Question about Mitsubishi WD-62525 62" Rear Projection HDTV
TV was fine yesterday. Went to turn on today and nothing happened. No lights no anything. Seems like no power, but i verifyed that there is power to the set.
  • Mitsubishi Master
  • 11,800 Answers
If the power is going inside the v but the tv appears dead then the first thing you should check is the power button - the tv must be opened then the power board taken out partially (leave the wires attached) and tested. Plug the tv, press the start button then , using a voltmeter, check that the power reaches the power button. Press it then check if the power reaches the power board. If it does continue testing the power board: the mains filter, the rectifier, the filtering capacitors, the power transistor, the control transistor, the transformer, the ballast resistors, the secondary coils and so on.
At least a basic experience is required - you need to know what to look for and how to look for it. If you don't have it then going blindly is the worst thing you can do, you will damage it even further. Call a repairman.
Posted on Oct 04, 2010
Black screen red diode blinks
unplug the set for a while then try it
Nov 09, 2013 | Samsung Televison & Video
My boss MT2 was working fine yesterday and today I went to go use it and two things happen. Either it will mute my guitar, no sound is being transmitted. Or I just get a loud buzz. Either way the power...
The light means NOTHING other than a small voltage is getting to the unit. Verify the power supply is putting out the required voltage...
BUT FIRST...
A common cause of this is we forget which side is input and output... happens ALL the time, so verify you have the in and the out cables to the right placee.
Apr 18, 2010 | Boss Mt 2 Metal Zone Effects Pedal
Working fine till yesterday. When shutdown
Open up the set and look for bad caps, see some failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 11, 2010 | Gateway FPD1760 Monitor
Unable to solve Blank screen
hmm confusing but try turning your ps3 off at the wall give it 5mins and try again if nothing happens try it on another tv
Sep 25, 2009 | Sony PlayStation® 3 (80GB) Console
AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 27, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
it seems that there is a problem in power supply or sweep section failure.
Oct 02, 2007 | Televison & Video
Tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Apr 04, 2007 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
42 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
