Question about Whirlpool Ovens
I have a Whirlpool self cleaning oven. I'm E1 -FS- error message after I tried to self clean it. It will not unlock
4 Suggested Answers
SOURCE: E1 F5 Error on Whirlpool Accubake Oven
The lock latch is located directly in the center upper portion of the door. It is a hook shaped latch that lock by turning downward. This lock gets stuck in this position which causes the e1 f5 error code. Locate the latch through the vent holes in the upper front of the oven door. Insert flat headed srew driver into vent hole and gently push latch up to a horizontal position & simply open door. Once unlocked, push cancel on the control panel.This will clear the error code and resolve the issue.
Posted on Nov 07, 2009
blueextc3221
  • 15935 Answers
SOURCE: KEMORE OVEN SELF CLEANING
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
blueextc3221
  • 15935 Answers
SOURCE: E1 F5 error message when try to activate the self clean
My oven has an error E1 F5. It was working fine until I tried to use the self cleaner. Now the oven and self cleaner will not work . Only beeps when I try to cut it on.
Hey I found your manual and error codes on-line and was surprised that Whirlpool did not have it hard to reach. Click Here=> Whirlpool 30 in Self-Cleaning Freestanding Electric Range Error Codes
Have questions please ask and rate this solution, Thanks Sea Breeze sea_breeze_128.jpg
or greater.
Error codes are on page 61 section 5-1
Please Rate This Solution, Thank You! Sea Breeze
Mar 27, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Trying to selfclean oven and getting error code E1 F5. What does that mean?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Feb 20, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool Gold Self-Cleaning Oven Error Message: E1 F5. What does it mean and can I fix it?
E1-F5 means the self clean latch will not lock.
Try pressing down any key and hold for 1 minute, see if this clears it. If not you will most likely need the latch switch replacing.
Dec 20, 2010 | Ovens
Self cleaning oven
Hello, check door switch,contact should be closed when plunger is actuated.check door circuit for open.
Thanks
May 27, 2010 | Whirlpool GBS307PDS Electric Single Oven
Trying to get gas self clean/oven to start. Getting error E1 F5.
E1 F5 is bad door lock assembly. Only way to repair is to replace the locking assembly completly. Sorry. Hope this helps.
Mar 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I did a self-clean session and the oven remained locked way after it completed the cleaning. The error message on the backsplash reads E1- F5-. I am not able to open the oven. What's wrong?
I hit the cleaning button instead of the broiler and the oven lock went in mode so now it thinks it is cleaning but I can't close it and it won't shut off the cleaning mode. What can I do?
Sep 05, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Apr 07, 2009 | Ovens
I used the self cleaning oven and now it wont unlock and it keeps beeping f5, e1 what does this mean and how can i unlock the oven?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&URTGF
Mar 27, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Dec 07, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Ovens Logo
1,549 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
