No Problem I will like to know how many ton it is and any other info like age and capability, what size house it is design for? I am Buying a house and it has it. Thanks in advance Jose Chacon the serial # is 0507088010 the model # CKL36-1L
  • 455 Answers
Hello,You have a 3 ton unit 2500 sq.ft+
Posted on Oct 05, 2010
Tons needed to cool 20,000 sq. ft.
hundreds of variables such as building age, insulation, size and quality if windows, etc. Also how many people will be in the building at one time? VERY rough guess without knowing the answer to those questions is 40 tons, but do a heat loss and gain calculation to know for sure.
Jan 26, 2015 | Carrier Heating & Cooling
What size coil fits this
The 70 stands for 70,000 btu and the 16 stands for 1600 cfm.. Air conditioning requires 400 cfm per ton, so the blower is capable of delivering enough air for a 4 ton a/c unit. However, the blower is is amultispeed and has a 'blower chart' in the manual that will give you an idea of air flow delivered on all 4 (usually) speeds. You wouldn't want to deliver 4 tons of air across a 3 ton coil. That would effect the temperature drop across the coil and also effect humidity removal.
4 tons of a/c is a considerable amount of cooling, so unless you have a large space or extremely high average summertime temps, I would ask a local contractor to do a heat load calculation to properly match a system to your specific needs.
Every area has a 'design temp' around which a system should be designed. Here in the St Louis area, the design temp for the winter is 5 degrees and for the summer its 95 degrees.
70,000 btu in gas equates to 20 kw in electric heat for what its worth.
Jun 15, 2014 | Comfortmaker G8MXN0701716A 66,000 BTU 80%...
Do dog houses come in different sizes?
Yes, of course, dog houses are available in various different sizes and designs. You can purchase any type of house for your dogs according to their size and breed.
I have also purchased two dog houses of different sizes for my two dogs from the Wooden Dog House. They are one of the best sellers. According to my experience, their products are very much stable and comfortable for the pets. They also provide professional solutions for any problems related to your dogs.
I will also suggest you use their services for your dogs that are available at a good affordable price.
Sep 12, 2012 | Precision Pet Dogs
Buying a house and want to know the size of the air conditioner...model is goodman clj60-1c and s/n is 0505041878....
That is a five ton unit...that's what the "60" in the model stands for.... 60,000 BTU.....12,000 BTU equals 1 ton...5 x 12 equals 60.
heatman101
Jul 10, 2011 | Goodman CLJ60AR61 Air Conditioner
I HAVE A NEW AC 2.5 TON GOODMAN, MY HOUSE IS 1600 SF I HAVE 3 BEDROOMS AND TWO ARE CLOLED AND THE VENTS ARE CLOSED TOO, WITH EVERY THING OPEN THE HOUSE WILL ONLY GET TO ABOUT 80-81 % NEW HOUSE WITH LOTS...
Depending on everything working correctly with the system, the problem I see may be the size of the system. 2.5 tons is enough to condition around 1000 sq. ft. At 1600 sq. ft. Of living space, you will need a 3.5 to 4 ton system. Unless it was designed in a way that 2.5 tons would work which i doubt, there would be a problem with the charge of refrigerant or other under lying problems. First I would make sure your system is designed right for your house, check all filters and air flow from the vents. Then you go from there. Q good way to check the charge without equipment to do it, on a warm to hot day the outside copper lines should be sweating and warm to hot air coming from the fan on top of the condenser. It's not the accurate way to do it, but a good check anyways. Hope this helps and good luck!
May 25, 2011 | Goodman CLJ42AR49 Air Conditioner
WHAT IS THE AGE AND SIZE of uacc-024jas
Just from the numbers I see it looks like a 2 ton A/C 24 in the numbers stands for 24,000 btu one ton equals 12,000. The age is unknown from the numbers you provided. If this helps please rate me and do a testimonial.
May 20, 2011 | Heating & Cooling
My weatherking outside compressor isn't big enough to handle my cooling needs. It is 1.5 ton unit, can I put a bigger ac unit onto this one without changing my heating system which is sufficient?
if your indoor unit is 1.5 ton the answer is no
if your indoor unit is 2.0 ton then you can jump to that size.
Note :your duct system may have been designed for a 1.5 ton and may need to be reconfigured for a size increase.
Your hvac contractor should know this?
Jun 14, 2010 | Weather King 10AJA4201AH Air Conditioner
I have an '06 model combination cooling and heatin
For every 500 sq. ft. house or a 1-bedroom size new house you need 1-ton of cool . An old house you need a ton worth of cooling for every 400 sq. ft. house or a 1-ton per 1 bedroom size house.
Dec 22, 2009 | Whirlpool Heating & Cooling
Need info for RUDD upflow oil furnaces
Contact your nearest Ruud DISTRIBUTOR, usually The Noland Company, and ask them if they could go into the historical documents and print out or send you the files for the wiring, spec's and parts breakdown. From the model number, that unit is rated for 3 tons of a/c. You can find a 3 ton coil that will fit in the space and get a straight cool condenser of 3 tons cooling and swap thermostats so it brings on the furnace and fan in heat and the condenser and fan in cooling. Or just add a simple White - Rogers model 444 for the cooling. Ron
May 06, 2009 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
81 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
