Question about Fantom Vacums Cyclone XT Upright Vacuum
Fantom Cyclone XT
How do I open the body of a Cyclone XT? The electrical cord is frayed & broken at the entry point of the unit. I could rewire it if I could open the body. I can't find screws, and don't believe it is glued together!
Thanks!
  • Rhonda Cain
    Rhonda Cain Jan 31, 2012
    This is my problem exactly. I don't see the top edge pieces that pop off? thanks
    President:
  • 1,673 Answers
The top edge pieces will pop off, tabs hold them in place, then you take it apart.
Posted on May 28, 2008
Fantom F11063 Cyclone Vaccum
I think the manual can help you in replugging the wires
How did you pull out the wires from circuit board ?
Is it with professional help or through some other means
Sep 18, 2008 | Fantom Vacums Cyclone XT Upright Vacuum
How do i replace the belt in the Fantom Cyclone XT vacuum
remove the covers over the headlights and under the shiny foul. there are two screws. there are two tabs that hold down the cover over the wheels, they just pop on/off with a click.
on my xt. i had to remove the rolling brush and clean out all the hair that was stuck in the bearings. remove the screw holding down the motor and belt. pry out the roller brush to get to the bearings. there was some serious hair ball in there.
reassembled mine and it works perfectly now :)
Dec 19, 2008 | Fantom Vacums Cyclone XT Upright Vacuum
Parts
TheFantom Cyclone XT was originally manufactured by Fantom Technologies,Inc. that closed in October 2001. The replacement for a Fantom CycloneXT would be Westinghouse Wired Deluxe Edition (either a WST1550 or a WST1551). These replacement products are now handled by Salton Inc. Perhaps you may inquire from them:
  • Salton Inc.
  • 1 800 616 8689
  • salton@saltonusa.com
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 20, 2008 | Fantom Vacums Cyclone XT Upright Vacuum
Fantom cyclone xt quit working in the middle of using it
you probably have a broken wire in cord or the power switch has gone bad two options take it to qualified electrical repair shop or if you just purchased it recently return it to the store also try another appliance in same outlet to make sure you havent thrown a circuit breaker hope this helps
Fantom Cyclone XT Vacuum Cleaner
Here is the owners manual which goes over some troubleshooting problems.
http://www.fantom.com/fantom/manuals/Cyclone.pdf
At first I would think it was the thermal overload, which is covered in the manual. But I would guess that you have let it sit for 30 minutes to cool down and tried again and the vacuum still didn't work.
I would think you may have one of four problems.
1. Your thermal overload was tripped and is stuck and will need replaced.
2. You have a clog in your vacuum lines or the brush roller is froze, which keeps causing the thermal overload to trip.
3. Your power cord has a short, which would need replaced.
4. Your power switch is bad, which would need replaced.
Out of these 4 possible problems I would say the only one you could fix on your own would be problem #2. Make sure the vacuum is unplugged and take the brush roller off and clean it, make sure it moves free. Check your vacuum lines to make sure you do not have a clog, other wise the motor does not get air flow to cool it down causing the thermal overload to trip. As for problem 1, 3, and 4 I would suggest taking it to a repair shop.
Hope this helps, post back.
Jul 11, 2008 | Fantom Vacums XT450K Upright Vacuum
Fantom Cyclone wiring
The only sure way recommended (and probably the safest) would beto get a service manual or at least a schematic diagram. The FantomCyclone XT was originally manufactured by Fantom Technologies, Inc.that closed in October 2001. The replacement for a Fantom Cyclone XTwould be Westinghouse Wired Deluxe Edition (either a WST1550 or a WST1551). These replacement products are now handled by Salton Inc. Perhaps you may inquire from them:
  • Salton Inc.
  • 1 800 616 8689
Jun 08, 2008 | Fantom Vacums Cyclone XT Upright Vacuum
Circuit board
You should be able to locate parts for your vacum at this link by entering the model number.
http://www.fantom.com/fantom/default.aspx
Mar 25, 2008 | Fantom Vacums Cyclone XT Upright Vacuum
Fantom Vacums Cyclone XT Upright Vacuum Logo
172 people viewed this question
Top Fantom Vacums Vacuums Experts
Richard Agent
Charles T Nevin
Charles T Nevin
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
