Question about GE Profile PCF25PGW Side by Side Refrigerator With Ice Box
I turned the water off on the ref for a week of vacation, and when I turned it back on, the water worked ok , but no water came to the ice maker. I removed the filter, but still no water to the ice maker. the water pressure is ok. before I tuarned the water off, the ice maker would make a clicking noise, some times real loud when the ice cube tray filled. it sounded like a gear shipping. the sweep arm on the ice maker manual that I have, shows the sweep arm vertical, but the sweep arm on the ice maker is at the top os the ice maker, and does not stop the ice maker from filling up the bin. I
  • 109 Answers
SOURCE: Roper top freezer ice maker out of sync? Too warm?
sorry you must replace the icemaker.
Posted on Mar 30, 2008
SOURCE: GE top freezer ice maker leak
I have the same problem -
Posted on Aug 11, 2008
tzweeb
  • 318 Answers
SOURCE: ice maker sprays water into the ice storage bin
you need to remove the i/m from the freezer and make sure the "fill cup" doesnt have an ice blockage. thats where the water has to funnel into the mold. it can get a drip into the cup and then freeze in the cup. clear it out once and try it again, but if it happens once or twice again , then you might have to replace the water inlet valve.
Posted on Dec 28, 2008
  • 4 Answers
SOURCE: LG ice maker only making two ice cubes at a time
Colenoid in the ice dispenser may be clogged or have a small amount of trash in it. Is there a filter on before the fridge (just after the ice maker shutoff)?
Posted on Mar 21, 2009
SOURCE: GE Side by Side Model #TFH24PRSMWW Ice maker
The on and off switch of the ice maker on the ge side by side model has fell off and appears broken. please instruct with a diagram how to reattach.
Posted on Jun 17, 2009
Went on vacation without turning the ice maker off was gone for to 2 weeks and the ice maker was full upon our return. I emptied all the ice and now the ice maker is not working (not making ice). I would...
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Jul 08, 2011 | Samsung RSG257AARS (241 cu ft) Side by...
WATER DISPENSER HAS STOPPED WORKING, HAD BEEN WORKING FINE THEN JUST STOPPED. WASNT SURE IF FILTER JUST NEEDED TO BE REPLACED OR IF MAYBE THE WATER LINE WAS CLOGGED. THE ICE MAKER IS WORKING FINE,
check your water tank in ref. it is behind veg. drawers.. if water tank is full. might check water soldnoid in b back of ref. there should be two one for ice maker and one for water..ok
Feb 13, 2011 | GE GSH25JFR Side by Side Refrigerator
Water doesn t come out put the water does go into the ice maker
ok there should be a double soldnoid in back of ref. one is to allow water to ice maker, one is for the water. ok it could be bad.. look for your tank in the ref. in back of veg. trays and see if there is water in the tank.. ok
Feb 12, 2011 | LG LFX25960ST Stainless Steel French Door...
Ice mker not working
ok make sure u have water coming into back of ref. make sure your ice maker wire is down in on position. chech and see if water in ice maker.. u have to have water. u have a solenoid that allows water into ice maker. check this out then let me know what u find then i will walk u tru what else to check..ok i hope this helps u..
Feb 12, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Water does not come out of door. I can hear the click and the ice is working on the other side so it is getting water.
check your water tank in the ref. looking under the veg. drawers. there it should be on the back of ref. if no water than your solenoird in back of ref. might be bad. there is two one for ice maker one for water.. ok
Feb 11, 2011 | Whirlpool Refrigerators
Icemaker stuck in 'vacation mode'
Feel inside the ice slots are there any old cubes that have evaporated in time? Take the ice maker out and clean it up and place it back inside to see if it will fill with fresh water. Take a hair dryer and melt the old ice inside the slots and see if it will try to fill. I will wait for a response from you.
KSCS25INWH00 Kitchenaid Parts
APPLIANCE 911
KitchenAid Refrigerator Ice Maker Assembly 2198597
May 06, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Testing IM-6 Water inlet valve
check water valve or icemaker
Apr 06, 2009 | GE Refrigerators
Ice maker has quit working
Sounds like the water port to the ice maker is frozen. Do a complete defrost - shut off power for at least a day or more then turn back on and see what happens.
Mar 25, 2009 | Refrigerators
Icemaker will not was dispense ice
My icemaker stopped producing ice. We turned off the water line to it when we went on vacation for a week. We turned the water back on when we got home and since that time it won't produce ice. We can still get water from the door dispenser though.
Nov 02, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker
Check the power conection to the ice maker. If that's ok, then I would think the solenoid that controls the water flow has gone bad. Unfortunately, you will likely have to replace the whole ice maker, I don't think they are reparable.
Feb 11, 2007 | Kenmore 53632 / 53634 Side by Side...
GE Profile PCF25PGW Side by Side Refrigerator With Ice Box Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
