Question about HP Compaq d530 PC Desktop
My hp machine red light is blink and my system get shut down what is the problem
  • HP Master
  • 1,183 Answers
You can use the following link to troubleshoot and pin point the exact message . Match how the light is blinking with chart on the link below to ascertain which component has gone bad.
Troubleshooting Link
Thanks for using Fixya
Proton
Posted on Oct 04, 2010
Reset my dav-ea20 system,it comes on,but shuts down with blinking light
Your unit has DC Offset(a damaged amplifier) which is why it keeps shutting down. If you are interested in repairing your Sony, please visit my website at audioserviceclinic.com. Thank you.
Jan 13, 2015 | Sony DAV-EA20 System
Red light blinking twice
If this machine is running XP, or earlier (98, 2000, ME, etc.), beware. It is no longer supported, and hackers will be looking for these machines to infect. I recommend you get a newer machine, or don't try to get on the Internet with this one. The hard drive or some other critical component may be failing, or just the OS or hard drive corrupted. If you have files that you do not want to lose, you could try this... Pull the hard drive out, and use a "USB Hard Drive Adapter" (available fairly cheap online) to connect the hard drive to a friend's computer, and save all the personal files (documents, pictures, etc.) you can to a folder on the friend's computer or an external hard drive. That way, at least you may not lose your files.
Jun 19, 2014 | HP Compaq d530 CMT PC Desktop
Machine makes 3or4 dumps ans shuts down red light blinks refrigerant if I unplug and plug back it will produce 3-4 dumps and so on
After the machine shuts down pull the front cover and look at the controller. What cod is it showing? I would need this info before i can tell you what to look for.
Apr 06, 2014 | Scotsman Cooled Modular Contour Cuber Air...
Stops cycling intermittantly
Any advisory lights on, e.g. bin full? Clean all sensors and make sure dump valve isn't letting water gradually drain out
Apr 04, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
My fat 60 GB PS3 just stopped working. Blinking red light persists despite multiple resets. Please advise
The manual clearly states a blinking red light is an "over heat condition" and your system has shut down to prevent a failure. You need to find more airflow for your PS3. If your system is cooled down and you are still getting a blinking red light then you will need to replace the CPU board because it has melted from excess heat. Click on the link below to send in your PS3 for warranty repair:
http://us.playstation.com/support/warranties/ps3/index.htm
Dec 21, 2010 | Sony Playstation 3 (PS3) Console
HP COMPAQ D530 RED BLINKING LIGHT WITH BEEPING SOUNDS.
4 beeps & 4 flashes mean problem with the power supply. For my experience, most of the time the PSU is good, it is just overloaded.
For more LED and Beep messages, check this link:
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00067072/c00067072.pdf
Dec 26, 2008 | HP Compaq d530 PC Desktop
HP wireless mouse problem
If it has a button on the bottom of the mouse, press and hold till it goes drk.
Hope this helps, Bud
Nov 09, 2008 | HP Wireless Optical Mouse
Blinking red lights on startup
4x red blinking light on this system means it's "CPU thermal shutdown" this is done when the cpu fan fails to cool the cpu and the computer shuts itself down to keep you from burning up the system.
This could be caused by dirt, hair, dust in the cpu fan or heatsinc or because the fan has failed.
you can blow some canned (dry) air through the fan and heatsinc undernieth it and try to clean it. most likely you will have to take it off to clean it thoroughly or replace the fan. It is about a 15-20 dollar fan and your local computer shot or neighborhood computer guru can replace it in 10 minutes, so dont let then keep your computer longer than a day.
If your computer savy, remove the case, inspect the fan while the computers ON to see if it sounds weird or is not coming on at all. it has usually two retaing clicps the can be difficult to remove with the power supply in the way. so be ready with a philips head screwdriver and a notebook to write down anything you dont want to forget to put back. If you decide to tackle it, post again here after you check the above mentioned things and ill get you a detailed breakdown of how to do it. It real is not too hard.
Regards..
Oct 29, 2008 | HP xw8200 PC Desktop
HP 3 button optical wireless mouse
It is normal because the mouse is still picking up the "stand by" power of the motherboard.
It will very very slowly trickle away any charge you have in the laptop battery, but over such a long time you would probably not notice.
The mice on my desktop machines do the same thing, as I live in an area prone to electrical surges I shut down my machines and power strips every night and as soon as I do the laser light in the mouse goes out.
On my laptop I have a wireless optical mouse and when I finish using it, I remove the USB adapter, the USB adapter then slides into a receptical in the mouse and automatically switches the mouse off saving the mouse battery.
If it concerns you just unplug the mouse when it's not in use
Jul 28, 2008 | HP Wireless Optical Mouse
HP Compaq d530 PC Desktop Logo
131 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
