Question about D-Link DI-707P Router (DSDLDI707P)
Just plugged in a brand new D-Link DI-707P router. I can't connect to it. I cannot reach it via 192.168.0.1, nor can I ping 192.168.0.1. This was to replace another 707P that was behaving similarly, so I suspect something's up other than problems with the routers. Any ideas what? It's connected to a Cavalier DSL modem, and all 7 ports are in use. Another oddity - in the past, I've not been able to access the router, but everything worked. Now, we're totally down, and I was trying to program the brand new router with our static IP address and DNS and whatnot, but just can't get to it. Even when nothing else is attached to the router but the modem and the computer I want to plug in. Any ideas? Thanks!
  • D-Link Master
  • 7,733 Answers
Use this Dlink emulators and choose your model ->link.
Posted on Oct 06, 2010
DI 707P router stops working.
I'm not sure about your Router whether you use it for Cable or DSL.
If you use it for cable, unscrew the coaxial cable and do factory defaults your router and re-plug the coaxial.
- if it is DSL, isolate the filter/spliter and connect the phone cable directly from the walljack to the router and do factory defaults the device. re-configure the router.
- Check the firmware version of the device whether it is latest one.
Oct 26, 2007 | D-Link DI-707P Router (DSDLDI707P)
Can't Ping D-Link Di-704P
Hi, A couple of things you can try: 1. verify that your LAN cable from router to PC is good. There should be some indicator LEDs lighting up when connected/linked; 2. Co to Start, Control Panel, right click on your Local Area Connection, Properties, highlight Internet Protocol (TCP/IP), click on Properties, tick Use the following IP address > IP address 192.168.0.254; Subnet mask 255.255.255.0; Default gateway 192.168.0.1, OK; 3. Check if you can ping 192.168.0.1; 4. If not, you may need to do a hard reset your router. Pls be reminded that all configurations on the router would be reset to default; 5. If the reset does not work, then perhaps the router would need replacement. Hope this be of some idea/help. Pls post back how things turned up or should you need further information. Good luck and kind regards.
Sep 21, 2007 | D-Link DI-704P Router
Bi-directional
D-Link´s print servers are IEEE1284 bi-directional compatible. This means that data can be sent and received in both directions between the printer and the D-Link print server. Toner status, paper level, and etc. will not be communicated back to the PC. In order to get printer status information, the proprietary printer driver has embedded code that needs to be passed on to the print server, decoded, then interpreted by the print server. Embedded driver codes are not supported by D-Link print servers. D-Link´s print servers, whether in Gateways or StandAlone, are plain TCP/IP print servers.
Feb 16, 2006 | D-Link DI 707P (DI-707P) Router
Print server software for mac
There are no plans to have Macintosh software for the print server feature of our routers. If you can perform port-based printing (OSX), you do not need printer software. Just print to the IP of the router (default is 192.168.0.1) and the Print Queue Name is lp (a lower case "L" and a lower case "P"). Use the current drivers for your printer. In some cases you made need postscript drivers for your printer from the manufacturer (if available). This feature is not supported by D-Link, as per packaging. Please visit http://gimp-print.sourceforge.net/MacOSX.php3 for 3rd party drivers that may work with your D-Link router. D-Link does not and will not support these drivers. Use at your own risk. Do not keep the product in anticipation of Macintosh compatibility. Return it to your reseller.
Can´t print through the router print server
Try changing the Spool Data Format setting in the printers control panel from EMS to RAW. Step 1 Go to Start>Settings>Printers. Step 2 Right click your printer icon and select Properties Step 3 From the properties screen, select the Details tab. Click on the Spool Settings button at the bottom of the window. Step 4 From the Spool data format: select RAW from the drop-down menu. Click OK to close out of Spool Settings and OK again to close out of the printer properties screen. Close the Printers control panel and try printing to the DI-713P with these new settings. In some cases, you may need to disable bidirectional printing.
Scheduled Firewall
Unfortunately not. Active connections must be stopped before the rules take effect. For Example: If you have an active FTP download when the schedule takes effect, the session will not be terminated until the download is complete. Once the schedule is effective and the FTP download has completed, you will not be allowed to initiate another FTP connection until the scheduling permits.
AOL DSL Plus
AOL DSL+ now uses PPPoE for authentication bypassing the client software. To set up your router: Step 1 Log into the web-based configuration of your router by opening a web browser such as Internet Explorer or Netscape and enter the IP address of the router (192.168.0.1). Enter admin for username and then your password (blank by default). Configure the WAN side to use PPPoE. Please consult your manual for login instructions since all routers are not the same. Step 2 Enter your screen name followed by @aol.com for the user name. Enter your AOL password in the password box. Step 3 You will have to set the MTU to 1400. AOL DSL does not allow for anything higher than 1400. Step 4 Apply settings. Step 5 Unplug (turn off) the power to the modem and router. Wait 1 minute and then power on only the modem. Wait about 1 minute and then power on the router. NOTE: If you connect to the Internet with a different Internet service provider and want to use the AOL software, you can do that without configuring the router?s firewall settings. You need to configure the AOL software to connect using TCP/IP (LAN). Contact AOL for more specific configuration information of their software.
Configure to print
You may print without the D-Link Printer software in Windows 2000/XP. Here´s how: Step 1 Go to Start>Settings>Printers>Add New Printer (WinXP - Start>Printers and Faxes>Add a Printer). Step 2 Select Local Printer. Make sure to uncheck Automatically detect and install my plug and play printer. Click Next. Step 3 Select Create a New Port and select Standard TCP/IP port. Click Next. Step 4 Enter the IP address of the router (192.168.0.1). Leave the port name with the default name. Click Next. Step 5 You will get a message saying that additional port information required. Step 6 Select Custom and then click Settings. Step 7 Set Protocol to LPR. Step 8 For the LPR Settings, queue name is lp. It is case sensitive! (LP lower-case). In most cases, check LPR Byte Counting Enabled. If you cannot print, then try unchecking this. Step 9 Select OK > Finish. Step 10 Continue with the Add Printer Wizard. Choose your printer from the list or click Have Disk and point to your printer driver disk.
Configure to print
Feb 16, 2006 | D-Link DI 713p Router (nwl-di-713p-r)
D-Link DI-707P Router (DSDLDI707P) Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
