Question about Princeton Digital VL1918 Monitor
How do I open my Princeton VL1918 monitor to look for bad caps? Removed all the screws but what else to I have to do to get it to open?
  • Princeton Di... Master
  • 13,433 Answers
Remove all the screws from the display, remove the stand, check for hidden screws under labels, soft objects etc.
After that the casing is only held in place with plastic clips, insert a plastic stick, case opening tool, flat screw driver or your fingernails in the cracks in the plastic, or openings, and move it up and down. The clips start opening, you need to go around the display, etc until you get it apart, then it will again have screws on top of the power supply and mainboard cover etc. very simple from there on.
Here is a quick video of a guy taking apart his monitor, i don't recommend the exact method of "hammering" the screen open, but you see where the display cover opens up.
http://www.youtube.com/watch?v=48cB8j-xdtw
Posted on Oct 04, 2010
The VL1918 recently started having a long period of on-off switching when started up. It eventually starts working properly.
It may have bad caps, see my pictures here:
http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL1918W/
This model can have many failed parts as you can see.
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Feb 02, 2011 | Princeton Digital VL1918 Monitor
I've opened my princeton vl 1919 monitor to see if the caps are blown. I can't loosen the grey metal cover covering the boards to see the caps. I've removed the hexes on either side of the video inputs but...
Not sure if the VL1918 uses the same chassis as your, just remove the 4 screws and disconnect all the lamps connectors and other connectors.
http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL2018W/
Can you post the pictures? so I can see what it is about.
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Jan 06, 2011 | Princeton Digital VL1919 19" Monitor
Hello I can't get anything on my screen except
Your PC is putting too high resolution for he VL1918 to display.
You need to set your PC video out put to the native resolution of the VL1918, which is 1280x1024 @60Hz.
You will have to hook up your old monitor (crt type?) and set the new resolution.
Or boot up in safe mode (hit f8 during boot up), and set the resolution to 640 x 480, reboot into regular mode, then rest the resolution to 1280x1024 260Hz.
Also watch out for bad caps in this monitor: http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL1918W/
Apr 07, 2010 | Princeton Digital VL1918 Monitor
My LCD Monitor is blinking on & off constantly
It may need a different outlet, if it is not getting proper power. Small chance that the video cable has gone bad, but more likely the monitor is damaged. But try those two things and call Princeton.
Jul 12, 2009 | Princeton Digital VL1717 LCD Monitor
How is the cover removed from the Princeton VL1918
Theres sort of clips that clips to the side of the monitor's frame, use a flat screwdrive to care fully push through the sides of the LCD to unlock the clips.
Nov 15, 2008 | Princeton Digital VL1918 Monitor
Princeton monitor
check www.badcaps.net - they have a tutorial on their site for replacing caps, it's for motherboards- but the technique is the same.
I ordered caps for the Princeton Monitor VL1918 from Mouser.com and got their item # 647-UHE1E471MPD6
The 470uf 25v caps size- 10x16 mm
Mar 11, 2008 | Princeton Digital VL1918 Monitor
Princeton Digital VL1918 Monitor Logo
67 people viewed this question
Top Princeton Digital Computers & Internet Experts
jairo sanchez
Sunday Ojelabi
Sunday Ojelabi
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
