Question about Kitchen Ranges
Washer won't drian - Kitchen Ranges
  • Kitchen Ranges Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Oct 04, 2010
Washer not drianing the on light is flashing 5 times then stops for 10 seconds then flashes 5 times again
Troubleshooting Why the Washer Won't Drain ' PartSelect ...
? 4:19
www.youtube.com/watch?v=PMrqIkM35HM
Nov 25, 2011 - Uploaded by PartSelect In this video you'll learn what causes washers not to drain. Remember, parts are specific to your model and ...
Aug 06, 2015 | Washing Machines
Whirlpool washer WTW5510VQO will fill, spin and drian but won't agitate, just makes a clicking noise.
If this is just clicking then the agitator bearings stuck or something is jamming it.
Jun 05, 2012 | Whirlpool Washing Machines
Washing machine won't drain completely or finish the rinse cycle
Hi the pump drian unit needs to be replaced, this solve your problem..
Jun 06, 2011 | Fisher and Paykel GWL11 Top Load Washer
My Kenmore elite 40512900 stays at 7 minutes
well often when it hits the last ten min of a cycle it is trying to drian more times then not it isnt or it hasnt senced it has drianed so odds are that your drian pump not drianing or you have a bad pressure switch. i would start with the drain pump often it has a filter that get clogged and can be gottin to from the front
Jun 02, 2010 | Kenmore Elite 45986 Front Load Washer
Washing will not hold water. it fills and agitates while it slowly drains
check the drian hose to see if it is to fare down the drian often it only needs to be six inches if any more it will sifion its self out
Jan 23, 2010 | GE 3.2 cu. ft. Washer
The washer was one last rinse and stop did't drain?
Generally a bad drain pump or a clogged drain pump or drain hose. Have a look and let me know what you find.
Benjamin
Aug 09, 2009 | Whirlpool 4.0 Cu. Ft. Plus Washer
Zanussi washer washers,drians but will not spin
The transmission is belt driven so carbon brushes cannot be the issue. most likely it is a slipping or loose belt remove lower rear panel and check belt tension also check condition of the belt. In order to shift into spin there is a solonoid that activates the transmission you should be able to hear it click. if it just hums it may need replacment.
May 15, 2009 | Zanussi Washing Machines
Pegasus Push Button Drain leaks when you push the button
REMOVE THE LOCKNUT AND CHECK FOR A CRACK OR PIN HOLE IN DOWN DRIAN USE A FLASH LITE IN DRIAN TURN OFF ALL LITES TO CHECK PUT LITE IN DRAIN AND CK FOR LITE IN THE DRIAN PIPE
Mar 09, 2009 | Plumbing
Halp
Hello it could be your lint filter or a hose is blocked by an object. May be even in the pump. Had a similar problem with our Maytag. Cheers.
Mar 08, 2008 | Washing Machines
Kitchen Ranges Logo
113 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
