Question about Dell 4100MP Multimedia Projector
Lamp failure with new bulb. i bought a used unit and the it worked right away. as i first turned it on, it said from the get go that the lamp was near its useful life so i bought a new bulb. it turned on and i had it working with my computer for about 30 minutes. the next day i tried the same and the "lamp" light came immediately on. i thought i mis-installed the lamp so i bought another. same problem. what am i doing wrong?
3 Suggested Answers
  • 3 Answers
SOURCE: dell mp5100 " lamp failure"
Have you tried cleaning all air in-take spaces ? On mine the lamp failure was triggered by temperatur. Afetr hoovering the projector and removing all dust the same lamp worked flawlessy.
Posted on Mar 31, 2008
SOURCE: lamp life over 2000. can't turn on again after replaced
sharp xv z9000u bulb reset
Hold down Enter + down arrow + right arrow and then power on.
Posted on Apr 21, 2009
Origional Epson 3010 bulb burned out after 2 years. New bulb died in a month
our company supply the Original lamp ,unit price is USD200
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Dec 08, 2013 | LC EPSON ELPLP68 / V13H010L68 Projector...
New lamp, half screen is bright the other half is much darker
Greetings,
Correct, if you know how to, try re-connecting the lamp.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 12, 2008 | BenQ MP610 Multimedia Projector
03 Chevy Trailblazer left rear taillight will not work. Brake light, back up light & turn signal all work. Right rear all work. Replaced bulbs, switched sides, still nothing.
There was a recall on this, see your local Chevrolet dealer.... Recall Date: NOV 01, 2004 Model Affected: 2003 Chevrolet Trailblazer Summary: ON CERTAIN SPORT UTILITY VEHICLES, VIBRATION AND HEAT MAY CAUSE THE TAIL LAMP/STOP LAMP BULB TO LOOSEN IN ITS SOCKET. IF THIS OCCURS, THE BULB MAY FLICKER AND EVENTUALLY BECOME INOPERATIVE. Consequences: AN INOPERATIVE BRAKE LAMP WILL NOT CONVEY THE DRIVER'S INTENTION OF STOPPING TO DRIVERS IN FOLLOWING VEHICLES, AND AN INOPERATIVE REAR TURN SIGNAL LAMP WILL NOT CONVEY THE DRIVER'S INTENTION TO TURN TO DRIVERS IN FOLLOWING VEHICLES. BOTH OF THESE FAILURES CAN INCREASE THE RISK OF A CRASH. Remedy: DEALERS WILL INSPECT THE TAIL LAMP/STOP LAMP ASSEMBLIES, AND IF NECESSARY, REPLACE THEM. THE RECALL BEGAN ON NOVEMBER 22, 2004. OWNERS SHOULD CONTACT CHEVROLET AT 1-800-630-2438, OLDSMOBILE AT 1-800-630-6537, BUICK AT 1-866-608-8080, OR GMC AT 1-866-996-9463. Potential Units Affected: 871473 Notes: GENERAL MOTORS CORP. Read more: http://www.motortrend.com/cars/2003/chevrolet/trailblazer/recalls/#ixzz2jWJ1eDyR
Nov 02, 2013 | Cars & Trucks
Tv nt coming on red light is on next to power light 50 inch lcd projection sony tv
hello. it sound's like you need to replace the lamp in your set. and here is how to do it the right way. rember to all ways unplug your set.. # 1 first. .Remove the outside lamp cover. The lamp cover is located on the right side of the Sony television. To remove the lamp cover, simply pull down. You will now have access to the lamp housing. # 2 Open the lamp housing door by turning the locking handle counterclockwise while pulling the door toward you # 3 Pull the lamp unit straight out of the television unit. Be sure not to touch the bulb, as it may still be hot. # 4 Slide the replacement bulb into the lamp housing. # 5 The lamp will slide securely into place.!!! "Do not" touch the new bulb as it will cause damage to the bulb and result in malfunction. # 6 Push the lamp door back into place. Turn the locking knob clockwise to secure the door in place.# 7 Slide the outside lamp housing cover back into place on the television.!!! plug your set back in to the wall & The television is now ready for use. thank you
Oct 21, 2010 | Sony KDFE50A10 50" HDTV
Mitsubishi WD-52327 TV won't consistently turn on, new lamp
the problem is in the power supply circuit
capacitor may be or so the click mean theres cap are leakink or get dry that why is so long to power on.
hope that give you a idea.
May 05, 2010 | Televison & Video
Message reads failure to srike lamp. bulb is less
that ones are total ****... seems like lamp is broken .. my advice would be get a new projector(not LP70) other that get a new lamp...
Mar 02, 2010 | InFocus LP70+ Multimedia Projector
Problems with Projector Panasonic PT-L501XU after change the lamp
was this bought new or second hand?
There is a "Lamp Time" setting that can be accessd using your remote control, check this setting.
Look on page 40 and after that of your manual about ambient temperature bulb failure.
By powering off or hittign the reset button the bulb should stay on IF the projector is gettign a signal from a device to show an image. If the projector is not hooked up to a device, laptop, TV, etc. the bulb may turn off to save hours of operation.
Dec 21, 2009 | Panasonic PT L501U Multimedia Projector
I just put a new bulb in my Optoma H31, but still get Lamp Fail
have you check that the bulb you installed is the right bulb for your unit?
have you check by replacing your bulb it correct position?try to unplug the power cord and lug it again and turn on.
Oct 09, 2009 | Canon RS-LP02 Projector Lamp for LV-X6
How to reset lamp meter
I have a PT-50LCX63 unit. After 5 years and 4 bulbs, a "reset lamp" warning showed up every time I turned on the tv. I have to say that after a few weeks, the message ceased on its own. I don't know if all models eventually reset or turn off, but I could not find any other information on the direct way of resetting. I find the warning a waste of time since the bulbs are good for 10 -14 months. Sadly I missed the class action suit that dealt with the premature lamp failures. I am looking for a new tv at this point. Bulbs have cost me $1200.00 since I bought it. The warning is supposed to allow you the option of replacing the lamp before it fails, Ha! what a joke...Thanks for reading.
Dec 29, 2008 | Panasonic PT-50LCX63 50" Rear Projection...
New bulb installed and it takes 10 plus minutes to start
Exchange the lamp under warranty...
You've tried almost everything else.
It's not that uncommon to experience "infancy failure" with a brand new lamp.
If the problem persists with the replacements replacement then I would suspect the Lamp power supply (Ballast) is failing.
Dec 14, 2008 | InFocus ScreenPlay 4805 Multimedia...
Dell 4100MP Multimedia Projector Logo
98 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
