Question about SMC EZ Connect g SMC2862W-G 802.11g/b Wireless Adapter
Can't connect to linksys wireless router
I have tried to reinstall smc drivers - and when I click on the wireless network I have on linksys it asks for network key and confirmation. The linksys key is 8 letters, but the smc asks for at least 10 letters - what the heck is that?
  • 110 Answers
It's the particular type of security you've got set up. Some formats of security require the key to be between a minimum and maximum number of characters, some require it to be a set number of characters. If you have problems, reset the router using the reset button on the back, and run the setup again.
Posted on May 28, 2008
I used to have a simple cable modem (coax cable in, network cable out) connected to a separate Linksys wireless router, model WRT400N. This worked beatifully. To improve download speed, I recently...
Welcome to FixYa!
For you to be able to do that, you will need to set the SMC router to bridge mode, you will not be able to do that by yourself because only tech from your ISP have the capability of doing that since they have this tool that can operate on the router setting it to bridgemode. Basically, you will need to call your ISP to set the router to bridgemode and from there, you will be able to configure the linksys router.
Hope this information will help.
Your response is very much appreciated. Thank you for using FixYa!
Jun 24, 2011 | Linksys WRT400N Router
I reinstalled windows XP and now my Linksys wireless router will not connect to the computer. I reset the router. There are three computers on the network. The only one that can/t connect is the one with...
My friend,
In that computer go to the wireless connection in the control panel.
And try to connect through the Windows utility.
Don't forget to start the wireless zero configuration from services.msc
To get in to services.msc in xp
Click on run and type services.msc
Then search for the wireless zero configuration .
Start the service.
Make sure if there is any other utility is there on the computer then disable that.
Dec 17, 2010 | Linksys Wireless-G WRT54G Router
The wireless is working fine but my desktop is not connecting
You will probably need to buy a wireless card for your desktop - most desktop computers do not have a wireless card when you buy them.
If you do have a wireless card installed, try refreshing the connection, making your home connection a trusted/auto-connect connection and downloading a new version of the hardware driver for your wireless card.
You will no have wireless internet on your desktop.
please rate my solution
Jun 20, 2010 | Linksys Wireless-G Broadband Router
I have a linksys wrt160n wireless router,, recently I was unable to connect to the wireless device, I noticed another linksys wireless device showing up on available networks,,I live in an apartment. I...
Is there any computer connected to the router ?
If not then connect the computer to the router. If you are connecting a wireless computer then disable the wireless connection on the computer. open the set up page of the router. change the wireless network name to something different that you never used before. change the standard channel to 11. save the settings. Try to connect to the wireless network. Check if you see the new network name ? If you see the new then try t connect and see if that works.
This router WRT160N has issues with the firmware.
Upgrade the firmware of the router. power cycle the router.
Click here for more information about router and network
Feb 28, 2010 | Linksys WRT160N Wireless Router
My Dell laptop won't connect with my Linksys G wireless router
First check in your laptop wi fi switch is turn on if you have laptop.
Then check in computer that wi fi network adapter driver are installed correctly and enabled .
You can check it in my network places right click on it thne go to proeprty then you see there wi fi network driver then enable it.if disable.
Then you can see search for available networks.
If not works then post here so i give you assistanse for router configuration.
Let me know if you need more assistanse.
Aug 31, 2009 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G not connecting to internet
Make sure you are plugging the SMC into the WAN port on the Linksys router and not the LAN ports.  Your internet connection (which is your SMC) should always plug into your WAN port on the Linksys.  Any computers that you may need to plug in, like Desktops that are "wired" and not "wireless", should plug into the LAN ports on the Linksys.  If you are not using the WAN port on the Linksys for your SMC modem, then that would explain why you cannot get to the internet on wireless or wired computers.
Here's why you are getting the "low connectivity" message:
Computers don't understand why the Internet is connecting or not the "low connectivity" message you keep receiving has nothing to do with your wireless signal strength.   To a computer NIC, "low connectivity" means your network adapter could not find a DHCP server and receive a valid IP address.  When this happens, your network adapter assigns an IP address to your computer in the following range..., and will display the "low connectivity" message until it is able to receive a valid private IP address from the DHCP server.  You can verify this by going to START | RUN and typing "cmd" (without the quotes), then hit ENTER.  A black box will pop up....then type "ipconfig" (without the quotes) and hit ENTER.  This will show you your IP address, subnet mask, and gateway address, and you can verify that your IP address is in the range.  A valid private IP address is typically in the range, but could also be in the range, or the range.    Also, make sure you have DHCP server enabled on the Linksys router for the LAN.  This will ensure your "wired" and "wireless" computers receive a valid IP address.
The WAN port on your Linksys router should be configured to "Obtain an IP address automatically using DHCP".
Apr 19, 2009 | Linksys Wireless-G Broadband Router
Two router home network problem
Can you still connect to the Internet with the Linksys router? I suggest that you go ahead and reset the SMC router to clear up your previously configured settings. Then before reconnecting it to the linksys router, make sure that you can access its web interface via Don't disable DHCP as your computer won't be able to obtain an IP address from it automatically. Do not change other settings. Next, disconnect the ethernet cable and check if you can access the router interface wirelessly. Once done, connect SMC's WAN port to Linksys' numbered port. Make sure SMC's WAN light is on, as well as the light for the port you used on the Linksys router. Check if you can get online.
With this configuration, the linksys router is now acting like a modem, and the SMC as your router. As long as you're online when wired to the linksys, you should also be able to access the net on the SMC once you physically connect them.
Dec 22, 2008 | SMC2804WBR Wireless Cable/DSL Broadband...
SMC EZ Connect 2862W-G does not see Linksys network
It shows that your wireless router and wireless adapters are both working. One thing to try is changing your wireless channel. Since you are already using 11, try maybe 1 or 9. Check if your SMC adapter will pick up the wireless signal.
By the way, how far is your computer (using the SMC adapter) to your wireless router?
Oct 21, 2008 | SMC EZ Connect g SMC2862W-G 802.11g/b...
Need driver for Linksys MRT54G Ver.2
Go On Google And Search Linksys Wireless-G MRT54G Ver.2
Driver And That Should Do The Trick
Jul 09, 2008 | Linksys Wireless-G WRT54G Router
SMC2802W loses configuration and connection
try to dl new update for that rought ever 2 weeks new updates coming for n model ok still drops u call them change ch and hertz settings ok
Apr 15, 2008 | SMC EZ Connect g SMC2802W 802.11g/b...
SMC EZ Connect g SMC2862W-G 802.11g/b Wireless Adapter Logo
263 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
