Question about Samsung Digimax S630 Digital Camera
Card Locked! It is definitely NOT the lock tab. This is my sisters camera. She has used this card for a while. She took it out to try out a card I gave her and when she put the original back in the camera, it says "Card Locked!" whenever anything that would alter its contents is attempted. I have tested this card in my own camera and it works and I tried my card in her camera and that works. Why is this one card suddenly showing up to this one camera as locked?
  • thepinball May 28, 2008
    Thanks for the replay! It really has nothing to do with the sliding lock mechanism on the SD card. I have no reason to think it does, anyway. I tried the card in my own camera and it worked and then I tried the card from my camera in the Samsung camera and they worked together. If it was the lock on the card, my camera would have not formatted the card or taken pictures, etc. I did clean the contacts even though that is a fairly moot point since the card worked in one camera and not the other. It is as if for whatever reason this one camera thinks this one card is locked. I really don't even expect to get a solution but this is so puzzling that I had to try to find out.
  • mehim1 Jun 15, 2008
    I've got a new card & it does the same thing as my old one did. All it says is Card Lock everytime i try to take a picture;
    What do i do?
  • 426 Answers
The best solution is to get all the data off of the card then remove the card ... its easier to just replace the card.....
but you can try to fix it your self if u think u can simply take a pair of pliers and remove the tab make sure that the slot is bridged(or not bridged) to stop the lock....before you do that you are going to want to test other cards and see if its a problem with the camera
before you take the hammer out to the card also try cleaning the contacts "_"
!~Lee
Founder Of Free Tech Associates
www.whypayforhelp.org
Fixya@whypayforhelp.org
Posted on May 27, 2008
When I try to take a picture, it gives me the error message "Card Locked !" I have checked the tab and the memory card is not locked. I have put memory card in another camera and it works. Also, I hav
Check the card slot for debris and clear it out gently with canned air, small thin piece of plastic, etc on the same side as the lock tab. Try not to use anything metal unless you have a really delicate touch.
Oct 30, 2014 | Cameras
I just bought the olympus X-42 and it took pictures fine. Then I uploaded them onto my computer. After that I wanted to take more pictures and now it says, "Write Protected" I looked at the instructions on...
This is almost always a setting with the "write protect" or "lock / unlock" tab on the SD or SDHC memory card itself - and is easily remedied. Remove the memory card from the camera if it isn't already, and look along the left edge of the card. Find a small tab and slide it forward (to the unlock position) and carefully slip the card back into the camera and try again. If it reports locked again, carefully remove the card to see if the tab has moved back to the locked position.
In exteme cases: If the tab is moving to the locked position during the insertion process, you could place a small amount of tape along the card edge - over the tab - and carefully insert the card again. You might have to remove some tape to allow the card to fit into to slot. If you never lock the card - you could put a very small drop of super glue on the tab to hold it in place. Wait for the glue to set completely before inserting into the camera.
Please rate this reply if it was found to be helpful. Good luck!
Aug 02, 2010 | Cameras
Card locked
So I got the same error message a few weeks ago. I bought a card reader and a software program that is supposed to recover lost/deleted/corrupt files but to no avail.
I have tried the SD card on my sister's camera (same Canon powershot) and it doesnt work. I have tried my sister's SD card on my camera and it does work so it is not my camera. It is clearly the SD card with an error.
What can i do, i cant lose these pics!!
Thanks anyone who might have an idea.
P.S. The SD card itself is UNLOCKED.
Apr 07, 2010 | Canon IXUS 860 IS Digital Camera
When I turn the camera on, it says memory card error, card locked!. I took the card out and saw that the lock switch is not on.. still doing it
The lock/unlock tab may be getting moved to lock when inserting into the slot of the camera, and then moving to the unlock position when it is removed from the camera. This will make you think it remained in the unlocked position while it was in the camera.
Use a small amount of scotch tape along the edge of the card with the tab to hold it in the unlocked position. Gently insert it into the camera - do not force the card into the camera. You may have to trim excess tape from the card, depending on how tightly the card fits in the camera slot. if you have trouble keeping enough tape on the card to hold the tab in place, you could try using a dab of super glue instead. The glue method however, will be permanent.
Once the card can be easily inserted and removed, try it again.
I hope this helps!
Oct 20, 2009 | Canon PowerShot A470 Digital Camera
I borrowed my sister in laws samsung i70 now it is saying the card is locked & wont function how can i unlock it?
Shut the camera power off, and remove the memory card.
Observe the label side of the card and find a small plastic tab on the left edge of the card. Slide the tab forward (towards the connector end) into the "Unlocked" position.
*Carefully* reinsert the card into the camera - taking extra care to slide it straight in - so that the tab is not bumped back to the "Locked" position.
Power up and and take pictures.
If it doesn't work - it is possible that the tab got moved during the reinsertion process. Remove the card again, and place a *small* amount of scotch tape over the tab to keep it from moving, and try again.
Oct 15, 2009 | Samsung S760 Digital Camera
I have a Canon powershot A700. I took out the old
As you've already tried sliding the card's locking switch, see this link for additional things that you can try.
Sep 08, 2009 | Canon PowerShot A700 Digital Camera
Locked Memory Card
I use a Nikon D300 and have Sandisk Compact Flash memory cards. i ahve not come across this problem but would suggest that you insert the memory card into your camera and reformat the memory card. This should clear any errors in the system BUT IT WILL ALSO WIPE ANY PHOTOGRAPHS YOU AHVE TAKEN when formating the memory card.
Oct 20, 2008 | SanDisk ULTRA II 4GB Compact Flash Card...
I presently have a Samsung Digital Camera Model L830.The memory card is in the camera (2G).After having taken some shots and then took the card out and had some prints made from it.I replaced the card in...
-likely the 'lock' tab on the memory card has been moved....a safety to prevent you from re-writing your card
Fix it by:
1 remove memory card from camera
2 look for the very little tab/switch on the front of the card
3 slide it to the unlocked position (opposite of now)
4 put it back into camera
if the tab/switch is missing do not dispair..
1 use a small piece of clear tape to cover this 'tab/switch' opening
-this is the same concept as cassette/vhs/ 5 1/4" floppies...removing the 'tab' to lock it
Oct 07, 2008 | Cameras
Card Locked
If it is an SD memory card, there is a switch actually on the edge of the card. Try moving it to the other position and reinstall. Most people don't realise it's even there untill they have problems.
If this works , please rate accordingly so others may follow.
Thanks.
If it doesn't, there will be access to view the locked photo's on the camera. Selecting protect/ lock again should remove this.
Jul 09, 2008 | Canon PowerShot A550 Digital Camera
Memory card locked
Hi everyone,
Here's the solution, I just had the same problem LOL!
1. take the memory card out
2.On the memory card there is a little switch (it will be the little tiny piece on the side of the card thats a different color) slide it up.
That's it!
Bye
Nov 05, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
Samsung Digimax S630 Digital Camera Logo
81 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
