Question about Denon D-M50S CD Shelf System
Denon m50 The cd function on my set stopped working and display said Mechanical Error, any ideas? the trays are stuck because two cd's were in the same tray.
    President:
  • 2,712 Answers
You could try this:
Press the eject button on the player. You will notice that the tray is making an attempt to move. Use two fine screwdrivers, and insert them into the space at the sides of the tray, one on each side, and gently try to pull the tray out..
If that doesn't work, then you may have to open up the cover and try a manual extract..
Hope that helps..please post back and let me know how it goes..
Posted on May 27, 2008
    Genius:
  • 3,422 Answers
HI,
Well you can fix this by yourself but you'll have to unscrew the device.
The cause is that the lubrication of the plastic lifting components has dried out and the clamping mechanism is not moving freely enough. This results in a situation with other moving parts of the carousel causing a jam. By gently relocating the jammed trays and ensuring free movement of the clamping mechanism the problem can be solved.
NOTE: The lubrication appears to be a specialist one used particularly for plastics.
Goodluck,
Please don't forget to rate the solution.
    Genius:
  • 3,587 Answers
Ooops...you may need to do a manual extraction on that...there may be a reset manual mode on that one..let me check the user guide..but it may require removing the case, and delicately releasing that mechanism from inside..
  • Patrick Michaels
    Patrick Michaels May 27, 2008
    I'm having a heck of a time finding that model number. How old is it?
Cd ejection tray
From Standby press function, whilst holding function press power (both on the main unit).
The display will show demo mode, this has now disabled the mode.
Regards Graham
Jul 25, 2010 | Denon D-M33 Shelf System
I have a denon 3500 cd player my cd is stuck
Open the top cover of your CD using a screw driver, (usually a star screw driver),. Then, manually turn the driving gear of the CD tray to free the stucked tray and until to the point where you can take the disc from the tray. Be careful so the setting of the tray and the laser eye is not change. Then, close the close the cover and play. You can send your e-mail thru fix ya to let me know.
Sep 25, 2009 | Sony CDP-C910 10-Disc CD Changer
Denon DCM-280. Tray won't open, there are CDs in
If you don't wanna send it for service, open the chassis of the player and free the CDs from the tray. Its highly likely that the CDs came off the trays and got stuck inside.
Jul 31, 2009 | Denon DCM-280 5-Disc CD Changer
Deneon UD M50 - Tray jam
It sounds like the cd tray has been forced shut and has been damaged when you got the CD's out. If it was me I would of unscrewed the casing and retrieved the CD's that way instead of trying to force the try open which I'm assuming you have done.
It could just be a simple matter of just slightly adjusting the internal CD mechanism so that it can open and close properly without jamming. The error message comes up because the tray cant eject properly. The worse case scenario is that the CD mechanisam would need to be replaced. Not a hard job for a service engineer, if you dont fancy taking the thing apart yourself then a service centre is your best bet.
Nov 01, 2008 | Denon D-M50S CD Shelf System
I have an denon ud m50 multi cd player and reciever some one tried to put more than 1 cd in the same tray and it now will not accept any so its a mechanical problem can this be fixed and if possible...
Yes this is fixable by rebuilding the loading mechanism. As long as the mechanism is just jammed and no parts are broken, this should only cost the labor charge at a local service shop. I have done a number of these in the past and while not the simplest of mechanisms, it is fairly straightforward.
Dan
Aug 26, 2008 | Denon Audio Players & Recorders
Denon M50 CD trays stuck
Hi Jez
I have only just picked up your request for the MD50 manual.
If you can let me know your Email address, I will forward the info on.
My Email address is normanibbotson@hotmail.com
Regards
Jun 28, 2008 | Denon D-M50S CD Shelf System
Denon UD-M50 cd changer. Need help extracting drawer for home repair!
Hi KathyKate
If you are still having the same problem with your denon UD-M50 I might be able to help. I have fixed a number of them in the past and have the necessary maintenance manual and knowledge of a company that can supply spare parts. Disassembly looks very complex, especially when the problem is with the carousel but once you have an understanding of the mechanism it's not that difficult. Care should be taken when manually removing and reloading the disc trays as damage can result to the 'Teeth' alongside each. Spare trays are available. All my repairs involved the removal of the carousel mechanism in order to align the trays. I can copy the relevant sections of the manual dealing with the re-alignment which is critical but again if followed exactly you should have no trouble. If you respond with an Email address, I will be only too pleased to forward you the schematics etc.
Regards Ibbotsnm
Nov 15, 2007 | Denon D-M50S CD Shelf System
DENON UD M50 CD PLAYER no longer works
Maybe you accidentally break some contact(s), on display or somewhere else. If that is the problem, soldering iron should solve that. Look for any loosen wires or detached contacts.
Oct 10, 2007 | Audio Players & Recorders
CD Changer
You can probably fix it yourself but you may need some parts. Here's Denon's link that'll take you to the next step http://www.usa.denon.com/
May 09, 2007 | Denon D-M50S CD Shelf System
Denon m50
Nov 24, 2006 | Denon D-M50S CD Shelf System
Denon D-M50S CD Shelf System Logo
246 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Dennis McCollum
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
