Question about Video Game Consoles & Games
Experiencing error 74 - Video Game Consoles & Games
    Scholar:
  • 65 Answers
This may be fixed for a short time by unplugging every cord from your xbox and leaving it for 30 min to an hour. tho this is only a workaround if it is under warranty i Highly recommend getting it replaced
An e 74 involves the GPU and will require soldering to truly fix and now there are a fuw things you can do one is to call Microsoft and get Assistance by phone
1-800-4MY-XBOX
International (direct dial to U.S.): 425-635-7180
Hearing Impaired (TDD device): 1-866-740-9269 or 425-635-7102
Hours of operation (every day):
9:00 A.M. to 1:00 A.M. Eastern Time
6:00 A.M. to 10:00 P.M. Pacific Time
-Or-
Try it your self i do NOT recommend do this as it will VOID your warranty but if you feel compelled to fix it your self
--- I do not accept any responsibility whatsoever on what you do to your xbox - I am just here to inform ---
http://www.youtube.com/watch?v=GTBH29CmFHA
This is a video showing how someone fixed there E74 for the second time. The xbox was reported to be currently playing fine, has a few games of halo 3 online to test and the box worked without any problems :)
Go to xbox-scene.com if you need any other infomation regarding xbox repair.
Good luck with whatever you deside to do!,
-Rel
Posted on May 30, 2008
Hp officejet j6480 cartridge error problems
This type of fatal cartridge error (i.e. "refer to documentation" / "incompatible cartridges", etc.) typically indicates the internal micro-electronics of the HP #74/75 cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. However, our test group has also seen these failures with brand new cartridges. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on most models which use HP 74/75 cartridges. Refer to Inkjet411 youtube videos below on how to access respective printer's service menu and correct:
HP 74, 75, 74XL, 75XL Cartridges - Solving Errors & Warnings:http://www.youtube.com/watch?v=C5ISTGyScWU
HP Photosmart C4200-C4500 and C5200-C5500a Printers - Diagnostic Tap 41 Test: (verifies electrical health of ink cartridges):http://www.youtube.com/watch?v=8fE-IM4AVMc
HP Photosmart 4200-4500 5200-5500 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=UDxRkAGOJaI
HP Officejet J5700/J6400 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=3X3_D90SSq4
Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=FnXoDIblpdU
Jan 12, 2012 | HP Officejet 5610 All-In-One InkJet...
Sreen system error e 74
This problem occurs when the Xbox 360 console experiences a hardware failure. To verify that your console is displaying the E74 error message, follow these steps:
  1. Turn off the console.
  2. Turn on the console.
  3. Verify that your console displays the E74 error message.
If you are experiencing this problem, your Xbox 360 console must be repaired..... Microsoft covers repairs for the E74 error for a period of three (3) years from the original purchase date of the console. If you are outside the initial three-year warranty period, you can still receive console repair service from Microsoft for a fee for the E74 error.
https://myservice.xbox.com/en-us/Pages/Welcome.aspx
Jan 01, 2011 | Microsoft Xbox 360 Console
I have the E 74 error how do i fix it?
Basically, this problem is caused by overheating, which is often an issue with most high-powered electronic devices.
As heat levels rise inside your Xbox 360 the connection between the motherboard and the video scaler (HANA/ANA) chip is damaged due to the expansion and contraction of the metal connectors.
Once you have experienced the red ring of death e74 once on your Xbox 360, it will continue to happen over and over again until you fix the problem permanently.
The process of repairing the Xbox 360 red light e74 involves opening up your console, removing the hard drive and disk drive (as these get in the way when you are navigating around the narrow confines of the case) and then locating the video scaler chip.
You then remove it from its seating point and clean the connections; an eraser works well for this. It then has to be seated correctly back in its slot. Once this is done and the hard drive and disk drive are re-installed you can put the case back together.
When you turn your console on again it should be free of the e74 error.
Good Luck and have a nice day.
Jun 07, 2010 | Microsoft Xbox 360 Console
My xbox has E74 what do i do about getting it fixed, however it only shows one red ring in the bottom right of the circle when it is turned on, not three
The Error 74 means that your 360 is experiencing hardware failure. Only one red light should show up. You should send you 360 to Microsoft for a repair. If you are not under warranty you could fix it yourself, by doing the X clamp repair. But by opening your 360 it will void your warranty so be careful.
Hope this helps
May 07, 2010 | Microsoft Xbox Console
Put new cartridge in officejet j6410 and overnight it now says cartridge on left needs replacing. put old cartridge back in and it still says the same thing
These types of severe cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem", "cartridge in wrong slot", etc.) typically indicate the internal micro-electronics of the HP #74/75 cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on most models which use HP 74/75 cartridges. Refer to Inkjet411 youtube videos below:
HP 74, 75, 74XL, 75XL Cartridges - Solving Errors & Warnings: http://www.youtube.com/watch?v=C5ISTGyScWU
HP Photosmart C4200-C4500 and C5200-C5500a Printers - Diagnostic Tap 41 Test: (verifies electrical health of ink cartridges): http://www.youtube.com/watch?v=8fE-IM4AVMc
Dec 26, 2009 | HP Officejet J6410 All-in-one InkJet...
My HP Officejet J6480 all-in-one gives me Cartridge error: Cartridge on right must be replaced. I have changed the cartridge but still get the message.
These types of 'severe' cartridge errors/alert messages (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem", etc.) typically indicates the internal micro-electronics of the HP #74/75 cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on most models which use HP 74/75 cartridges. Refer to Inkjet411 youtube videos below:
Oct 03, 2009 | HP Office Equipment & Supplies
Can i get rid of error E 74 myself
This is from the microsoft site...
  1. Turn the console off and on. To do this, follow these steps:
  2. Turn off the console.
  3. Disconnect all the cables.
  4. Reconnect all the cables.
  5. Turn the console back on.
  6. Turn the console off and on without accessories. To do this, follow these steps:
  7. Turn off the console.
  8. Disconnect any accessories that are connected. For example, disconnect all Xbox 360 controllers, all Xbox 360 Memory Units, and the Xbox 360 Hard Drive.
  9. When the accessories are disconnected, restart the console to determine whether the console or an accessory is experiencing the problem.
Jun 22, 2009 | Microsoft Xbox 360 Console
E74
The E-74 error is also due to overheating and the RROD fix also cures this fault, hope that helps :)
Nov 11, 2008 | Microsoft Xbox 360 Console
Console
error code 74 is
74: AV cable Error - There is a problem with the AV cable, try using a different AV cable.
hope this solves your problem
Maxicube
Feb 10, 2008 | Microsoft Xbox 360 Console
Error 74
error code 74 is
Maxicube
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
