Question about Whirlpool Duet GHW9150P Front Load Washer
F1 flashes half way through the wash - Whirlpool Duet GHW9150P Front Load Washer
  • 2,382 Answers
Hi...
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this IMAGE...
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Posted on Oct 05, 2010
I have a Whirlpool Cabrio top load washer. When I load the clothes and start the washer and it begins to run I hear an alarm, it stops and a F1 flashes on the display. What does this mean?
F1 (F60-68)
Primary Control Failure F then 1 flashes when there is a primary control failure. Replace the machine control assembly.
See Accessing & Removing the Electronic Assemblies.
F1 flashing on the display indicates a primary control failure.
"F then 1 flashes when there is a primary control failure. Replace the machine control assembly."
The link below lists Cabrio failre codes.
http://www.advantagesupplyfl.com/WhirlpoolCabrioWasherFaultCodes.html
Dec 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 comes up everytime you wash a load of laundry.
F1 = Primary Control Failure
Thank you
Sep 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Alert F1 when starting wash cycle
Thank You
Sep 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Son put normal dish washing liquid in top draw!
ok, the machine flooded and the water has leaked into the bottom of the machine, 1st turn off the machine at the power point. 2nd- open the top drawer and remove the suds from it. 3rd. open the bottom drawer and look under it to the bottom of the cabinet . that is where the water will be. use a torch if you have to. now you need to dry the water up. you can do this with a hair dryer or a fan heater. the reason the machine is flashing F1 is because the water has triggered the flood switch and you need to dry up that water. please reply 4 more help.once dryed F1 will disappear. please make sure all the suds are removed from the top drawer. good luck
May 14, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Half way through the wash the machine stops and F1 lights up.
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the washer ID doesn't mean
anything to me. It seems to me that you probably have a lid switch problem. I can recommend www.acmehowto.com where they have an excellent video on directdrive washers. If you still need help you'll find it at www.applianceaid.com . I think you'll find what you need there. Don't worry about the timer, they hardly ever go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Nov 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer will not work at all just keeps flashing F1
You have a potential short circuit. Please ensure that you have unplugged at mains before attempting these checks!! Then you should make sure the wiring loom is secured properly to the motor. Check the wires around the motor to see if any have bared or are splayed revealing bare wires. otherwise the motor may be faulty.
Sep 15, 2009 | Hotpoint Ultima WF860 Front Load Washer
F1 error code on Kenmore Oasis He
Moister can get in between the contacts,is it in a high moister environment? Try using a hair dryer on the panel to dry it out.Also unplug it to reset.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
F1 error code
replace machine control bd under console
Oct 30, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Top drawer not working
sometimes if the heater is faulty only one drawer will work and the other drawer will flash f1
Nov 02, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Whirlpool Duet GHW9150P Front Load Washer Logo
292 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
