Question about Russound CA64i 12Channel Amplifier
Have a ca 6.4 i that stopped producing sound all lights and controls work and i checked that all sources work ? what can I check or do
2 Suggested Answers
micromatikal
  • 2777 Answers
SOURCE: russound ca 6.4i stopped putting
It is major hardware failure on the device, as long as you have tried rebooting it (unplugging for 2 minutes and replugging). Then it is the internal processor or other major board that has failed. Many things can cause it not to output sound... could even be a solder point that broke inside the unit on one of the boards. No easy fix for this but you can take apart the machine and look for physical damage if you want to try and fix it yourself.
Thanks
Tim
Posted on Oct 04, 2010
No sounds from my yamaha HTR6030 Display is OK. All function keys working.Relay clicks. But no sounds.
Try connecting different sources to different inputs or fm source if nathing produces sound I would recommend to have it check by a tecnitian
Aug 19, 2016 | Yamaha Audio Players & Recorders
Lights but no sound
check that they are connected up correctly and are plugged into the correct socket.
go to control panel, or the utility that controls the sound card attributes, such as realtek mixer, soundblaster mixer control, and ensure that sound output is set for speakers.
go to volume control and ensure that sound is not muted.
With some modern motherboards it is far less straightforward to set up speakers than it used to be.
In your system devices/device manager check whether the sound / video codecs are installed and are not listed in the "other devices " list. If they are that means the driver will need to be installed.
The way to check whether the sound card is functioning at all is to plug a pair of headphones into the appropriate socket and check whether sound is produced.
It is fairly straightforward but is made difficult when you have 6 sockets on the soundcard.
GOOD LUCK
Nov 04, 2015 | Audio Players & Recorders
Mw612 not working
It looks like Error Code 130,
130. (10000010) Phase 1 to 6 Single Rotor Position Sensor Error
The Motor Controller has found an error in the pattern received from the Rotor Position Sensor.
Likely causes of this fault are a bad connection on the harness
between the Rotor Position Sensor and the Motor Controller,
or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action:
1) Check for corrosion on the edge connector of the Rotor Position Sensor and
the Motor Controller module connector.
2) Check the contacts on the rotor positional sensor end of the hall harness to
see if any have been damaged. (Each set of contacts in the socket has two
wipers. If the distance between these wipers varies between different
contacts, replace the rotor positional sensor harness).
Secondary Source: Rotor Position Sensor.
Action:
Check the Rotor Position Sensor with an R.P.S. tester.
Replace if faulty.
Tertiary Source: Motor Controller module.
Action: Replace Motor Controller module.
Jun 12, 2013 | Fisher and Paykel GWL11 Top Load Washer
My fisher and paykel smartdrive wont agitate or spin but it pumps the water out it , when i spin the drum there is a bumping sound. can i get into the drum part to see if anything has gotten inside?
That is fault code 130
130.(10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness between
the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Action: Check for corrosion on the RAST connector of the Rotor Position
Sensor and the Motor Control Module connector.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if
faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted
Jul 31, 2012 | Fisher and Paykel Fisher & Paykel Washer
Fisher and Paykel Smartdrive washing machine won't fill up
Your fault code is 131,RPS faulty.
between the Rotor Position Sensor and the Motor Controller, or a faulty Rotor
Position Sensor.
Action:
Action:
Check the Rotor Position Sensor with an R.P.S. tester. Replace if faulty.
Action:
131. (10000011) Phase 1 to 6 - Repetitive Rotor Position Sensor Error
This fault is similar to fault number 130 above but differs slightly in that it is a
continuous condition. See fault code 130 for service procedure
Mar 20, 2012 | Fisher and Paykel Washing Machines
I hace a 1990 firebird V-6 and at stop lights its idles bad and then dies the check engine light comes on, when i start it back up and drive the check engine light disapears. It is also getting hot while...
SOUND LIKE FAULTY IDLE SPEED CONTROL OR FAULTY FUEL INJECTOR OR A INTAKE VACUUM LEAK.IF GETTING HOT WHILE STOPPING.CHECK COOLANT FAN FUSE AND RELAY.IF BOTH GOOD.HOT WIRE COOLING FAN TO CAR BATTERY USING JUMPER WIRES.IF COOLING FAN DONT WORK REPLACE THE MOTOR.IF FAN WORKS.COOLANT TEMPERATURE SENSOR IS BAD.ALSO HAVE CAR SCANNED TO SEE WHAT CAUSING CHECK ENGINE LIGHT TO COME ON.
Feb 19, 2010 | 1990 Pontiac Firebird
Blower on my 2004 Mazda 6 went out
Sounds like your blower motor or blower motor resistor went out.
Jan 26, 2009 | 2004 Mazda 6
Ice maker not working, light blinking
I contacted Sears repair service and had the Ice maker and control panel replaced.
Jan 09, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Has light but no sound
The first thing to always check first is the fuse. This will probably involve some disassembly but it is alwayst the cheapest fix and a constant issue.
Aug 14, 2007 | Sunfire True Sub Signature Subwoofer
Russound CA64i 12Channel Amplifier Logo
82 people viewed this question
Top Russound Audio Players & Recorders Experts
Robert Graf
 Grubhead
Grubhead
Gil Shultz
Are you a Russound Audio Player and Recorder Expert? Answer questions, earn points and help others
