Question about HP Pavilion dv1000 Notebook
The display on my HP Pavillion dv1000 is extremely dim and I can't get the screen to lighten so I can read it. I have done a hard reset and replaced the power inverter. It blink on once, but that was the best I could get.
  • 2,567 Answers
1. Test using an external monitor. If it works, then either the screen bulb or the inverter board might be defective.
2. Test the inverter. Easiest way to do it if you have a good screen with a good bulb. Connect the good screen to the inverter board & test it. If it lights up, then the inverter board is good. If it did not, then the inverter board is bad & needs to be replaced.
3. If the inverter board is good, then we are left with the possibility that the screen bulb is bad. To fix this, we will need to replace the LCD screen.
Posted on Oct 09, 2010
Need step by step instruction for screen replacement of hp pavillion laptop
It would be hard if I type it here. It's better that you can see it.
There are a lot of tutorials in Youtube. I'm pretty sure that you can find one from there.
David
Mar 18, 2013 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 screen has gone extremely dim. changed the inverter and nothing. connected to an external monitor and nothing. what is wrong? HELP PLEASE!
Two things: video card issue or video card settings. Try to go to the power options configuration of your portable system. Adjust the brightness. If changes does not take effect on your portable's display as well as the external monitor, it is a video card issue. The last option of resolution is to re-install the video driver. Click the link below and choose the exact model of your computer. Try to download the video driver for your computer. Make sure that you have the correct driver for your operating system. If re-installing the video driver still fails, unfortunately you need to have your video card replaced. Usually the video card comes embedded on the motherboard. That means you have to have your whole board replaced.
HP Pavilion Models
Jul 05, 2011 | HP Pavilion dv1000 Notebook
HP Pavillion dv4000 is stuck with a 'disk read error'
try with Disk Manager so Format with Low Level Format...run in under DOS
Oct 23, 2009 | HP Computers & Internet
Screen dim HP pavilion dv1000
The lid actuator switch may not be working correctly. It's a small switch above the keyboard and led's on either the right or left side. Try pressing it 2 or 3 times to see if the display starts working correctly again. If so, it will need to be replaced.
If that doesn't work, you can also turn it on with the ac adapter plugged in. After it boots, press the power button and hold it in until it shuts off and then turn it on again and see if the display has returned to normal.
If neither of these options work, your laptop may need to have the backlight replaced.
Aug 13, 2009 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 blank screen
It may not even be caused by the graphics display driver at all. Your Hard Drive may hae BAD SECTORS and the computer is battling to read the system area of the hard drive... Make alse sure that the hard drive commections are fine
Jul 08, 2009 | HP Pavilion dv1000 Notebook
Very dim screen on dv1000
HAVE YOU TRIED CHANGING YOUR POWER SAVING OPTIONS AND ALSO TRY INSERT POWER CABLE
Jul 04, 2009 | HP Pavilion dv1000 Notebook
Display problem
you have to open the chasis of the notebook and resit the ram if the problem is not solved then your notebook needs servicing
May 28, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
167 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
