Question about Moultrie MFH-DGS-100V2 Digital Camera
Cant get it to take picturs it says SD locked
    Brigadier General:
  • 3,006 Answers
First check that you are using an SD card with a capacity which does not exceed 1GB as that is the maximum your camera can handle and it will give error messages with larger capacities, especially if you have fitted a later specification SDHC card. Click here for a free download of the user manual from Moultrie if you don't already possess one.
If you are using the correct type and capacity of memory card then this is such a common question that I hope you don't mind if I paste my generic answer below. Note that cards may appear to be unlocked when they're not. The answer also covers what to do if the card is faulty.
Your camera uses SD memory cards. On one edge is a slider switch: towards the electrical contacts is the unlocked position and away from them is locked.
Unfortunately, the switch is easy to move accidentally and it's also easy for it to appear to be unlocked when it isn't. Like any mechanical component it's also possible for the switch to fail.
If the switch is in the locked position then slide it fully to the unlocked position; if it's already in the unlocked position, slide it fully to the locked position and then fully back again. There should be a soft click at each end of the switch travel, if not then the switch is definitely faulty or obstructed.
If that fails, then try looking closely at the switch in both positions to ensure that there is no debris obstructing its movement, if not then check the electrical contacts to ensure that they're completely clean and grease-free. Don't touch the contacts with your bare skin, but if the contacts need cleaning then a cotton bud (Q-tip) moistened with a little alcohol or methylated spirits can be used to clean them.
If you still have no fix, then try a different SD card as yours may have an irreparable faulty switch. If the card does prove to be faulty then on most major brands you may be able to return them to the manufacturer for exchange: I've found that they will often do this on a goodwill basis even if the card is out of warranty. Just check the manufacturer's website for support details.
If all options regarding the memory card are unsuccessful, then you have a faulty camera and further remedies require either a professional repair or replacement of the camera.
I hope that my free answer has been of use and has given you options to fix your problem. Please let me know by taking a brief moment to rate my reply.
Posted on Oct 04, 2010
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Moultrie Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Memory card error appears.cant take any more pictures. what do i do now...
Your camera can handle MMC and SD cards. Modern SD cards are most likely SDHC cards and can't work in your camera. `please look for maximal 1 or 2 Giga Byte cards and the should not have SDHC or SDXC printed on them.
If your card is full, and it won't take more pictures, try putting most or all photos on a computer. Then delete the pictures you transferred. Make sure you also backup you pictures on an other medium.
Also check the lock switch on the memory card is NOT in the lock position.
Jun 22, 2014 | HP Photosmart M415 Digital Camera
Lexor sd card Locked in camera
Actually there are several possible solutions to this problem, Troubleshooting steps may be viewed here:
Dec 08, 2012 | Sanyo Cameras
How do i unprotect my sd card because i cant upload pictures
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 04, 2012 | Sanyo VPCCA102 Dual Camera Xacti
My SD card is locked and i cant get it unlocked
Nov 24, 2011 | Vivitar ViviCam 5024 Digital Camera
I can see the pictures form my 1 gb sd card in my Casio Exilim. However, I cant see or transfer the pictures when I connect the camera to my laptop via the usb cable? the camera comes up as removalble...
It's good the laptop recognizes the camera as an external drive. A couple of things make sure you are looking at the SD card and not the cameras internal memory. Most point and shooters can't download directly from the internal memory to the computer they need to be transferred to the SD card first. Also if they are on the SD card for sure look to see if you have locked any of them cause that will prevent a download as well. It almost appears as if the SD card became locked which all it will alow you to do is look at teh picture and nothing else. I'm including a diagram of the little lock on the side of the SD card make sure that's in the open position.
Diagram
The position in thee little circle is where it need to be for unlock
Jan 06, 2011 | Casio Exilim EX-Z750 Digital Camera
Cant take picture says card is locked
There is usually a switch on the side of most picture cards (I am guessing its an SD card) this is the lock switch. Try setting it to the 'Unlocked' position.
Good Luck!
Jun 19, 2010 | Canon PowerShot A470 Digital Camera
Cant copy pictures to sd card error msg write protected, help!!!
Look at the tab on the sd card to be sure it is not in the locked position. Thats probably it or you need a new sd card.....
Apr 16, 2009 | Palm Treo 700wx Smartphone
Sandisk Sd card
there is a small switch on the side of the card change its position.Its there so you cant accidentally delete stuff thats important you may have moved it by mistake
Nov 21, 2007 | Cameras
Cant take songs off Says " Write Protection"
There is a LOCK switch on the side of the SD Card.
Slide it away from the LOCK and youll be all set.
Best of Luck.
Oct 28, 2007 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Moultrie MFH-DGS-100V2 Digital Camera Logo
199 people viewed this question
Top Moultrie Cameras Experts
Steve
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
