Question about Sony Ericsson K510i Cellular Phone
Sound quality the quaity of sound when receiving a call is very poor. It is loud enough, but distorted and unclear. It's fine on the internal ;odspeaker. Any thought?
    Genius:
  • 1,011 Answers
U have to replace the ear piece of ur phone.
Posted on Jul 24, 2008
Motorola H19txt has very poor sound quality
sadly you have poor quality loudspeaker. the only thing u can do is plug in a powered speaker set into the headphone socket.
Nov 20, 2013 | Motorola Mobility H19txt Universal...
I like the sound of my practise amp but it's not powerful enough can i connect it to a larger amp without getting feedback/distortion?
you can use the record outputs to run the signal into a stereo receiver without problems, though it would likely sound better with a shure sm57 microphone hooked up to a mixing board or other instrument amp.
the record output should be PERFECTLY balanced to hook up to a consumer-level stereo reciever with NO distortion; however, this record output might be too loud for another instrument amplifier or a mixing board; hence, the microphone in the latter situation.
short answer- "yes, but..."
Nov 26, 2010 | Roland Cube-20x (20w 8" Modeling Guitar...
Some of my records sound distorted in playback others play fine it seems
This could be a defective cartridge or a bad belt. It all depends upon the type of distortion that is present. Poor speed control can be difficult to hear with speech but very noticable in music. With low volume sources, poor quality may not be as noticable and hide cartridge problems. Can you please update this with a description of the distortion as well as the model number?
Thanks,
Dan
Oct 05, 2010 | Technics Audio Players & Recorders
Distorted sound on Technics SL-1200/1210
You could be getting acoustic feedback from the speakers to the TT's. Lower the volume or somehow isolate them from room sounds and vibrations.
Jul 05, 2010 | Technics SL-1200 Turntable
My left speaker is loose
The symptom you are describing is exactly what is known as a "BLOWN" speaker or the voice coil has "shorted", this is caused from the volume being up to loud, heating up the voice coil and frying it, in the future if the bass/sound is distorted then turn the volume down just enough to stop the distortion and this will save the speaker.
As far as getting a replacement speaker, you will have to contact the manufacture to get a replacement.
Good Luck !
Apr 21, 2010 | Philips FWC577 CD Shelf System
My ebac 2650e has started shuddering when on the eco auto setting but is fine on fast settings. It also makes a rattling sound. help!!
The fan is mounted on a very poor quality 3 angle mount. The weight of the motor distorts the mount over time so the the fan starts clipping other fittings when spinning. You can turn the mount around so the motor hangs upright again. The latest EBACs are of very poor quality...
Feb 15, 2010 | Ebac Dehumidifiers
Distorted copy quality in the sent faxes
Make sure the rollers that pull the paper through are clean and that the glass is also clean. Clean the rollers with a cloth dampened with alcohol.
Apr 20, 2009 | HP LaserJet 3050 All-In-One Printer
ION TTUSB05XL - Poor sound quality
the turntable has a built-in phono preamp so you don't want to run it through phono inputs in your receiver but just regular auxiliary inputs instead
Oct 03, 2008 | ION Audio iTTUSB Turntable
Intellifax 4100 grinding noice
Probably caused by the toner cart. Only use genuine new Brother brand supplies. Remans fail quite often with Brother machines.
Possibly bad gears on fuser drive. But with the poor print quality, I suspect it is the toner.
May 02, 2008 | Brother IntelliFAX 4100 Laser Fax
Sound quality
Will not turn on get blue screen with eq band only after leaving it on for some time i get some function out of it only at low volume setting if i try to turn it up reception and sound quality breaks up
Oct 12, 2007 | Pioneer DEH-1500 CD Player
Sony Ericsson K510i Cellular Phone Logo
49 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
