Question about Orbit Sprinkler System Power Source Transformer #57040
I have a Orbit 57161 Sprinkler System 6-Station Standard Indoor Mounted Control Timer with rainbird sprinklers the issue that I have is the sprinklers stay on and don;t turn off.what do i do?
Manual:
http://www.orbitonline.com/lib/media/57114-14%20rF_Eng.pdf
Website:
http://www.orbitonline.com/products/Timers/02/01/19/671/
Tech service 1-800-488-6156
Timer has 4 year warranty
The manual has troubleshooting
Looking through the manual I can see potential trouble areas:
-Water pressure too high > 60 psi is ordinary household pressure > order Brady BTG pressure gauge that connects to hose
-Overlapping times are 'stacked' by timer ... but 'more than one start time' is listed as cause of stations turning on when not supposed to >> reset and re-program timer, make chart of on-off times
-Weak or missing AA batteries >> clean terminal inside timer and replace batteries
-Hard water deposits or unfiltered water clogging water valve (water softeners frequently have this problem) >>> see if vinegar or CLR cleaner can help flush water valve >>> add sediment filter in front of timer
-Look at screen > does display show Manual? As in manual modeI have a Orbit 57161 - 2322052.jpg
-Fuse blown
-Bad solenoid
-A combination of problems listed above with sediment -or- solenoid as main suspects
Posted on Oct 06, 2010
Rainbird esp modular controller will not operate system -
Make sure that the transformer is supplying the 26 volts ac required by the pump relay and zone solenoids. If the voltage is there and unit still will not operate then the electronics are to blame.
Jul 22, 2016 | Rainbird Rain Bird Esp-4mi Esp Modular...
How stop sprinklers from starting over
You only program the first zone to turn on at a specific time. The rest of the zones go in sequence.
Aug 22, 2014 | Orbit 6 Station Indoor Dual Program...
Orbit sprinkler timer manual
Contact the manufacturer. They usually will have the manual online for downloading.
Jul 30, 2014 | Orbit Irrigation 57856 6-Station Easy Dial...
Rainbird sprinkler manuals
Normally, when there is a battery for an item that has a cord that plugs into power, it is to keep "Memory" of anything programmed, in case power goes out.
Jun 01, 2014 | Rainbird Rain Bird Simple Set 6-station...
I'm getting the error code ER P. What does this mean?
Without knowing who the manufacturer is it sounds like it is an "error in the power supply" Suggest replacing the transformer or checking voltage in the outlet.
Sep 04, 2013 | Rainbird Rain Bird Simple Set 6-station...
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/support/
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
Orbit Sprinkler System Power Source Transformer #57040 Logo
1,854 people viewed this question
Top Orbit Hardware & Accessories Experts
appman67
appman67
 Kenneth
Kenneth
Andrew Taylor
Andrew Taylor
Are you an Orbit Hardware and Accessory Expert? Answer questions, earn points and help others
