Question about Pioneer SD-P55A3-K 55" Rear Projection Television
Pioneer tv I have a pioneer projection tv model # SD-P55A3-K I have sound but no picture
  • Anonymous Mar 27, 2014
    Model # SD P55A3-K Pioneer. I just want to get it out of my basement and take it to a recycling depot.
  • Pioneer Master
  • 8,617 Answers
This is a common problem with pioneers. try resoldering the vertical output Ic that should remedy the problem. if not the vertical IC may be faulty
Posted on May 28, 2008
No picture on my pioneer TV model SD-582hd5
The problem is on lamp try to replace it to get back the picture..
Feb 23, 2012 | Pioneer SD-P55A3-K 55" Rear Projection...
Pioneer 47 inch big screen, was getting dim but would flicker back to normal, now there is just no picture at all but has sound
Sounds like you got a bad connection, that has finally come off.
Moving those big things can cause that.
Open the back and check.
And call an expert.
If ya in VB, I'll do it.
Aug 29, 2011 | Pioneer SD-P55A3-K 55" Rear Projection...
I have a Pioneer SD-P55A3 and i was wondering if it can be taken apart for moving purposes?
No,don't this tv is a delicate equipments inside.Tv CRTS R,G,B TUBES guns are easily to be broken if dosen't have the outer frame to protect it.Also the Tv CRTS R,G,B TUBES guns have coolant chemicals inside it,could also damage ur tv even if the CRTS R,G,B TUBES guns are not broken.Tries to put it on the cargo pallet,put a heavy blanket on.Ties it with a heavy ropes tightly and firmly.Than put it in a moving Rider truck or a personal truck.Now firmly sacures the tv for good not to make any movment.Now u can tranport it anywhere.
Dec 06, 2010 | Pioneer SD-P55A3-K 55" Rear Projection...
My pioneer sd-p55a3 projection tv stays on for 5 minutes and then fuse for projector burns out
probably the solder connections on the convergence board.. solder it up good and it will usually stop blowing that fuse..
what is the fuse #?
let me know if i can be of further asistance
Jun 08, 2010 | Pioneer SD-P55A3-K 55" Rear Projection...
Sd-p55a3-k/kc this tv does not turn on
Th convergance amps have failed you will half to replace them, or have it done parts are around 70 dollars not and easy fix on a pioneer time consuming
Dec 10, 2009 | Pioneer SD-P55A3-K 55" Rear Projection...
My tv has no sound, Should I fix the problem
I suggest you do a technical review porq you may worsen your situation
Oct 27, 2009 | Pioneer SD-P55A3-K 55" Rear Projection...
Hello, I have an older Pioneer SD-P55A3 projection tv. I have a problem where the picture at the bottom of the screen appears distorted or, more accurately, "warped". There is yellow and blue that does not...
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
Mar 16, 2009 | Pioneer SD-P55A3-K 55" Rear Projection...
Words don't line up??
call someone out to reconverge it for you it shouldnt cost alot and it will get the picture right again
Jan 28, 2009 | Pioneer SD-P55A3-K 55" Rear Projection...
My Pioneer 55 inch screen tv SD-P5553 has a solid black horizonta
This sounds like a picture mode issue. You maybe in a ZOOM mode. Try adjusting your set to FULL mode. If you are using a Sat receiver or cable box, some of these may have picture viewing mode as well, wich may need to be set in FULL or NORMAL viewing mode.
Good Luck!
Jan 18, 2009 | Pioneer SD-P55A3-K 55" Rear Projection...
Pioneer SD-P55A3-K 55" Rear Projection Television Logo
212 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
