Question about Whirlpool Washing Machines
What does the F06 code mean on my Whirlpool Duet front load washer?
  • 2,382 Answers
Hi, this advice is for Kenmore Elite HE and Whirlpool Duet FRONT LOADER washing machines displaying the "F06" error code.The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness.Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor.Perform a continuity check of the Drive Motor windings.Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3.All readings should be approximately 6 ohms.HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3.If the readings are good, this will also prove the wiring and connector good.
- Check the MCU.The connectors are numbered 1 to 3 (L to R).That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires.At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor.Pins 1, 2, and 3 on this connector are the Drive Motor windings.Pins 4 and 5 are for the tachometer.
Connector 3 - is the primary power connector.Pins 1 to 2 should read 120VAC with the door in the locked position.Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE:All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
Posted on Oct 05, 2010
What is error code F06
The "F06" fault code indicates a drive motor error. This means the control is unable to properly detect motor speed and the machine will shut down.
Mar 17, 2016 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet is showing error codes f06 and e02 and wont unlock door or run cycle, what can I do?
Janice,
Here is a link to a website that gives the F06 code, but I cannot find the other code.
http://www.appliancepartspros.com/repair-help/whirlpool-fault-codes.
Scroll down towards the bottom to find the Duet fault codes.
Jul 28, 2015 | Whirlpool WFW94HEX Duet 5.0 cu. ft. Front...
Error Code 01 F06
Your fault is mentioned here.
An F06 fault code in a Whirlpool Duet washer (the Kenmore HE3/4t's are also made by Whirlpool) usually means a motor-related problem. It usually pops up when the drum won't rotate at all or only very sluggishly. Here's the excerpt from the Whirlpool Duet Service Manual on this:
http://fixitnow.com/wp/2008/10/28/whirlpool-duet-washer-with-an-f06-fault-code/
May 10, 2015 | Maytag Dryers
Whirlpool duet front load washer, F06 error
FROM WHAT I CAN FIND OUT YOU HAVE A DRIVE MOTOR PROBLEM,
IF YOU TYPE IN YOUR SEARCH BOX (WHIRLPOOL FAULT CODE F06) there are several several sites that tell you how to fix it
Nov 25, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: i have a code it is f06 and then washer stops spin...
Drive Motor Tachometer Error. The control is unable to properly detect motor speed and the washer will shut down.If a failure occurs during high-speed spin the door will be unlocked after 3 minuts. Check wireharness connections between the drive motor/Techometer and the motor control unit also check between the motor control unit and the central control unit. Check the drive motor, the motor control unit, and wire harness.
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Flashing Light
check ot this above link to know what this error code means and how to resolve it.
http://www.applianceaid.com/duet_washer.html#duet
good luck.
thanks.
Oct 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer throwing H the F code
f06 usually means problem in motor speed circuit either main control or motor control or possible wiring connections..FH is usually a problem with the flow meter left side under top has small hose from fill valve and one to dispenser...it's not reading water flow to machine a light tap may help confirm problem if doesn't help may need to change flow meter anyway small switch on small bd with wires will stick and not signal main bd there is water flow
Sep 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Service manual
Whirlpool GHW9150P front loader washer keeps stopping mid cycle witht he F06 code. I can get through an entire cycle if there are only two or three items in the washer. My thought is it needs a new motor drive. would you agree?
Apr 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
388 people viewed this question
Dan Webster
Dan Webster
Sal De
