Question about Frigidaire Dishwashers
I put too much voltage into my Frigidaire dishwasher (FDBB2040FS1) is there a replacement part that can be ordered?
  • 901 Answers
You have to check the electrical damage and replace the parts. It may be a fuse problem if you are lucky!
Posted on Oct 05, 2010
Frigidaire dishwasher not filling with water. It's not the inlet valve. Already bought new.
Do you have the voltage present at the valve in order to open it on command from the controller?
Oct 27, 2017 | Frigidaire Dishwashers
FIRGIDAIRE DISHWASHER FDB1050RES0 WASHING LIGHT BLINKING CONSTANTLY BUT MACHINE WON'T RUN
Thank you for your inquiry, William Garrett!
I understand that the washing light on your Frigidaire dishwasher, FDB1050RES0, continues to blink and will not run. You may need to perform a reset on your dishwasher. In order to do so you would need to disconnect power from your dishwasher for roughly ten minutes. This will help clear out any false error codes or miscommunications within your dishwasher. If resetting your dishwasher does not resolve the issue you may need to have an electrical component replaced and I would recommend seeking professional assistance for that. Hope this is helpful. -Matt
Feb 16, 2015 | Frigidaire Dishwashers
How do i clear error code u0 on frigidaire dishwasher
pressing cancel twice should remove the error code. if not interrupt the power to the dishwasher for 30 seconds then apply power to the dishwasher. also verify proper voltage is applied to the dishwasher. all should be done by a trained appliance repair technician.
Aug 13, 2014 | Frigidaire Washing Machines
Dishwasher is draining slower than normal and sometimes doesn't drain at all, I have replaced drain hose...still having same problems.
The drain pump /valve is the faulty component and must be checked , this is at the drain of the chamber and water is flushed . Normally it gets clogged due to dirt accumulation of the dishwasher.
So have it removed ,give voltage to test outside or replace. Also make sure that there is voltage to the pump when the drain cycle happens.
Sep 29, 2010 | Frigidaire FDB1050REM Dishwasher
Frigidaire dishwasher noticeably louder - circulation motor?
Try to position the machine, so that you can run the cycle and watch the dish washer. Remove the back panel and hear the sound of origination. Take suitable action as per your convenience. You can clean & replace the bearings if they are worn or replace as a whole unit.
Jul 06, 2010 | Frigidaire Dishwashers
The lock symbol located at the dry button is lit and the dishwasher wont start on my built in Frigidaire fdb520rhso
check your door lock make sure it has correct voltage and has not been closed indicating that it is locked.other than that replace the control board
Mar 12, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
Drain out is done via the pump out motor. Is the pump out motor working? Check by deternining with a AC voltmeter to see if supply voltage is across the terminals in pump out mode. If voltage is present and motor does not spin - the motor is open circuit and must be replaced. Remove the 2 clamps and the 2 electrical push on terminals with the MAINS voltage disconnected. Is the outlet pipe not blocked or obstructed ?
Jan 19, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Replacing detergent dispenser
take the door apart, the dispenser will pop out and you can rehok the new. make sure the seal is good
Feb 17, 2009 | Frigidaire FDB949GF Dishwasher
Dishwashers Logo
65 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
