Question about Dewalt 18 Volt Compact Drill Kit
My screwgun just screws it wont unscrew. The button above the trigger does go in and out, but it locks the trigger when it is on the unscrew side. It has worked before,did something get lodged in there?is that possible?
  • 2,176 Answers
It is possible that it hs moved, or the switch is stuck in fhe forward position
Posted on Oct 05, 2010
Can't get rigid zrr8660 screwgun to sink screw more than half way.
Some screwguns have a torque adjustment that slips when adjusted too light. The strongest setting usually has a symbol of a drill bit. Have you tried putting the screw into another piece of wood? If you are going into a very dense wood you may have to predrill hole.
Dec 17, 2014 | Home
How do I remove the 10-year old "TITAN", locking dead bolt from my front door? I removed the interior turn-handle side, but can't get the outside (keyed side) off?
if the inside is off and you unscrewed the main long throught the door screws than it is more than likely just stuck on by paint, they clamp to the door from each side with those screws, if there a no visible screws then its just stuck
Oct 16, 2014 | Kwikset Titan Single Cylinder Deadbolt
How to release dremel tip .already got screw it wont release
Press release button and hold down while unscrewing bolt. Continue to hold button and unscrew bolt until tip is loose enough to pull out if it still won't come out unscrew all the way, take bolt off and pull out tip with channel locks. It just got jammed in when tightening because diameter is probably a little wider
Mar 05, 2013 | Dremel Variable - Speed Multipro Rotary...
How do i change the tip on my screwgun?
put the gun in reverse (the setting to remove a screw), while pressing the trigger with one hand, hold the gun with the other hand on the part that spins, but not the tip itself. hold it firmly, and as it attempts to spin, the tip holder will open wider and release the bit
Jan 23, 2013 | Electrical Supplies
How to remove the chuck?
open the chuck fully and it shoudl have a screw inside. Unscrew it, but be carefull, these screws are usually reversed - to uncsrew, rotate it clockwise. Once done, put allen key into chuck (short side in), fasten the chuck to hold allen key well and hit the key with hammer - counterclockwise direction. You might want to verify this procedure with someone else as I have no experience with Dewalt, but this way it works for Makita, Metabo, Narex, ... then why not for Dewalt? Juraj
Jun 06, 2010 | Dewalt DC727KA 3/8" 12v Cordless...
How can i replace dell inspiron 1525 laptop monitor?
For removing the panel, things you need is just a small + 03 Number Screw Driver.
1. Remove the button highlighted above using a Sharp Object like Safety Pin.
2. Now you will find screws for the Outer Frame.
3. Remove the screws one by one.
4. You might find some locks for the outer panel.
5. Slightly Insert - sign Screw Driver on the frame and scroll it until the locks are released.
6. Now you can easily remove the panel.
7. Once the outer panel is removed, you will find some screws on the side of the frame, unscrew it.
8. At the bottom side of the Monitor there will be a Power and Signal Cable for the Panel, unplug it.
9. Thats it now the panel is removed.
Take Care.
Apr 03, 2010 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
How to unscrew with the drill. Is there a button
Yes there is a button to reverse the direction. Look right above the
trigger in the middle of the drill you will see a oblong button with an arrow on it. Push it in. The button goes through the drill. On the other side the button will have the arrow pointing in the opposite direction. Push it.
Happy Drilling !!
Feb 16, 2010 | Dewalt Drills
Psp Problem
THESE STEPS WILL VOID YOUR WARRANTY!!!
You will need:
1 Fairly Small Screw Driver
Something Soft to protect your screen (Optional)
Something sticky to hold your small screws (Optional, but recommended)
Ability to remember where you removed screws from =D
1. Flip your PSP on the front side (screen side).
2. Unscrew the two screws on the outside opposite of the battery.
3. Open the battery panel, and unscrew the screws under the battery.
4. CAREFULLY, take off the faceplate and make sure your L/R buttons are properly secured and clear from dust/dirt.
5. Check the 'Home', 'Start', etc., buttons for anything that may "jam" them.
6. Reassemble your PSP by screwing the screws back into their proper areas.
AGAIN, this will VOID any warranty you have and I AM NOT responsible for any damages to your PSP!!!
Sep 18, 2008 | Sony PlayStation Portable (PSP) Console
Dewalt 18 Volt Compact Drill Kit Logo
61 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
