Question about Hitachi Computers & Internet
My laptop has a Hitachi HTS541612J9SA00 Disk Drive which has stopped working. The computer can identify the drive and said its up to date. But it will not recognize any disks and my nero and media center will say that there is no drive installed.
  • 1 more comment
  • coleman619 May 28, 2008
    Its an internal drive, I guess I need a new one then!
  • coleman619 May 29, 2008
    If you could that would be great.
  • coleman619 Jun 03, 2008
    I'm having trouble with this, when I hit F8 I cannot find the 'boot from utility' option. Would this be listed as another option?
    Sergeant:
  • 336 Answers
Try to install the Drive by Opening Control panel and Clicking Add new Hardware and following the on screen instructions. If that dosent work The drive may be shot and you may need to get another drive. Also is the drive internal or external?
Hope This Helps
All The Best,
RCF
Posted on May 28, 2008
  • Ryan Frame
    Ryan Frame May 28, 2008
    Now do You know how to run tests on your hard drive? If you don't I can walk you through It. The tests will tell me if the hard drive can still be used or if it will no longer function.
    All The Best,
    RCF
  • Ryan Frame
    Ryan Frame May 29, 2008
    When the start screen comes up hit F8 one of the options is to boot from utility partition. Do that and you will be in a screen. Go to hard drive and do all tests on it. Tell me what they say.
    Hope this Helps
    All The Best,
    RCF
Error
If you have an external hard drive, you can use software such as Acronis, to make a copy of that drive to save everything in an image. Get a new drive to install in place of the old one. Next you can use Acronis to copy the image on the external hard drive, back to the computer, onto the new hard disk in your computer.
Jul 19, 2013 | Microsoft Windows Vista Ultimate Edition
I need to purchase a drive enclosure for a Hitachi hard drive. Model no. HTS541612J9SA00. I have bought 2 different models both were wrong. Help!
The drive you posted is a SATA I drive, that may be the reason the other enclosures did not work. Search for an enclosure that is SATA I compatible.
Here is one from Thermaltake:
http://www.thermaltakeusa.com/Product.aspx?C=1289&ID=1940#Tab1
Jun 12, 2011 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
When starting the laptop, it says "operating system not found", the hard drive (hitachi hts541612j9sa00) makes a sound like trying to run but not being able to do so. I tried to take it out an...
Hi
Thank you for using FIXYA!!!
Before we start thinking about trashing the drive, we can ask some questions, and if the results are negative, it is most likely a spindle failure in the drive itself. Basically this means that the repair cost will be much more than just to replace the drive.
I have written a tip which will be able to diagnose the problem. To navigate to the tip, you will need to click on the link below.
Click HERE.
Just to clarify: The clicking noise i am referring to in the tip does not necaserilly need to be loud, if the drive makes a different sound that it use to make, it is most probably done.
Please do not hesitate to let me know if you have any further questions.
Kind regards
Lock123
May 20, 2011 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
Hi, my laptop stopped recognizing my HITACHI HTS541612J9SA00. on device manager i get two general storage devices, and their properties say that they're both working properly plus they're both located on...
This sounds like a single drive with multiple partitions that's working properly. Just because it doesn't identify the device by name doesn't mean its stopped working. Have you lost drive letters? Also, if it stopped working then you wouldn't be able to boot Windows unless you have multiple drives with some type of redundancy like a RAID array that's mirrored. : ) You can right click My Computer or just Computer IIRC in the later OSs and Manage to bring up your management console. Go to Hard Disk management and check what's active and if you have any drives/partitions that haven't been assigned a letter. This is the place to tell you more about your drives than you probably knew was possible. Good luck!
Feb 14, 2011 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
My disk drive does not work in my Advent 1115C Laptop running Windows 7. I went into the Device Manager and listed under Disk Drive is 'Hitachi HTS541612J9SA00 ATA Device' and I tried to update it but it...
Install it another computer which is running well.If your Hdd run well in that computer ,change the USB cable .If the HDD can not run in another pc you think, you have lost data.Because that Hdd cant run any more.
If the problem is same.
follow the step
R_click on my computer>Properties>Hardware>Device manager>uninstall all the usb hub ,one after one .
After UN install all the usb, restart your PC .
If the problem , is same as before ,
Insert your OS in the cd tray > press Win key + R>type sfc /scannow (please take a space between sfc and front slash)>hit enter .Again you will restart the PC.
If the problem is same please change the Hard disk.
Hope it will help you
Jan 10, 2011 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
I want a converter for Hitachi HTS541612J9SA00 120 GB SATA Hard Drive to usb do you know wich one I need..?
You need a 2.5" inch SATA to USB external harddrive enclosure.
since its a laptop hard drive you need a small case.
for example this one http://www.amazon.com/2-5-SATA-HDD-Enclosure-Black/dp/B0018TCB0O
Aug 07, 2010 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
No hard drive
the hard drive heads have failed you will need to replace the hard drive,, ebays the cheapest to be honest but only search compatable with you dell,, any make hasnt got to be Hitachi
Apr 27, 2009 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
53 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
