Question about Grilling
When I turn the on the first burner will light and flame are OK, but lighting the next burner the flame goes down to a point that you can barely see the flame. It appears that the gas get reduce to have a big flame on all burners.
    Problem Solver:
  • 5 Answers
Sounds to me like your other burner isn't getting the same amount of gas flow. what you need to do is give your grille a good cleaning and check the lines for any leaks. you will always smell gas so it will be hard to tell by smell alone. Test your lines by wrapping them tight with foil or something removable and turn your grille on to see if the flame gets bigger.
Posted on Oct 05, 2010
I light the first burner and the flame doesnt seem as big as it should be, I light the second burner and the flame goes down slightly, I light the third burner and it goes out completely
clean all the burners and the orffices , check the gas is full if lpg ,check gas line is not blocked , if this natgas grill check connection is in tight and not loose giving small flow of gas.
Aug 28, 2011 | Grilling
At 300F after half hour, pilot and main gas burner was going off. When re-lit would stay on only 5 minutes thereafter. Had the thermopile changed(bought locally- not original from Imperial but identical),...
Hi there.
The thermostat will only shut down burner flame but not pilot flame.
Try tightening all wiring connections.
By using an ohm meter, check the continuity across the hi limit terminals when the pilot goes off, your hi limit may be tripping prematurely causing pilot flame to shut down.
Regards.
Jul 29, 2011 | Kitchen Appliances - Others
Gas stove burner will not turn on
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 29, 2010 | Gaggenau 23 in. KG 260 Gas Cooktop
New propane tank won't ignite
The regulator on the on the hose is either gone bad, or could have got a little bit of dirt in it. You could tap the side of the regulator gently and sometimes this will solve it.
Apr 11, 2010 | Char-Broil Designer 463261106 Grill
Not enough gas/flame.
You probably have water in the burners. If you can get one burner to light, let it warm up the grill and maybe it will dry out the others.
Apr 07, 2010 | Char-Broil Advantage 463453306
Pilots lites , holds ok for minutes,but once move
Hello KJGreen, It sounds, based on your description, as though the thermocouple is faulty and should be replaced. If the pilot light stays lit and you've left it on for several minutes before turning the knob on to light the log set, then that indicates that the thermocouple is bad.
The thermocouple is a safety device (heat sensor) designed to stop the flow of gas to the burner in the event the gas flame goes out and the pilot goes out. The sensor will only allow the gas valve to open once it has reached the preset temperature.
To confirm that the thermocouple is defective, I would light the pilot light and allow it to remain lit for up to 10 minutes before I attempted to turn on the log burner. If, after 10 minutes, the log burner still won't stay lit, then you know that the thermocouple needs to be replaced. Otherwise, the burner should light, since after 10 minutes, the sensor should be hot enough to signal the gas valve to open.
If you are going to have this replaced, please make sure you use only an approved supplier, since an incorrect replacement part could cause an unwelcome malfunction of the gas log burner. Safety should be primary when dealing with open flame burners.
Hope you find this Very Helpful and best regards!
Nov 23, 2009 | Vanguard International Infra Red - Large...
Viking oven only one burner will light
http://www.vikingrange.com/MEDIA_CustomProductCatalog/m20127_f20254.pdf
Go to this web site. It has a manual on Viking ovens.
Usually, when the set temp is reached, the flame will cycle down to what is called "Minimum Blaze". This is to put heat into the unit at the rate that it leaves the unit. It helps to hold temp rather than cycle off and on. It cycles high when temp goes below set and then cycles down when set temp is reached.
Jul 09, 2009 | Refrigerators
When lighting one of the burners, the ingnition knob has to be held down over ten seconds for the flame to stay lit when the knob is released..
Lift the top of the Stove up.
Look for a Small line that goes to the Affected Burner.
At the end of that Line you will see a small Flathead Screw.
Turning That screw Clockwise Adjusts your Pilot Light for that Burner.
Be careful not to Adjust to High, it would just be a Waist of gas.
hope that helped.
May 20, 2009 | Gaggenau 11 in. VG 232 Gas Cooktop
Grilling Logo
98 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
