Question about LG Heating & Cooling
Hi. Just bought a new in box "LP" LWHD 1200R window air conditioner. When I went to turn it on, I got an awful loud fluttering noise coming from the front of the unit. NOT the "slinger fan" which is located in the back. The compressor is working because it will blow cold air, but the noise sounds almost like something is in there rubbing or something. Can anyone please help. It's getting warm up here! Thank you ................ Eric
    Champion:
  • 254 Answers
Hello Eric,
Let me see if this will be of any help take the front cover off and check to see if any packing material has fallen down in the air baffle. this will be towards the top of the unit on the inside. Also check to make sure that any insulation seems to be in place.
Posted on Jun 02, 2008
I got a new (out of the box) LG window unit about a month ago and about a week later started making this awful noise that would wake me out of a dead sleep. It happens about every 10 minutes and I'm at...
compressor fan blade stripped out,,and the motors shaft is slipping..LG uses plastic fans ,,Ive replaced 4 on mine in the past 5 years,,,,part around $30
Aug 26, 2011 | LG Electronic Window Air Conditioner
AC unit LWHD 1800R won't turn on & test/reset does not respond.
Reverse the wires in the receptacle ,not the ground,this is most likely the problem the way the circuit is set up in the ac unit.Let me know if this helps.
Jul 05, 2010 | LG LWHD1500ER Wall/Window Air Conditioner
We have an LG model #LWHD-1200HRY. The air is
is it a heater also if so electric/or heatpump.
Jan 15, 2010 | LG Heat cool Window Air Conditioner
My LG LWHD 7000 is not heating.
heater coil located behing the front evaporator coil has burnt out. To access the coil you need to remove the a/c from its sleeve and the coil is located between the evaporator coil and the fan motor. An appliance parts house will have the replacement coil if you do it yourself.
Good Luck on your repair hope this helped
Dave
Jan 07, 2010 | LG Heat cool Window Air Conditioner
My new Kenmore window unit 76081 makes loud rattle
If it does not make the noise when the fan is ruunin you may ahve abroken sping in the compressor. Make sure you Window unit is level. If not the compressor will knock on the inside. Rusty
Jun 12, 2009 | Kenmore 76081 Wall/Window Air Conditioner
The air conditioner on my pop up camper is loud and vibrating
sounds like the compressor in your air conditioner has a broken spring in it,you can not take the compressor apart to fix,has to be replaced(cashy).I assume your camper is shaking,and the noise only happens when you turn on the air.
May 31, 2009 | Coleman Campers Grill
Lsu242he mini split heat pump fluttering light
This sounds like a low voltage short in the unit. Low voltage shorts can be very difficult to troubleshoot. If you are serviceing the unit for a customer, it might be more cost effective to replace it.
Mar 20, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Fan flutter noise with air conditioning on
I WENT TO THE VW DEALER...HAPPENED TO PASS BY. THE PROBLEM WAS SOLVED WHICH WAS FLUTTERING SOUND FROM THE AIR CONDITIONING FAN.
IT WAS COMING, I WAS TOLD, FROM THE MECHANISM THAT ADJUST THE TEMPERATURE, AND NOT THE FAN
THANKS FOR THE FOLLOW UP
Sep 08, 2008 | 2000 Volkswagen Golf
Makes loud noise when first turned on
It may have been damaged in shipping or from the manufacturer. I would consider exchanging it for a new one.
Jun 15, 2008 | Danby Portable Air Conditioner
Heating & Cooling Logo
139 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
