Question about Epson Stylus NX400 InkJet Printer
I have a NX 400 and replaced the ink with Epson cartridges but now the pages have white lines across the page .I have replced the ink many times before and this has never happened . Thank You , Don
    Brigadier General:
  • 4,088 Answers
The print head appears to have plugged ink jets in several positions or maybe the ribbon cable to the head is damaged in some way. Try cleaning the print head from the software. If no help, try cleaning the head face with rubbing alcohol. Beyond this, you may need professional help. Hope this helps!
Posted on Oct 05, 2010
Cant get rid of horizontal lines on my prinying pages,ive tried re a lignment but doesnt work
Hi
If a single inkjet in your printer is not functioning then output will appear as a horizontal line across the page. If one of the jets is on all of the time then output will have black or colored lines across the page. Use the following steps to isolate the problem:
- Replace the ink cartridge
- Check the flexible cabling for continuity and for short circuits between adjacent conductors
- Exchange the control board for a good one
- Finally check the power supply
Good Luck
Mar 09, 2011 | Epson Stylus 880 InkJet Color Printer
Ive just installed new ink cartridges in my epson stylus nx 115 printer and the print is irregular. It worked fine with the oldink. How do I get itto print properly.
align the heads in the control panel/ printer page for maintaining print cartridges.
You see, everytime you change ink cartridges you must realign them using a printed page that has lines on it, that has numbers that you choose that determines where the edges of the paper is and also helps to calibrate where each color goes relative to each other.
Well, to make a long story short, it's all about lining up different heads with each other.
Jun 26, 2010 | Office Equipment & Supplies
How do i replace the ink cartridge on an epson stylus nx 400
to replace ink before they run out..
You can view on-screen instructions for replacing an ink cartridge using the printer maintenance utilities.,click the button on the Maintenance tab. then select Ink Cart Replacement and follow the instruction from there on.
Jun 27, 2010 | Epson Stylus NX400 InkJet Printer
How do you change ink cartridges on Epson nx 400
Please download the user manual by clicking HERE.
Open the document which I uploaded for you and go to page 33 to see the procedures of replacing ink cartridges.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
May 06, 2010 | Epson Stylus NX400 InkJet Printer
My Epson NX 400 will not recognize my ink cartridge replacement.
Maybe caused by a bad cartridge or a bad printhead, unfortunately.
Please reseat the cartridges. make sure that you are using correct genuine epson cartridges.
Contact epson to receive free cartridge replacements as a one time courtesy to isolate the issue.
Apr 25, 2009 | Epson Stylus NX400 InkJet Printer
My Epson NX 400 is giving me this error message:Error B88/69/68 C
Try to run the ink pad reset utility software.
Please log on to epson.com. The software runs on win xp and win vista.
Mar 31, 2009 | Epson Stylus NX400 InkJet Printer
White lines on printed photos Epson Stylus NX400
You need to clean the print head on the cartridges , please follow these steps\
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Mar 15, 2009 | Epson Stylus NX400 InkJet Printer
Epson RX500
Are the lines ink? Either you have to keep cleanng the heads until they work correctly or find out where the ink is coming from, if not from dirty heads.(dirty heads means that the ink had drived and you may have to remove them and clean them with rubbing alcohol . What color are they? Replaced any of the ink  cartridge yet?
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=26321&infoType=Overview
Apr 04, 2008 | Epson Stylus RX500 All-In-One InkJet...
Epson Photo R265 Lines every 2.5 cm
Check status monitor see if cartridges are low or nearly empty , if new or full take out all cartridges and soak nozzles upright in cleaning solution overnight , or untill ink starts to bleed out:
Dab dry and re - fit , make up a A4 paper page with 6 colour bands about 1" high x 8" wide and print about 4 to 6 pages ,
check which colours are poor , if improvement is observed run
again a few times:
If one colour is poor take out that cartridge and soak again for a few hours , try again:
If no improvement replace with new cartridge or use a cleaning cartridge ( available on-line ) :
Using the head-cleaning utility shortens the life of the printer as the printer is set to lock-out after a pre-set use of the cleaning facility: and will have to be re-set instore:
cx3200@tiscali.co.uk
Dec 17, 2007 | Epson Stylus R265 InkJet Photo Printer
Epson Stylus NX400 InkJet Printer Logo
493 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
