Question about Endless Summer (GA200209) Stainless Steel Open Flame Patio Heater
Pilot won't lite at all - Endless Summer (GA200209) Stainless Steel Open Flame Patio Heater
    Problem Solver:
  • 10 Answers
Is that with a lighter or just the piezo on the unit. Is pilot getting gas?
Posted on Oct 05, 2010
My pilot light will only light after i heat the thermal coupler. Even with the button depressed gas won’t flow to pilot until heat on thermal coupler is applied. Is this normal?
No this is not normal .The pilot should lite first then when you hold button down until thermocouple sense the flame and tell pilot to stay Lit .
I think you should change out the whole pilot assembly.
Does this pilot needed to be lit manually or has a sparker
Feb 23, 2018 | Heating & Cooling
Jandy lite 2 pilot won't start
check fuses that go to ignitor if ok ohm out ignitor when unplugged should be about 78 ohms if shorted or open replace if ok check safety circuit
Apr 20, 2013 | Jandy Laars Lite 2 Pool Heater 400000 BTU ...
My pilot light won't stay lite,replace thermopile and still doesn't stay lite.
Hi there.
Check for wiring errors, fix and tighten all wiring connections. Make sure that the gas pressure is correct.
Check the hi limit and gas valve, one of those component may be bad.
Regards.
Apr 18, 2013 | Cecilware FMP40 Deep Fryer
Pilot lite won't stay lit
Thermostat flame sensor. Do you see a little rod next to the pilot? That is what tells the main gas valve that the pilot is lit and it is safe to give gas. Easy swap, and you can usually just pick up a generic one.
Apr 14, 2013 | Heating & Cooling
The pilot got wet and it won't lite up ???
There could be water in the pilot line or pilot is blocked and needs cleaning out along with the pilot line .
Dec 24, 2012 | Heating & Cooling
Pilot won't light
check gas pressure check safety circuit if ignitor lites check gas line to it maybe plugged
May 21, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Gas ignitor bypass for raypak heater?
to test the pilot, you can use a torch to keep the sensor hot. if it still won't stay on, you have a bad flame sensor sometimes called either a thermopile or thermocouple. very easy to replace.
Mar 11, 2012 | Raypak RP2100 DIGITAL POOL HEATER R265
Endless Summer (GA200209) Stainless Steel Open Flame Patio Heater Logo
43 people viewed this question
Top Endless Summer Heating & Cooling Experts
Paul Carew
Craig Butler
Craig Butler
Are you an Endless Summer Heating and Cooling Expert? Answer questions, earn points and help others
