
  • Remove the printer cartridge and reinstall that.
  • Use HP Printer Automatic Cleaning Utility to Printheads:In case the error message is occurring ,use automatic cleaning utility of printer for printhead cleanup
  • Update the Printer Drivers :It may happens due to outdated printer drivers. We recommend you this to update your HP printer drivers on regular bases for smooth and flawless printing
In case your HP printer still display the error message best option is to dial HP Printer technical support Phone number-1-800-436-0509 (US), +44-800-078-6054 (UK), +61-1800-769-903 (AUS)
1 800 436 0509 HP Printer Technical Support Phone Number
Jan 04, 2011 | HP Officejet 6500 Wireless All-in-One...
The ink cartridges keep expiring and they are nearly all full .my machine is a hp photo smart 3310 all in one.How do i by pass the expiry dates on cartridges
Each ink cartridge has an expiration date to protect the printing system and ensure good ink quality. The cartridge expire date appears on line 53 of the self test report.Printing can continue without replacing the ink cartridge. Follow the instructions that appear on the HP product or on the computer. However, HP recommends replacing the expired ink cartridges. HP cannot guarantee the quality or reliability of expired ink cartridges. Service or repairs required as a result of using expired ink are not covered under warranty
As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. Reset the product
  1. Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ).
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button .
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Dec 16, 2010 | Office Equipment & Supplies
I refilled HP 88 cartridge but printer (Officejet Pro L7590) still thinks cartridge is empty. How do I reset ink level?
Under the cartridge is a black like pump - on a new cartridge this is hard and rests firmly on an area inside your printer. As you print, the pump becomes softer - this is how the printer determines it is empty. Once refilled, the pump does not get back to the original state. Open the bottom of the cartridge and put a firm solid piece of folded paper in there - make sure it is steady and re-close cartridge. It will now read as full but may also show full - judge ink levels by the quality of print. Also make sure chip has not expired.
Nov 05, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
New ink cartridge won't print
Do you know for sure the original cartridge was empty? Take a clean pencil with eraser, and gently "erase" the electrical contacts on the cartridge and the printer where the 2 connect. See if that helps. If it is USB, unplug it and plug it back in. You might try to uninstall and reinstall the driver for the printer.
Aug 26, 2009 | HP Photosmart C6180 All-In-One InkJet...
Brand new yellow ink cartridges are always read as empty
We have a step by step solution posted on our we site at: www.ccl-la.com/HP.htm The problem is air in the ink lines and the guide helps you purge the air from the system and restore printing.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 27, 2009 | HP Photosmart C6180 All-In-One InkJet...
Won't Print After Changing Ink Cartridge
Did you pull the plastic tape off of the cartridge?
Jan 29, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Officejet 9110 empty or expired cartridge error
You were a bit vague in your report as to what the exact error is that you are plagued with. Perhaps you have more than one. The 9100’s ink cartridges are “smart cartridges.” They each have a chip in them that reports various cartridge statuses directly to the printer. Diagnosing the problem correctly requires the identification of the particular error message. You can find a list of the error messages and what they mean here:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=376170&prodTypeId=18972&prodSeriesId=376170&objectID=c00067620
I think that you are experiencing an “INK CARTRIDGE EXPIRED” error. This error is not related to the ‘volume’ of the ink within the cartridge(s) but rather to the actual expiration ‘date(s)’ on the cartridge(s). The expiration date is encoded on the chip that resides on the cartridge. The actual expiration date appears to relate to the date two years after the date that is stamped on the cartridge label. I can’t change the expiration date on the chip—at least not easily or inexpensively—but I have discovered a way around it.
The date on the cartridge corresponds to the date on the printer itself. You just need to send the printer back in time to a period before the expiration date and you should be able to print again. A time machine is probably out of the question. Instead, reset the date on the printer to reflect a suitable date.
This could conceivably have some negative consequences that I haven’t experienced yet. I’ve only just discovered this ‘hack’. Though I haven’t tested it, the newly assigned, incorrect date will probably appear on any subsequently received fax transmissions. I can also conceive of networking issues if your printer is networked. Some network related instructions require that all network nodes (all devices on the network—computers, printers, etc.) report a time (and date) within just a few minutes of each other to communicate. You’ll just have to try it in your network and see if everything functions properly or within acceptable limits.
To change the date on the 9100 printer, you’ll need to access the ‘Maintenance’ menu. Just below the LCD panel on the front of the printer there are a series of buttons as follows:
[Return], [Up] & [Down], [Accept], [Left], and [Right]. They each have their own unique symbol, but I’m sure you can understand my descriptions. Press and hold BOTH, the [Up] and the [Down] buttons at the same time while you press and release the [Accept] button—then release the other two buttons. If you weren’t taken directly to the ‘Maintenance’ menu (# 10), then use the [Up] or [Down] arrow button to navigate to it and then choose the [Accept] button to select it. Similarly select the ‘Set date and time’ option, and follow the prompts to make the necessary changes using the appropriate buttons.
Once you have changed the date and time you may have to turn the printer off and then back on again before the printer will recognize the cartridge(s). In my case, the printer went through an extensive print head alignment.
Jan 27, 2009 | HP Officejet 9110 All-In-One InkJet...
How to reconfigure ink cartridge
Change your system date to backward and you can use it again
Oct 23, 2008 | HP Business Inkjet 1000 - Printer - colour...
"Expired color cartridge" message blocks black printing - nothing works
Hello merelU. I'm afraid you may have to replace the empty color cartridge as there may be problems with the printer while an expired cartridge is installed on the printer (even though some of the cartridges are still under warranty) and also, HP cannot guarantee the quality or reliability of expired ink cartridges.
all the best.
thx
Oct 07, 2008 | HP Photosmart 3310 Printer
26 people viewed this question
Seeker5211
Seeker5211
