Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
Hi. My fridge is about a month old. Although we have the freezer set at 8 degrees (the warmest it will set to), the freezer is extremely cold. Ice cream becomes rock hard (we can't even cut it with a knife). Can it be adjusted? Thanks, Pat
  • 316 Answers
This is not an adjustment issue, this is a malfunction issue. If you have a thermometer that you can place in the freezer, as opposed to any temperature readings from the freezer itself, your temps would normally be around 0 degrees F. At the warmest freezer settings, you should be around 10 degrees, which would make your ice cream very scoopable. I would contact the store you purchased it at or Samsung for a refrigerator repair service as soon as possible before they tell you its no longer covered under warranty.
Posted on Oct 05, 2010
Fridge Ices Up Even on the Warmest Setting (Freezer Working Fine)
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
If it runs then that cold control is the problem.
Sep 15, 2017 | Refrigerators
Why do freezer coils ice up on my Stainless Steel Whirlpool refrigerator (model GB2SHDXTS)?
On your model your cntrl board has a relay that can stick causing the compressor to always run even when the unit is turned off or in defrost. turn the fridge off, move the temp of the freezer to it's warmest setting and it should display a line in the freezer and fridge temp display. listen to hear if the compressor is running in back of the unit. if it is you need part number: 12868513
Mar 15, 2013 | Whirlpool Refrigerators
2007 french door -bottom freezer -kenmore elite fridge- freezing foods in fridge and icemaker not making ice regularly- sporatically making small amounts of ice cubes motherboard was replaced when fridge...
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Sep 14, 2011 | Refrigerators
Turned the fridge temperature up (ie. from 3 to 6) but fridge warmer than ever. Gauge on side ambiguous. Now wondering whether 1 is actually the coldest and 6 the warmest. Help! Fridge old so can't trace...
Keeping 3 to 5 degree is good. But check freezer is frosting good. If ice formation around the freezer is over, it will abstract the fan by functioning. If so, check defrost timer, thermostat and heater for not malfunctioning.If defrost cycle is good, there would be constant cool in fridge compartment.
Thanks.
Feb 03, 2011 | Fisher and Paykel Active Smart E522B...
Hi, I have a fisher and paykel fridge for almost 3 years.The problem is that the ice cube maker stop working. I have check all the things that are mention in the fridge guide, water supply is fine, the ice...
I had the same problem. my freezer was set too cold so the water inlet was freezing. what I did was blew a hairdryer into the ice making section for a couple minutes, this seemed to melt the block, then tested that it was clear by forcing the ice tray through a cycle. you then need to set your freezer warmer - I find setting it 2 bars from the warmest setting keeps stuff frozen and the ice coming :) hope this helps!!
Jan 29, 2011 | Fisher and Paykel Active Smart E522B...
Fridge running at higher than 4 degrees.
I have the same problem with my F&P fridge/freezer although I'm not sure how old it is because I bought it from my landlord when he moved out. I call the repairman who said turn it off and defrost the freezer. I turned it off last night, defrosted the freezer as there was some ice build up internally at the rear and turned it on again. It went fine, I set it at the coldest (gauge on colder) setting and this morning it was quite cold. Today I get home from work and it's hardly cold, no condensation on the lemonade or beer bottles! Will be interested to hear others thoughts before I call the repair man again. thanks, Jenny
Feb 09, 2010 | Fisher and Paykel Active Smart E522B...
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
Freezer cold, not fridge
24 hours It should be good Do check temp settings.
Aug 05, 2009 | Candy CPCA240FFK Bottom Freezer...
Frigidaire side by side doesn't make ice
If the Temperature in the Freezer is not cold enough, the Ice maker will not make ice. Make sure the freezer is below 10 degrees or so. Zero is where you want it for the best ice production. What was the reason for defrosting in the first place? Should be frost free?
Jan 31, 2008 | Frigidaire FRS3R5EMB Side by Side...
Ice build-up in the freezer of a Kenmore 19 (Top Freezer) refrigerator, and only 60 degrees in the fridge.
there is supose to be a switch or were the ice is making just figure out which way to turn it off or on. then turn it off and see if the ice stop making. if that doesn't work get a new frige
Jan 29, 2008 | Refrigerators
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
170 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
